My guess the best option would be to put them in 1 frame so you select either one of them. Otherwise you should put an extra button to enable both frames when you change your mind.
or give them the same 'groupname'
I did have a version where I placed all in the 1 frame...I am stilling working on it but it does work on some features.The issues I am having is if I select Internal and its selections from the combobox`s it works as it renders External combobox`s disabled.If i then change to External is keeps the selections in the combobox`s also from Internal so it ends up transferring both Internal and External combobox`s......if I select Internal and its combobox`s only it works fine......same for External
I also have userform Production and Planned Stop now working
How do I give the same Groupname.....is this in properties?
Combobox issue resolved.
Thanks bakerman
Works....if i select Internal or External can the Time textbox`s also be disabled (entry deleted) on the 1 not selected.
If changing from say Internal to External it removes the entries in the Combobox`s but not the Textbox.......i will attempt to resolve this so would i need to add code in the Optionbutton4 and 5 parts of the code
Thanks again
Try it this way.
Code:Private Sub OptionButton4_Click() For i = 2 To 6 With Me("Combobox" & i) .Value = vbNullString .Enabled = IIf(i <= 4, True, False) End With If i = 2 Or i = 3 Then With Me("Textbox" & i) .Text = vbNullString .Enabled = IIf(i = 2, True, False) End With End If Next End Sub Private Sub OptionButton5_Click() For i = 2 To 6 With Me("Combobox" & i) .Value = vbNullString .Enabled = IIf(i <= 4, False, True) End With If i = 2 Or i = 3 Then With Me("Textbox" & i) .Text = vbNullString .Enabled = IIf(i <> 3, False, True) End With End If Next End Sub
Thanks for all your help bakerman...the code above worked
I did find 2 errors...i used the Tag property in the userform for the Combobox`s and Textbox`s and they work...i used the Tag Property for the Optionbuttons for XFLOW A+B+C also but if i transfer the userform without selecting XFLOW A or B or C it gives a Runtime error...i thought the Tag property would stop this error...
Also if i do not select External or Internal i can then select all the Combobox`s and Textbox`s in the frame......is there a way to force either Internal or External to be selected
Paul
1) Remove the Tags from XFLOW A+B+C and put next code on top of CommandButton1_Click.
2) In designmode set the Enabled-property of the CB's and both TB's to False.Code:For Each ctl In Frame1.Controls If TypeName(ctl) = "OptionButton" Then If ctl.Value = False Then x = x + 1 End If Next If x = 3 Then MsgBox "Select a machine before you write data": Exit Sub
Thanks bakerman
Added the code (possibly in the wrong place) and set the Enabled-property of the CB's and both TB's to False
If i select date and machine and press Transfer Button it messagebox says "Select a Part"...i press OK and it give a Runtime Error 2110.....
Could this be where i placed the code as you mentioned on top of CommandButton1_Click...i could not get it to place above the CommandButton1_Click which may cause the error
Thanks again
Change this line
to this lineCode:If ctl.Value = vbNullString Then MsgBox ctl.Tag: ctl.SetFocus: Exit Sub
The error occured because you can't set focus to a disabled object.Code:If ctl.Value = vbNullString Then MsgBox ctl.Tag: Exit Sub
