Results 1 to 5 of 5
Thread: Count Colored Cells Using Excel Formula
    Mar 2013
    I want to count these cells colored by the formula without the code
    Why not a VBA code solution? Why are you looking for a formula based solution?
    Mar 2013
    Because I love formulas
    Is solved difficult formulas ?
    I've done something like this
    =COUNTIF(D2:L2;">"&$L$2)
    But I want the best from you
    The formula you've mentioned above gives the answer you are expecting. So is this question something that you want to do, or just curious to know if it is possible through formula.
    Mar 2013
    I want another way!
    Is there no other way better than this?
  1. Replies: 13
  2. Replies: 1
    Last Post: 12-04-2012, 05:30 PM
  3. Count consecutive value in a range using formula
    Last Post: 11-12-2012, 05:23 PM
  4. Count no of cells containing date
    Last Post: 04-16-2012, 10:37 PM
  5. Replies: 6
    Last Post: 09-26-2011, 07:39 AM
