Results 1 to 10 of 10
Thread: Extract, Transpose and Fill automation in a survey
    Jan 2014
    Dear friends,
    With the help of fellow forum colleagues I managed to convert the output of a 300 people Google survey to something processable in Excel. Essentially, transforming the layout of the "per-row" output into a "per-column" table that I can Pivot or analyze afterwards.
    But I cannot complete a piece of the layout without your help.
    I've attached a sample of the survey (just 2 people/34 questions due to file size limits in this forum) and explained what I need within the spreadsheet.
    In a nutshell, I need to make 4 new columns, copy the values of the last 4 questions of each respondent to the corresponding column and fill the rest of the column down until the next respondent values begin.
    This is because this last four questions hold demographic data (Job post, Area, Years in the job, Comments) that I will need to group the respondent answers when I process them in a pivot table or statistical package.
    Welcome to board!!
    Insert a standard module and put the code there. Adjust the range wherever necessary.
    Sub kTest()
        Dim Data, i As Long, n As Long, c As Long, dic As Object
        Dim arrOutput(), List, v, ShtOutput As Worksheet
        Set dic = CreateObject("scripting.dictionary")
            dic.comparemode = 1
        Data = Worksheets("form responses").Range("a1").CurrentRegion.Resize(, 35).Value2
        List = Worksheets("sheet2").Range("a7:g40").Value2 '<< adjust this range
        For i = 1 To UBound(List, 1)
            dic.Item(List(i, 1)) = Array(List(i, 7), List(i, 2))
        ReDim arrOutput(1 To UBound(Data, 2) * 34, 1 To 10)
        For i = 2 To UBound(Data, 1)
            For c = 2 To UBound(Data, 2) - 4
                n = n + 1
                arrOutput(n, 1) = Data(i, 1)
                arrOutput(n, 2) = c - 1
                arrOutput(n, 3) = Data(i, c)
                arrOutput(n, 4) = Evaluate("=LOOKUP(""" & Left$(Data(i, c), 1) & """,{""a"",1;""b"",2;""c"",3;""d"",4;""e"",5;""f"",0})")
                v = dic.Item(c - 1)
                arrOutput(n, 5) = v(0)
                arrOutput(n, 6) = v(1)
                arrOutput(n, 7) = Data(i, 32)
                arrOutput(n, 8) = Data(i, 33)
                arrOutput(n, 9) = Data(i, 34)
                arrOutput(n, 10) = Data(i, 35)
        Set ShtOutput = Worksheets("Output")
        If Err.Number <> 0 Then
            Set ShtOutput = Worksheets.Add
            ShtOutput.Name = "Output"
        Err.Clear: On Error GoTo 0
        With ShtOutput
            .Range("a1:j1") = [{"Nombre","Pregunta","Respuesta","Valor","Clasificacion","Tema","Puesto","Area","Antigüedad","Comentario"}]
            .Range("a2").Resize(n, 10).Value2 = arrOutput
    Jan 2014
    Wow! That was fast! I included the code in my Personal.xlsb sheet and run it on the file I sent to you. I stops at an error message that I uploaded in this message:"subscript out of range". I also included the debug screen.
    I was trying the understand the logic and it is still challenging for me to decipher some of the limits of the variables or arrays (i, c, n, etc.). I understand, for example, that in the line:"List = Worksheets("sheet2").Range("a7:g40").Value2 '<< adjust this range", as far as the data is in the exact same range as you saw in my file, it's ok. Right?
    Anyway, I'm most hopeful I will tackle this survey processing and if you would like to assist me a bit more I'd be most grateful.
    Survey
    Hey "Renczi" Your survey related discussion really very important. Actually If you need any useful data about the survey so you can communication with us.
    iReward Survey provides rewards at the end of the path, including offers for paid surveys, cash prizes, contests, cheap stuff, games, sweepstakes, and more. Complete the entire survey with valid answers to claim your rewards.
    Jan 2014
    Quote Originally Posted by johnabrahaml View Post
    Not sure if you need me to do something else.
    If you are running this code from the Personal.xlsb, try this version.
    Sub kTest()
            dic.comparemode = 1
        Data = ActiveWorkbook.Worksheets("form responses").Range("a1").CurrentRegion.Resize(, 35).Value2
        List = ActiveWorkbook.Worksheets("sheet2").Range("a7:g40").Value2 '<< adjust this range
        ReDim arrOutput(1 To UBound(Data, 2) * 35, 1 To 10)
                n = n + 1
                v = dic.Item(c - 1)
        Set ShtOutput = ActiveWorkbook.Worksheets("Output")
            Set ShtOutput = ActiveWorkbook.Worksheets.Add
        With ShtOutput
            .Range("a2").Resize(n, 10).WrapText = False
    Jan 2014
    Success! I attached the worksheet in case you find it useful for something else. Thank you so much!
    Jan 2014
    Hi there! Despite my happiness in my previous mail, when I came to process the actual survey data (147 rows, 35 columns) I got a "subscript out of range" message that I couldn´t decipher.
    I managed to attach my spreadsheet and a screen capture of the debug page in vba.
    I would greatly appreciate your help to figure out what's going on.
    Best regards.
    Replace
    with
    ReDim arrOutput(1 To UBound(Data, 1) * 35, 1 To 10)
    Jan 2014
    Now it did the job! You just helped me be on track with my task. Deeply grateful!
  1. RefersTo:=Range [transpose(..)]
    By PcMax in forum Excel Help
    Last Post: 02-06-2014, 04:41 AM
  2. Transpose A Column Of Data In To A Table
    By gunjan.nasit in forum Excel Help
    Last Post: 05-20-2013, 12:33 AM
  3. Unable to Get ElementID In VBA IE Automation
    By ashu1990 in forum Excel Help
    Last Post: 03-28-2013, 11:58 AM
  4. VBA IE Internet Explorer Automation Through ElementID
    Last Post: 01-22-2013, 06:20 AM
  5. Transpose data into Rows
    By vikash200418 in forum Excel Help
    Last Post: 04-10-2012, 11:02 PM
