Hi Frineds,
My macro is not working, i need to apply filter thur message box and delete after the given date rows.I have attached the macro sheet for your reference .
Kindly help to correct the same.
Regards,
Prabhu
Hi Frineds,
Regards,
Prabhu
Try this:
Code:Sub MYFILTER() Dim W1Startdate As Date W1Startdate = InputBox("Please Enter the Start Data in DD/MM/YYYY format") range("A2:T" & range("A1").End(xlDown).Row).AutoFilter Field:=7, Criteria1:=">" & W1Startdate 'range("A4:T" & range("A2").End(xlDown).Row).SpecialCells(12).EntireRow.Delete End Sub
Did you debug your code first? http://www.cpearson.com/excel/DebuggingVBA.aspx
Like my answer? Click * below
Database Normalization
Database Principles
Pivot Table Tips
Excel Video Tutorials
SumProduct Video Tutorial
DataPig Access Tutorials
MS Query Tutorial
SQL Tutorial
I tried, but it is not deleting the record after the given date. i.e it is struck on the filter.
Kindly helpCode:Sub MYFILTER() Dim W1Startdate As Date W1Startdate = InputBox("Please Enter the Start Data in DD/MM/YYYY format") range("A2:T" & range("A1").End(xlDown).Row).AutoFilter Field:=7, Criteria1:=">" & W1Startdate range("A3:T" & range("A2").End(xlDown).Row).SpecialCells(12).EntireRow.Delete End Sub
Try this:
Code:Option Explicit Sub NewDelete() Dim W1Startdate As Date W1Startdate = InputBox("Please Enter the Start Data in DD/MM/YYYY format") Dim lr As Long lr = Range("G" & Rows.Count).End(xlUp).Row Dim i As Long Application.ScreenUpdating = False For i = lr To 3 Step -1 If Range("G" & i) >= W1Startdate Then Range("G" & i).EntireRow.Delete End If Next i Application.ScreenUpdating = True MsgBox "task complete" End Sub
Please use code tags when posting VBA Code in the forum. It makes for easier reading and is a forum standard.
Database Principles
Pivot Table Tips
MS Query Tutorial
SQL Tutorial
Thanks it is working!
But it is taking huge amount of time when we delete larger data. i think it is deleting row by row.
can we make change to delete the enter in one short now like deleting manually?
Try
Code:Sub MYFILTER() Dim W1Startdate As String Dim dtFilter As Date W1Startdate = Application.InputBox("Please Enter the Start Data in DD/MM/YYYY format", Type:=2) If W1Startdate = "False" Then Exit Sub If IsNumeric(Replace(W1Startdate, "/", vbNullString)) Then dtFilter = DateSerial(Split(W1Startdate, "/")(2), Split(W1Startdate, "/")(1), Split(W1Startdate, "/")(0)) Range("A2:T" & Range("A1").End(xlDown).Row).AutoFilter Field:=7, Criteria1:=">" & dtFilter Range("A3:T" & Range("A2").End(xlDown).Row).SpecialCells(12).EntireRow.Delete If ActiveSheet.AutoFilterMode Then ActiveSheet.AutoFilterMode = False End If End Sub
No Sir,
It is not deleting.
Any error ? how many rows of data you have ?
I found 2 issues:
1.It is taking MM/DD/YYYY instead of DD/MM/YYYY.
2. If the input dates between 1- 10 example 08/10/2014(10th Aug 2014) it is deleting correctly but the input dates between 11-31 example 08/15/2014 it is not taking any action.
I have attached the data for your reference. Kindly help to correct the same.
Regards,
Prabhu
It's working here. You need to enter the date in dd/mm/yyyy format.
