Thread: Send Lotus Notes Email Using VBA
    Dear Experts,
    I have an excel sheet in cell "c9" i have mentioned one email adderss. When i click the click button the attahcment should be send to the Recipient mentioned in cell c9
    I am using lotus notes for mails. Request you to assist.
    Excel sheet is attached for your reference.
    Thanks in Advance,
    R.Ramakrishnan
    Hi Ramakrishnan,
    Welcome to ExcelFox !!
    I got this code from here
    Sub SendWithLotus()
        Dim noSession As Object, noDatabase As Object, noDocument As Object
        Dim obAttachment As Object, EmbedObject As Object
        Dim stSubject As Variant, stAttachment As String
        Dim vaRecipient As Variant, vaMsg As Variant
        Const EMBED_ATTACHMENT As Long = 1454
        Const stTitle As String = "Active workbook status"
        Const stMsg As String = "The active workbook must first be saved " & vbCrLf _
                & "before it can be sent as an attachment."
         'Check if the active workbook is saved or not
         'If the active workbook has not been saved at all.
        If Len(ActiveWorkbook.Path) = 0 Then
            MsgBox stMsg, vbInformation, stTitle
         'If the changes in the active workbook have been saved or not.
        If ActiveWorkbook.Saved = False Then
            If MsgBox("Do you want to save the changes before sending?", _
            vbYesNo + vbInformation, stTitle) = vbYes Then _
            ActiveWorkbook.Save
    '    'Get the name of the recipient from the user.
    '    Do
    '        vaRecipient = Application.InputBox( _
    '        Prompt:="Please add name of the recipient such as:" & vbCrLf _
    '        & "will@yahoo.co.uk or just the name if internal mail within Unity.", _
    '        Title:="Recipient", Type:=2)
    '    Loop While vaRecipient = ""
        vaRecipient = ThisWorkbook.Worksheets(1).Range("c9") '<<=== adjust to suit
         'If the user has canceled the operation.
    '    If vaRecipient = False Then Exit Sub
    '     'Get the message from the user.
    '    Do
    '        vaMsg = Application.InputBox( _
    '        Prompt:="Please enter the message such as:" & vbCrLf _
    '        & "Enclosed please find the weekly report.", _
    '        Title:="Message", Type:=2)
    '    Loop While vaMsg = ""
    '     'If the user has canceled the operation.
    '    If vaMsg = False Then Exit Sub
         'Add the subject to the outgoing e-mail
         'which also can be retrieved from the users
         'in a similar way as above.
        Do
            stSubject = Application.InputBox( _
            Prompt:="Please add a subject such as:" & vbCrLf _
            & "Weekly Report.", _
            Title:="Subject", Type:=2)
        Loop While stSubject = ""
         'Retrieve the path and filename of the active workbook.
        stAttachment = ActiveWorkbook.FullName
         'Instantiate the Lotus Notes COM's Objects.
        Set noSession = CreateObject("Notes.NotesSession")
        Set noDatabase = noSession.GETDATABASE("", "")
         'If Lotus Notes is not open then open the mail-part of it.
        If noDatabase.IsOpen = False Then noDatabase.OPENMAIL
         'Create the e-mail and the attachment.
        Set noDocument = noDatabase.CreateDocument
        Set obAttachment = noDocument.CreateRichTextItem("stAttachment")
        Set EmbedObject = obAttachment.EmbedObject(EMBED_ATTACHMENT, "", stAttachment)
         'Add values to the created e-mail main properties.
        With noDocument
            .Form = "Memo"
            .SendTo = vaRecipient
            .Subject = stSubject
            .Body = vaMsg
            .SaveMessageOnSend = True
         'Send the e-mail.
        With noDocument
            .PostedDate = Now()
            .Send 0, vaRecipient
         'Release objects from the memory.
        Set EmbedObject = Nothing
        Set obAttachment = Nothing
        Set noDocument = Nothing
        Set noDatabase = Nothing
        Set noSession = Nothing
         'Activate Excel for the user.
        AppActivate "Microsoft Excel"
        MsgBox "The e-mail has successfully been created and distributed.", vbInformation
  1. Replies: 17
    Last Post: 07-15-2013, 09:56 PM
    Last Post: 05-23-2013, 08:08 AM
  3. How To Send Outlook Email Using VBA
    By mfaisalrazzak in forum Excel Help
    Last Post: 03-03-2013, 03:09 AM
  4. how to send each row by email
    By BARIS in forum Excel Help
    Last Post: 09-19-2012, 09:42 PM
  5. Send Outlook Email With Word Document
    By Murali K in forum Excel Help
    Last Post: 06-27-2012, 08:42 PM
