Results 1 to 10 of 15
Thread: Format Function In VBA
    Member Transformer's Avatar
    Mar 2012
    Lightbulb Format Function In VBA
    UsefulGyaan Has Posted the Following On 07-02-2013 01:51 PM:
    Many times we encouter with such a situation when we have a “String” and from this string we need to fetch a value in fromat of *Date,Percentage,Currnecy,Fixed, Scientific,Yes/No,On/Off etc. Here comes the most used function of VBA, The “Format() Function”. Syntax: The syntax for Format() function is: Format(Expression,[Format]) Expression is the String which you have […]
    Function For Strings
    You mistakenly think format is designed for 'strings'. It isn't. It also applies to numbers (including date/times).
    The result of format is always a string.
    https://www.excelfox.com/forum/showthread.php/2918-Right-Hand-Side-Range-Range-Value-values-Range-Range-Value-only-sometimes-Range-Range-Value-Anomaly
    https://www.excelfox.com/forum/showthread.php/2355-Tests-and-Notes-on-Range-Referrencing/page8
    https://www.excelfox.com/forum/showthread.php/2355-Tests-and-Notes-on-Range-Referrencing?p=24006&viewfull=1#post24006
    https://www.excelfox.com/forum/showthread.php/2909-Appendix-Thread-Evaluate-Range-(-Codes-for-other-Threads-HTML-Tables-etc-)?p=23185&viewfull=1#post23185
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=UgzlC5LBazG6SMDP4nl4AaABAg
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=UgzlC5LBazG6SMDP4nl4AaABAg. 9zYoeePv8sZ9zYqog9KZ5B
    https://www.youtube.com/watch?v=jTmVtPHtiTg&lc=Ugy_RiNN_kAqUvZ8W994AaABAg. 9xhyRrsUUOM9zYlZPKdOpm
    https://www.youtube.com/watch?v=bs-urI_o8jo&lc=UgyBACXgNY4j_cHgH5J4AaABAg.9oTkVdzfqfm 9wlhQrYJP3M
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgxoHAw8RwR7VmyVBUt4AaABAg. 9C-br0lEl8V9xI0_6pCaR9
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=Ugz5DDCMqmHLeEjUU8t4AaABAg. 9bl7m03Onql9xI-ar3Z0ME
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgxYnpd9leriPmc8rPd4AaABAg. 9gdrYDocLIm9xI-2ZpVF-q
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgyjoPLjNeIAOMVH_u94AaABAg. 9id_Q3FO8Lp9xHyeYSuv1I
    https://www.youtube.com/watch?v=LP9fz2DCMBE&lc=UgzbPgJUMCztIOQDym14AaABAg. 9wdo_rWgxSH9wdpcYqrvp8
    Technically, the result of Format is a Variant with a sub-type of String. If you affix a $ sign after it, Format$, then it returns a pure String. By the way, this Variant/String result structure is true for all (at least I think it is all) the VBA String functions (such as Mid, Chr, Str, etc.) that return text values.
    Mar 2012
    Hi snb thanks for the feedback
    Actually Theodoulus decided to write it in parts....so this time he has written about Strings in future he will be writing about others.
    Regards,
    Transformer
    @Rick
    x3 = Format$(1234)
    results in the same kind of variable as Format(1234) (see the locals window).
    @Rick
    x3 = Format$(1234)
    Wow, either Google has gotten worse at finding stuff, or Microsoft pulled most of the non-VB.NET documentation, but it used to be much easier to find online documentation about the difference between VB/VBA functions with and without the $ sign. I did locate this from Microsoft's Office 2000 documentation, however...
    http://msdn.microsoft.com/en-us/libr...ffice.10).aspx
    ...see the second paragraph (starts with the word Note in bold letters).
    That text doesn't match the locals window in Excel's VBeditor.
    So MS has bugs in documentation too.
    I do not think that is true. The locals window says Variant/String which I believe means that the variable was declared as, or default to being, a Variant and it currently holds a String value... that says nothing about what Format or Format$ returned, only what ended up in the Variant variable in the end. Assigning a pure String value to a Variant won't convert the Variant to a String... it is still a Variant and that Variant currently contains a String value. For example, if you did this...
    x4 = "123"
    the locals window still reports Variant/String. Similarly, if you did this...
    x5 = CInt(123#)
    the locals window would say Variant/Integer meaning the variable was declared as, or defaulted to being, a Variant which currently holds an Integer value. The testing at the following link was for the compiled version of VB, so I do not know how convincing its result will be to you given we are talking about VBA within Excel, but I offer it to you to show that, at least originally, there was a difference between using the $ and leaving it off of String functions...
    Faster Visual Basic Programs
    Sub M_snb()
        Dim x00 As String, x01 As String, x02, x03
        x00 = Format(1234)
        x01 = Format$(1234)
        x02 = Format(1234)
        x03 = Format$(1234)
        x04 = Format(1234)
        x05 = Format$(1234)
        MsgBox VarType(x00) & vbTab & TypeName(x00) & vbLf & VarType(x01) & vbTab & TypeName(x01) & vbLf & VarType(x02) & vbTab & TypeName(x02) & vbLf & VarType(x03) & vbTab & TypeName(x03) & vbLf & VarType(x04) & vbTab & TypeName(x04) & vbLf & VarType(x05) & vbTab & TypeName(x05)
    In VBA at least any 'difference' is absent; see also the locals window.
    Of course in the local window only x00 and x01 are 'real 'strings'.
    Mar 2012
    Hi snb,
    There is a difference.Check the following code:
    Sub Test()
        Dim dteToday    As Date
        Dim strToday    As String
        dteToday = Format(Now())
        strToday = Format$(Now())
        MsgBox dteToday & vbTab & TypeName(dteToday) & vbNewLine & strToday & vbTab & TypeName(strToday)
    Regards,
    Transformer
  1. Replies: 3
    Last Post: 04-05-2013, 08:24 AM
  2. Programmatically format VBA buttons
    By Belleye in forum Excel Help
    Last Post: 09-25-2012, 11:18 AM
  3. Convert Text In YYYYMMDD Format To Date Format
    By S M C in forum Excel and VBA Tips and Tricks
    Last Post: 02-28-2012, 12:04 AM
  4. Replace Currency Format From One to Another at One go !! (VBA)
    Last Post: 07-19-2011, 09:13 PM
  5. Save File In CSV Format VBA
    By Raj Kumar in forum Excel Help
    Last Post: 06-01-2011, 07:22 AM
