Results 1 to 10 of 13
Thread: Highlight Data Based on Data in Another Column
    Jan 2014
    How can I highlight data based on another cell in the same row?
    Ex. I only want to Select data in Column C only if Column B = Rm2
    A B C D
    1 Bob Rm1 x 0
    2 Jack Rm1 x 0
    3 Dean Rm2 n 0
    4 John Rm2 n 0
    5 Barb Rm3 x 0
    Jan 2014
    I asked the wrong question
    How can I Select data based on another cell in the same row?
    Ex. I only want to Select data in Column C & D only if Column B = Rm2. I will be doing a find and replace after the info has been selected. I will be using this in a macro.
    A B C D
    1 Bob Rm1 x 0
    2 Jack Rm1 x 0
    3 Dean Rm2 n 0
    4 John Rm2 n 0
    5 Barb Rm3 x 0
    We can select Column C & D based on Column B with the help of find method in VBA but what next.
    Jan 2014
    I only need to select the data in Columns C and D where Column B equals the room number chosen.
    So for this example for Rm1, I only need to Select the information in Columns C and D in rows 1 and 2.
    If I needed to select Columns C and D for Rm2, I only need to Select the information in Columns C and D in rows 3 and 4.
    The macro would almost work like conditional formatting where the data would be highlighted based on a condition in the row.
    I hope I explained it better.
    Jan 2014
    A B C D
    Bob Rm1 x 0
    Jack Rm1 x 0
    Dean Rm2 n 0
    John Rm2 n 0
    Barb Rm3 x 0
    I only want to select the data in Columns C and D where the Rm# in each of the rows of data = Rm1
    Example:
    Premise: If I wanted to select the data from Column C and D with Column B = Rm1
    Solution: I would select Columns C and D in rows 1 and 2.
    I'm going to replace the x in Column C with "n/a" and the 0 in Column D with "j/k"
    Moderator
    Jul 2012
    You state that you want to perform a Find & Replace with selected items.
    If you can explain a little more what you want to replace the selected items with you can perform this in 1 action so there's no need to really select them first.
    Moderator
    Jul 2012
    We can start with this one.
    Sub FindReplace()
        FindNr = InputBox("Roomnumber to search", "Replace data")
        With Sheets("Sheet1")
            For Each cl In .Range("B1:B" & .Cells(Rows.Count, 2).End(xlUp).Row)
                If cl.Value = FindNr Then
                    cl.Offset(, 1) = IIf(cl.Offset(, 1).Value = "x", "n/a", cl.Offset(, 1).Value)
                    cl.Offset(, 2) = IIf(cl.Offset(, 2).Value = 0, "j/k", cl.Offset(, 2).Value)
    Jan 2014
    This code for Sub FindReplace() worked in the attached document.
    Sub FindReplace()
    Is there anyway to use a different tab (Containing a Location and Room #), within the same workbook, to Use instead of the InputBox. So Instead of having to put a Room # in the input box, is there a way to specify a Location (In a particular Cell) and pull the Room # from the TableTab? Then use the Room # pulled (from the table) run the Find and Replace macro?
    Jan 2014
    This code for Sub FindReplace() worked.
    Moderator
    Jul 2012
    Post a new example file which represents the current situation.
    Be sure to explain exactly where what is to be found, which cell to be used to specify location, etc...
    The more information you provide the better we can help you.
  1. Replies: 34
    Last Post: 03-13-2015, 02:26 PM
  2. Replies: 10
    Last Post: 02-18-2014, 01:34 PM
  3. Group And Transpose Data Based On Sections of Data
    By theladysaphir in forum Excel Help
    Last Post: 06-28-2013, 07:55 AM
  4. Replies: 17
    Last Post: 05-22-2013, 11:58 PM
  5. Group Pivot Data Based On Row Values In One Column
    Last Post: 10-09-2012, 11:46 PM
