Results 1 to 9 of 9
Thread: Removing Particular value from a Drop Drown form control using VBA
    I need a code which removes a particular value from the Drop Down (Form Control) using VBA.
    Actually the condition is when the Drop Drown fill first time there is a value which is "Select Value" in the first
    position
    Whenever a user select any value from the Drop Down then this value should be Removed so the user can not select this
    value again.
    And after removing this value the index should be Reindex.
    It will a great help for me
    Thanx in Advance.
    :o
    Worksheets("Sheet1").DropDowns("NameOfDropDown").RemoveItem 1
    Thanx for giving me ur time from ur busy schedule.
    I applied this but its not working for me. I don't know what i am doing wrong.
    Have you changed the sheet name and dropdown name as required?
    Yaa,
    but it gives some error. and this command which you wrote is for Form Control(does'nt mean that i am creating user forms i placed the control in a sheet)
    I really need it
    Thanx.
    I have used the same code in the attachment
    Its Gives me
    Run-Time Error '1004'
    RemoveItem method of DropDown class failed
    Error when i am writing the same in my excel file.
    I am filling this List Box by a namedrange.
    You cannot have the listfill range and expect to remove an item from the list!! Instead of having the listfill through a range, why don't you add each item. Then you will also be able to remove item
    Yup Now its working.....
    Thanx
  1. Replies: 1
    Last Post: 05-03-2013, 04:41 PM
  2. Removing unused Cell styles - need an efficient code
    By siddharthsindhwani in forum Excel Help
    Last Post: 04-15-2013, 07:12 AM
  3. Creating drop-down function in excel
    By Jorrg1 in forum Excel Help
    Last Post: 01-09-2013, 01:45 PM
  4. ScrollBar Not Aligned In MultiPage Form VBA
    By Tony in forum Excel Help
    Last Post: 10-31-2012, 11:43 PM
  5. Animation on Form Control
    By Mechanic in forum Excel Help
    Last Post: 03-22-2011, 08:56 AM
