Results 1 to 8 of 8
Thread: Select Group Of Cells Using Data Validation
    Dec 2012
    Can groups be selected using Data Validation....I have 3 groups of people....can I have a dropdown list where I select any of the 3 groups and it places the select group names in "Sheet DV" merged cell area
    Rich
    Dec 2012
    Can this be done
    I would suggest two ways to do this. But my advice would be to avoid merged cells as much as possible.
    Dec 2012
    That is excellent
    I will follow the Alternative version.
    Is there a way to stop the cells from being over written....using the "Another Alternative" version where the formula - =IFERROR(INDEX(DVGroup2,ROWS(C$4:C5)),"") can be over written by typing over the names...can this be locked so only the dropdown list can be selected
    Also what is the 6,1 at the end of this formula
    OFFSET(lists!$A$2,0,MATCH(CurrentGroup2,AllGroups, 0),6,1)
    Thanks for your help
    Rich
    6 is the number of rows for each group, starting from header
    1 is the number of columns for each group
    You can lock all the cells, except the header cell, and then protect the sheet. This will stop users from overwriting the cell.
    XL: How to Lock Individual Cells in a Worksheet
    Dec 2012
    Thanks again
    Another Alternative Sheet - If I want to add another 2 of the dropdown lists down the sheet what is the best way to copy and paste....I want exactly the same dropdown lists down the sheet
    Did you color the header of the dropdown list manually and also the Lists manually with the color orange
    Thanks again
    Yes, I colored them manually. Just copy the entire range to where you want, any number of times.
    Dec 2012
    I try to copy the DV down but have done something wrong as I cannot control the 2 added groups. I need to be able to select any combination in the 3 groups..all box`s can have group 1 or 2 box`s have group 2 and the other box group 3 or box 1 has group 1 , box 2 has group 2 and box 3 has group 3 ...any combinations
    Do I need to add to the Name Manager
  1. Replies: 3
    Last Post: 06-10-2013, 06:12 PM
  2. Replies: 4
    Last Post: 05-05-2013, 04:01 AM
  3. Group Pivot Data Based On Row Values In One Column
    Last Post: 10-09-2012, 11:46 PM
  4. Dependent Data Validation (Using Only Formulas)
    Last Post: 10-18-2011, 03:14 PM
  5. Data Validation Dependent Dropdowns
    Last Post: 04-10-2011, 03:34 PM
