Results 1 to 5 of 5
Thread: Lock Cells After Data Entered
    Lightbulb Lock Cells After Data Entered
    Hi All,
    Here is VBA method to lock the cell after entering data in the cell.
    Dim blnUnlockedAllCells As Boolean
        Const RangeToLock As String = "A2:D1000" '<<  adjust to suit
        If Target.Cells.Count > 1 Then Exit Sub
        If Not blnUnlockedAllCells Then
            Me.Cells.Locked = False
            Me.Range(CStr(RangeToLock)).SpecialCells(2).Locked = True
            blnUnlockedAllCells = True
            Me.Protect Password:="pwd", userinterfaceonly:=True
        If Not Application.Intersect(Target, Me.Range(CStr(RangeToLock))) Is Nothing Then
            If Len(Target) Then Target.Locked = True
    Note: adjust the RangeToLock to suit. This code goes in the sheet module of the sheet in question.
    I hope this helps !
    Feb 2013
    The above code will fail as you don't unprotect the worksheet anywhere!
    Regards,
    Simon Lloyd
    Office Application Help
    Would fail on a worksheet, which is protected before applying the code. Once the code is applied, you don't need to unprotect the sheet since you are using userinteface=TRUE. And yes, I should have been mentioned that in my post
    Jun 2013
    Protected worksheet
    I only want to lock the cells that I enter data into. I have a protected worksheet and I do not want to unlock all cells. How do I modify the code to accomplish this?
    Mike
    If you do not have a specific range to lock, put A1:XFD1048576 in the variable RangeToLock.
  1. Select Group Of Cells Using Data Validation
    Last Post: 06-09-2013, 05:55 PM
  2. How To Lock Or Protect Cell Using Data Validation
    Last Post: 06-06-2013, 01:57 AM
  3. Replies: 4
    Last Post: 05-05-2013, 04:01 AM
  4. don't copy filtered data if no active cells
    By xander1981 in forum Excel Help
    Last Post: 11-01-2012, 06:47 PM
  5. Lock cells on the basis of date VBA
    Last Post: 09-27-2011, 03:56 PM
