Results 1 to 10 of 11
Thread: Minimize/Maximize Ribbon using VBA
    I need a code which hide Ribbon, Gridlines, Heading and FormulaBar using VBA.
    Thanx in Advance.
    Try
    Sub ToggleProperties(ByVal ShowRowColHeads As Boolean, _
                                        ByVal ShowSheetTab As Boolean, _
                                        ByVal ShowGridLines As Boolean, _
                                        ByVal DisplayFBar As Boolean, _
                                        ByVal DisplayRibbon As Boolean, _
                                        ParamArray ShtNames() As Variant)
        If Not IsMissing(ShtNames) Then
            ThisWorkbook.Worksheets(ShtNames).Select
            ActiveWindow.DisplayHeadings = ShowRowColHeads
            ActiveWindow.DisplayWorkbookTabs = ShowSheetTab
            ActiveWindow.DisplayGridlines = ShowGridLines
            Application.DisplayFormulaBar = DisplayFBar
            Application.SendKeys ("^{F1}")
            ThisWorkbook.Worksheets(ShtNames(0)).Select
    and call the routine
    Sub kTest()
        ToggleProperties False, False, False, False, False, "Sheet1", "Sheet2"
    Note: Minimising Ribbon command toggles the current status of the Ribbon. If the Ribbon is minimised, it'll maximise and vice versa.
    You can replace the command to toggle ribbon visibility
    with this
    Application.ExecuteExcel4Macro "SHOW.TOOLBAR(""Ribbon""," & DisplayRibbon & ")"
    Thanx for this useful function.
    Working!
    Apr 2013
    missing from sample code.... "DisplayRibbon" does not change anything
    there are five parameters provided to set values:
    only four are utilized
    please advise of corrected code sample
    FYI: thread rating of "BAD" due to incomplete sample code... and worst of all misses the question of how to manipulate "ribbon"
    It is easily understood from my post above that you should REPLACE one line with another.
    I think to hide ribbon. Best to switch the workbook in full view mode.
    I hope it is tricky..
    Here is a non sendkeys method to minimize/maximize Ribbon (works XL 2010)
        Const RibbonHeightSafeSide = 100    'adjust this if necessary
            If DisplayRibbon Then
                If Application.CommandBars.Item("Ribbon").Height < RibbonHeightSafeSide Then
                    Application.CommandBars.ExecuteMso "MinimizeRibbon"
                    'or use send keys
                    'Application.SendKeys ("^{F1}")
                    DoEvents
            ElseIf Application.CommandBars.Item("Ribbon").Height > RibbonHeightSafeSide Then
                'or use send keys
                DoEvents
    To avod 'select':
         If Not IsMissing(c00) Then
            With Windows(c00)
                .DisplayHeadings = Not .DisplayHeadings
                .DisplayWorkbookTabs = Not .DisplayWorkbookTabs
                .DisplayGridlines = Not .DisplayGridlines
            Application.DisplayFormulaBar = Not Application.DisplayFormulaBar
    The 'Select' is necessary otherwise the arguments will work only for the first worksheet, if we pass more than 1 worksheet.
  1. Hide Ribbon, Gridlines, Heading and FormulaBar using VBA
    Last Post: 06-10-2013, 04:41 PM
  2. Populate Ribbon Controls On Load Dynamically Through VBA Variables
    By phxpoolplayer in forum Excel Ribbon and Add-Ins
    Last Post: 04-20-2013, 01:51 AM
  3. Minimize and Maximize option in Excel UserForm
    By shabbirtaibany in forum Excel Help
    Last Post: 09-23-2012, 07:05 PM
  4. How To Add A New Group In A Ribbon
    By Excel Fox in forum Excel Ribbon and Add-Ins
    Last Post: 09-16-2011, 07:57 AM
  5. Add ribbon programmatically to Excel 2010 using VBA
    By heapifyman in forum Excel Ribbon and Add-Ins
    Last Post: 07-18-2011, 09:16 PM
