Results 1 to 10 of 11
Thread: VBA Macro To Fill Missing Items In A Sequence Of Values Based On Criteria
    Aug 2013
    I am trying to change the cells in my spreadsheet and created a macro but it is not working quite right. I had to update this because I confused the person that responded and hope other will view this because my macro is still not working. I might have to repost. There are blanks between the data have. So, I need to read the first item and change that cell as well as the following cells until I reach the next item. If that item is like, it will continue. If not, then it will paste the other label and fill in the blanks with that until it gets to the next. There are only 2. I hope this makes sense.
    Macro
    'macro ten
    'implant update
    Sub imptype()
    Dim c As Range
    For Each c In Range("J1:J" & Range("J" & Rows.Count).End(xlUp).Row)
        c = IIf(UCase(c) = "AIP", "Implant Pass-through: Auto Invoice Pricing (AIP)", "Implant Pass-through: PPR Tied to Invoice")
    DATA Have
    AIP
    Standard
    AIP
    Standard
    AIP
    DATA Need
    Jun 2013
    your code works well on my test sheet
    Aug 2013
    It is not working for me. It labels everything as Implant Pass-through: PPR Tied to Invoice
    Apr 2012
    This appears to be an Excel issue, but you have posted in the Access Forum. Is this in fact an excel issue? What is your issue? What results are you getting? It appears that you are using the syntax for Access which is IIF versus the syntax for Excel which is IF.
    Moderator
    Jul 2012
    @ alansidman
    IIf is in fact an XL-function. It's a sort of short version of If...Then...Else. It has 3 parts (expr,truepart,falsepart)
    In the 1st you evaluate a certain expression, if true returns truepart, if false it returns falsepart.
    F.e.
    Sub tst()
        MsgBox IIf(1 < 2, "Yes", "No")
        MsgBox IIf(2 < 1, "Yes", "No")
    Another option
    Sub imptype()
        Dim c   As Range
        Dim a   As String
        Set c = Range("J1:J" & Range("J" & Rows.Count).End(xlUp).Row)
        a = c.Address
        c = Evaluate("=if(" & a & "=""aip"",""Implant Pass-through: Auto Invoice Pricing (AIP)"",""Implant Pass-through: PPR Tied to Invoice"")")
    Here are two more options... the first one is mostly to show yet another alternative, but I seriously doubt you will find a faster method than the second one.
    ' Interesting alternative
    Sub ImpType1()
      With Range("J1:J" & Cells(Rows.Count, "J").End(xlUp).Row)
        .Replace "AIP", "=AIP", xlWhole
        .SpecialCells(xlConstants).Clear
        .SpecialCells(xlBlanks).Value = "Implant Pass-through: PPR Tied to Invoice"
        .SpecialCells(xlFormulas).Value = "Implant Pass-through: Auto Invoice Pricing (AIP)"
    ' Super fast method
    Sub ImpType2()
      Dim X As Long, vArr As Variant
      vArr = Range("J1:J" & Cells(Rows.Count, "J").End(xlUp).Row)
      For X = 1 To UBound(vArr)
        If vArr(X, 1) = "AIP" Then
          vArr(X, 1) = "Implant Pass-through: Auto Invoice Pricing (AIP)"
          vArr(X, 1) = "Implant Pass-through: PPR Tied to Invoice"
      Range("J1:J" & Cells(Rows.Count, "J").End(xlUp).Row) = vArr
    Just to clarify on the point about IIF (also known as the Immediate If) versus If...Else...End If
    IIF has to evaluate the entire function before returning a result whether the TRUE part or the FALSE part. If the following code is tested, you'll easily figure it out
    Sub IIFVsIFTest()
        Dim lng As Long
        lng = 0
        MsgBox IIf(lng = 0, "Please do not use zero", 1 / lng) 'Throws division by zero error
        If lng = 0 Then
            MsgBox "Please do not use zero"
            MsgBox 1 / lng
    So for posterity, IIF and If...Else...End If cannot be substitutes for each other, unless the developer clearly knows what the code does
    Aug 2013
    Ok, these options somewhat work. But, I guess I am not explaining the data have correctly. I have either AIP or Standard and then blank cells in between. So, if I have AIP on J1 and then Standard on J15, the Implant Pass-through: Auto Invoice Pricing (AIP) needs to be on J1 through J14. If the Standard is J15 and the next AIP is J20, then Implant Pass-through: PPR Tied to Invoice needs to be J15 to J19 and so on.
    This is because there are other items in this Excel. I have the claim number, component information. So the full raw data would be like this:
    clm component manu imptype
    111 xyxy xyxy AIP
    111 2222 djrkf
    111 jones johnson
    111 xyxy fjklda
    222 fjdk fjdskl Standard
    222 fjsk fjdksal
    222 fjsdk fdwjkf
    333 fjk fjklas AIP
    333 fsdjkl fjksla
    444 fjk fjdsk AIP
    444 fjdskl djak
    555 jk jjkl AIP
    555 jkl jlj
    666 jk jklj Standard
    666 jk jkljl
    So, claim 111 is all an AIP claim and I need it to fill the correct AIP wording. Claim 222 is a standard and that needs to be filled in. claim 333, 444, 555, 666 and so on works the same.
    Apr 2012
    @excel fox and bakerman
    Thanks for the explanation on the differences. Great to learn new stuff!
  1. Replies: 1
    Last Post: 08-20-2013, 04:31 PM
  2. Replies: 4
    Last Post: 04-05-2013, 12:08 PM
  3. Sum values based on multiple criteria
    By Jorrg1 in forum Excel Help
    Last Post: 01-07-2013, 03:04 PM
  4. Macro to clear data based on color fill
    Last Post: 12-03-2012, 09:25 AM
  5. Fetch multiple values based on criteria
    By Lucero in forum Excel Help
    Last Post: 04-07-2012, 12:35 PM
