Originally Posted by
larkspur
Please ignore the TCIA, typing error
I'm sure Excel Fox won't mind if I jump in here. Based on your previous descriptions of your invoice numbers and what your data column values look like couple with how you want the data split out, I have a UDF (user defined function) for you to consider (I could not think of anyway to do it with normal Excel functions)...
Function InvoiceNumbers(Cell As Range) As String
' This function assumes output will start one cell to the right of the specified Cell argument
Dim X As Long, Index As Long, S As String, OutText As String
S = Cell.Text
For X = 1 To Len(S)
If Mid(S, X, 11) Like "[A-Za-z][A-Za-z][A-Za-z]#####/##" Then
OutText = OutText & " " & Mid(S, X, 11)
ElseIf Mid(S, X, 10) Like "2000######" Or Mid(S, X, 10) Like "1800######" Then
OutText = OutText & " " & Mid(S, X, 10)
Index = Application.Caller.Column - Cell.Column - 1
If Len(S) Then InvoiceNumbers = Split(Trim(OutText) & Space(Len(S)))(Index)
Assuming your data starts in cell A1, put this formula...
=InvoiceNumber($A1)
in cell B1 (note the $ sign to freeze the column letter) and copy it across for as many columns as you think you might ever need your data split out into and then copy all those cells down to the bottom of your data.
HOW TO INSTALL UDFs
If you are new to UDFs, they are easy to install and use. To install it, simply press ALT+F11 to go into the VB editor and, once there, click Insert/Module on its menu bar, then copy/paste the above code into the code window that just opened up. That's it.... you are done. You can now use NameOfTheUDF just like it was a built-in Excel function. See the example formula and instructions above.
