Results 1 to 5 of 5
Thread: VBA code for my page causing Excel to Crash to desktop and restart
    Jun 2013
    Exclamation VBA code for my page causing Excel to Crash to desktop and restart
    I have opened a new question after people have helped me figure out how to get my first problem fixed, now I have a new problem. You will find the coding on the "INITIATING DEVICES" page below. The idea for the second to last part of the code was to add columns (text values) from B7:b and E7:E and display it on column J7:J. So if Photo is entered into B and Pass is entered into column E then the result will be Photopass in column J. The original code works fine if run via the macro command. The problem is that I tried to add it into some of my existing code and now the whole entire program will crash when information is entered into ANY cell. The program becomes unresponsive and then it shuts down and starts up again. I don't get a code or Debug message. Here is the entire code on the page.
        If Target.Column = 7 And UCase(Target.Value) = "YES" Then
            Sheets("MESSAGE CHANGES").Cells(Rows.Count, 1).End(xlUp)(2).Resize(, 3) = Sheets("INITIATING DEVICES").Cells(Target.Row, 1).Resize(, 3).Value
            Application.Goto Sheets("MESSAGE CHANGES").Cells(Rows.Count, 1).End(xlUp).Offset(, 3)
         If Target.Column = 6 And UCase(Target.Value) = "YES" Then
            Sheets("DEVICE NOTES").Cells(Rows.Count, 1).End(xlUp)(2).Resize(, 3) = Sheets("INITIATING DEVICES").Cells(Target.Row, 1).Resize(, 3).Value
            Application.Goto Sheets("DEVICE NOTES").Cells(Rows.Count, 1).End(xlUp).Offset(, 3)
         '(replace if new code fails)If Target.Column = 5 And UCase(Target.Value) = "FAIL" Or Target.Column = 5 And UCase(Target.Value) = "DAMAGED" Then
            '(replace if new codes fails)Sheets("FAILED DEVICES").Cells(Rows.Count, 1).End(xlUp)(2).Resize(, 3) = Sheets("INITIATING DEVICES").Cells(Target.Row, 1).Resize(, 3).Value
         If Target.Column = 5 And UCase(Target.Value) = "FAIL" Or UCase(Target.Value) = "DAMAGED" Then
            Application.EnableEvents = False
            Sheets("FAILED DEVICES").Cells(Rows.Count, 1).End(xlUp)(2).Resize(, 5) = Sheets("INITIATING DEVICES").Cells(Target.Row, 1).Resize(, 5).Value
            Sheets("FAILED DEVICES").Cells(Rows.Count, 1).End(xlUp).Offset(, 5) = Sheets("INITIATING DEVICES").Cells(Target.Row, 11).Value
            Application.EnableEvents = True
        'code that will place date/time when value is selcted in E
        If Not Intersect(Target, Range("E:E")) Is Nothing Then
           Range("I" & Target.Row).Value = Now
        Dim wb As Workbook
        Dim ws As Worksheet
        Dim lastRow As Long
        Set wb = ThisWorkbook
        Set ws = wb.Sheets("INITIATING DEVICES")
        lastRow = ws.Range("B" & ws.Rows.Count).End(xlUp).Row
        ws.Range("J7:J" & lastRow).Value = Evaluate("=B7:B" & lastRow & "&E7:E" & lastRow)
        Private Sub Workbook_BeforePrint(Cancel As Boolean)
        With Sheets("INITIATING DEVICES")
            .PageSetup.PrintArea = .Range("A1:H" & .Cells(Rows.Count, 1).End(xlUp).Row).Address
    Thank you for any help that you can give me, if you need anymore information I can send the inspection file and also offer more information if needed. I'm sure I messed something up and that's why it keeps crashing. Still learning here.
    I think your problem is you have your code in the Change event and that code is changing cells within the columns you are monitoring... than change by your code is kicking off the Change event again which makes another change to the same column thus kicking off the Change event again... this process goes on until Excel locks up or crashes. If I am right, you can solve your problem by putting this line of code as the first line of code in the Change event...
    and then putting this line of code as the last line of code in the Change event...
    I don't see this occurring in the code you posted, but for future information, if your code can raise an error so that you need an On Error statement of one kind or another, then make sure you execute the Application.EnableEvents=True statement before you let your error trap end the subroutine.
    Jun 2013
    Wow I'm lost, sorry so would I simply add that code to my page code above or does it have to go somewhere special. I would elaborate a little more but I'm replying from my phone so I can't look at the vba code at this second. I'm just confused as to what or where that code would go in my vba page code. Thanks I will look at the coding later when I get a second. I'm guessing I basically created a never ending loop then.
    Jun 2013
    Ok I'm stupid sorry, I figured out what the problem is and I found out where the code needed to be placed. So far it seems to be working.
    Jun 2013
    Ok so below is the modification that I used. You can see where I posted the codes per your recommendation. Now the interesting thing is that when I when I ran the code it seemed to work until I got down a couple of lines and then I got an error. I ran bebug and it flagged a line of my code.
    Now it seemed that after I tried to figure out what happened, and ended the debug session and then hit the button to re-run or enable my macros again (the button that exits break mode) none of the macros work again for this page. I checked to make sure break mode was exited but still nothing. I'm assuming it has something to do with where the code stopped or was flagged but im not sure what I did or what went wrong.
        Dim wb As Workbook
        Dim ws As Worksheet
        Dim lastRow As Long
        Set ws = wb.Sheets("Initiating Devices")
  1. Excel VBA Code to Add New Sheets
    By cdurfey in forum Excel Help
    Last Post: 06-25-2013, 08:05 AM
  2. VBA Code To Email Multiple Recipients From Excel
    Last Post: 06-11-2013, 12:18 AM
  3. Feed / Post Data on Web Page Using VBA
    By in.vaibhav in forum Excel Help
    Last Post: 01-10-2013, 05:00 PM
  4. Executing XLSM file on a web page
    Last Post: 12-17-2011, 05:38 AM
  5. Capture values from IE page
    By maruthi in forum Excel Help
    Last Post: 11-22-2011, 08:25 AM
