Thread: Generate random numbers in Excel
    Jul 2011
    i am looking to generate random numbers in excel.
    Step :
    1. Select the Range
    2. Input box will ask From Number; To Number
    3. when i click on ok it will generate random numbers within selected range if possible they should be unique
    reference : http://www.ablebits.com/excel-random...dins/index.php
    http://www.ozgrid.com/VBA/RandomNumbers.htm
    i will appreciate any help on this
    Sub GenerateRandomNumbers()
        Dim lngFrom As Long, lngTo As Long
        Dim rng As Range
        lngFrom = InputBox("Enter from value")
        lngTo = InputBox("Enter to value. Should be greater than " & lngFrom)
        For Each rng In Selection 'Will error out if selection is not a range
            rng.Value = GETRANDBETWEEN(lngFrom, lngTo)
        Next rng
    Function GETRANDBETWEEN(lngFrom As Long, lngTo As Long)
        GETRANDBETWEEN = lngFrom + Int(Rnd() * (lngTo - lngFrom + 1))
    You could always use =RANDBETWEEN() in Excel 2007 and greater, in which case you could modify the function to
        GETRANDBETWEEN = Application.RandBetween(lngFrom, lngTo)
    Jul 2011
    Thank u so much Kris !
    Really appreciate your knowledge & help
  1. Get Random List :
  2. VBA Code to Generate Events at Specific frequency
    By ChiswickBridge in forum Excel Help
    Last Post: 02-11-2013, 08:20 AM
  3. Replies: 2
    Last Post: 12-04-2012, 06:09 PM
  4. Replies: 1
    Last Post: 12-04-2012, 05:30 PM
  5. Random Unique Number Generator Excel VBA
    Last Post: 10-18-2012, 01:00 PM
