Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Insert Missing Dates By Comparing Two Lists Of Dates
    Mar 2013
    hi Welcome Please, I want to compare the two columns in terms of date, such as the existing columns
    Nov 2011
    Hi Lee,
    Can you please explain it bit more, what exactly you want.
    Mar 2013
    I hope this will be explained
    Mar 2013
    This file may be explained
    Aug 2013
    Hi mahmoud-lee,
    This is much harder than it seems - well it was for me anyway (took me nearly 3 days on and off).
    Anyway, let us know how this goes (hopefully good as it works for me):
    Sub Macro1()
        'Written by Trebor76
        'Visit my website www.excelguru.net.au
        'Match the dates in Col's D and E and output them to Col's L and M respectively.
        'http://www.excelfox.com/forum/f2/compare-between-two-dates-1497/
        Const lngStartRow As Long = 4 'Starting row number for the data. Change to suit.
        Dim objMyUniqueList As Object
        Dim strMyArray() As String
        Dim lngArrayCount As Long
        Dim lngEndRow As Long
        Dim lngListARow As Long, _
            lngListBRow As Long
        Dim rngCell As Range
        Dim dteMyDate As Date
        Dim varUniqueItem As Variant
        Dim lngMatchCount As Long
        Set objMyUniqueList = CreateObject("Scripting.Dictionary")
        lngEndRow = Range("D:E").Find("*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row
        'Create an unique array of dates from both columns.
        For Each rngCell In Range("D" & lngStartRow & ":E" & lngEndRow)
            If Len(rngCell) > 0 And IsDate(rngCell) = True Then
                dteMyDate = CDate(rngCell)
                If Not objMyUniqueList.Exists(dteMyDate) Then
                    objMyUniqueList.Add dteMyDate, dteMyDate
                    lngArrayCount = lngArrayCount + 1
                    ReDim Preserve strMyArray(1 To lngArrayCount)
                    strMyArray(lngArrayCount) = Format(dteMyDate, "yyyymmdd") 'Best format for sorting.
        Next rngCell
        'Need to sort the array in ascending sequence.
        'This nifty code was written by Hans Vogelaar MCC, MVP and is sourced from here: _
        'http://social.msdn.microsoft.com/Forums/en-US/830b42cf-8c97-4aaf-b34b-d860773281f7/sorting-an-array-in-vba-without-excel-function?forum=isvvba
        Call BubbleSort(strMyArray)
        'Initialise the 'lngListARow' and 'lngListBRow' variables to the 'lngStartRow' constant variable.
        lngListARow = lngStartRow: lngListBRow = lngStartRow
        For Each varUniqueItem In strMyArray()
            '**Note the 'dteMyDate' variable here must be in the same format (i.e. with dashes or slashes) as the dates are formatted within the cells**
            'Toggle through the unique dates and, using the COUNTIF function, output however many are required from Col. D into Col. L.
            dteMyDate = CDate(Mid(varUniqueItem, 5, 2) & "-" & Right(varUniqueItem, 2) & "-" & Left(varUniqueItem, 4))
            If Evaluate("COUNTIF($D$" & lngStartRow & ":$D$" & lngEndRow & ",""" & Format(dteMyDate, "d-mmm-yyyy") & """)") > 0 Then
                For lngMatchCount = 1 To Evaluate("COUNTIF($D$" & lngStartRow & ":$D$" & lngEndRow & ",""" & Format(dteMyDate, "d-mmm-yyyy") & """)")
                    Cells(lngListARow, "L") = Format(CDate(dteMyDate), "mm/dd/yyyy") 'Output format can be changed here if desired.
                    lngListARow = lngListARow + 1
                Next lngMatchCount
            'Toggle through the unique dates and, using the COUNTIF function, output however many are required from Col. E into Col. M.
            If Evaluate("COUNTIF($E$" & lngStartRow & ":$E$" & lngEndRow & ",""" & Format(dteMyDate, "d-mmm-yyyy") & """)") > 0 Then
                For lngMatchCount = 1 To Evaluate("COUNTIF($E$" & lngStartRow & ":$E$" & lngEndRow & ",""" & Format(dteMyDate, "d-mmm-yyyy") & """)")
                    Cells(lngListBRow, "M") = Format(CDate(dteMyDate), "mm/dd/yyyy") 'Output format can be changed here if desired.
                    lngListBRow = lngListBRow + 1
                Next lngMatchCount
            'Get the two output row numbers in sync.
            If lngListARow > lngListBRow Then
                lngListBRow = lngListARow
            ElseIf lngListBRow > lngListARow Then
                lngListARow = lngListBRow
        Next varUniqueItem
        'Remove objects from memory
        Set objMyUniqueList = Nothing
        Erase strMyArray()
        MsgBox "The dates in columns D and E have matched to columns L and M.", vbInformation, "Excel Guru"
    Sub BubbleSort(arr)
        Dim strTemp As String
        Dim i As Long
        Dim j As Long
        Dim lngMin As Long
        Dim lngMax As Long
        lngMin = LBound(arr)
        lngMax = UBound(arr)
        For i = lngMin To lngMax - 1
            For j = i + 1 To lngMax
              If arr(i) > arr(j) Then
                strTemp = arr(i)
                arr(i) = arr(j)
                arr(j) = strTemp
            Next j
      Next i
    Regards,
    Robert
    Mar 2013
    I am unfortunately not the required solution
    I want it like this solution and I hope by the formula
    Why is 2nd and 3rd January missing in first column?
    Mar 2013
    Nothing
    But I mean, any date that does not exist in the corresponding column writing (0) in the corresponding date
    But when it is writing again ...... etc.
    Because it is a comparison between columns (1) & (2)
    I want them to like 3, 4
    What do you mean nothing?
    All the attachments you are uploading are exactly the same, and you are not proving anything that way. My question is, why is 2nd and 3rd January missing in your final output?
    If that was a mistake from your part, then try this code
    Sub ExcelFox()
        Dim lng As Long:    lng = 4
        While Not (IsEmpty(Range("D" & lng).Value) Or IsEmpty(Range("E" & lng).Value))
            If Range("D" & lng).Value > Range("E" & lng).Value Then
                Range("D" & lng).Insert xlDown
            ElseIf Range("D" & lng).Value < Range("E" & lng).Value Then
                Range("E" & lng).Insert xlDown
            lng = lng + 1
        Wend
    Mar 2013
    I am very sorry
    But I want to convert columns (1) & (2)
    Such as columns (3) & (4)
    It remains Columns (1) & (2)
    I wish formulas and not code
  1. List of Dates In DropDown Starting From Today()
    Last Post: 04-10-2013, 05:58 PM
  2. Replies: 4
    Last Post: 04-05-2013, 12:08 PM
  3. How to Extracting dates and days between 2 dates.
    Last Post: 08-11-2012, 09:11 PM
  5. Visual Plotter basis given dates and activity
    Last Post: 03-07-2012, 02:37 PM
