Results 1 to 10 of 11
Thread: Left and Right Mouse Click Event
    Oct 2011
    Yes you can using
    Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
        Cancel = True
        MsgBox "Double-Clicked"
    OR
    Private Sub Worksheet_BeforeRightClick(ByVal Target As Range, Cancel As Boolean)
        Cancel = True
        MsgBox "Right-Clicked"
    Oct 2011
    Hallo
    Let's analyze:
        Cancel = True
    In a paper without a password by running the code occur at least two possibilities.
    Example: I make right click on a cell and activate the macro, but if I were on an image this command does not work.
    You can disable the selection image forever without protect the sheet?
    To disable the selection of image, you will have to protect the sheet. If you want users to be able to edit the cells, you can unlock the cells, and then protect the sheet.
    Oct 2011
    Hallo
    This is an example of code to enable I can not enter password
        Cancel = True
        Application.CommandBars.FindControl(ID:=130).Execute
    end sub
    I would like to draw a line on the sheet and images
    You can protect the sheet through code and then allow to draw a line through code. To do this, protect the sheet(s) by
    Sheet1.Protect UserInterfaceOnly:=True, Password:="xyz"
    Oct 2011
    Meanwhile, thank you for the answers, but if I run RightClick on protected sheet over an image the event does not Run.
    Here we are again as the first
    Why do you want to right-click? You can use a normal click, and the assigned macro will run even if the sheet is protected. And if you want the shapes also to be unprotected, then use
    Sheet1.Protect UserInterfaceOnly:=True, Password:="xyz", DrawingObjects:=False
    Oct 2011
    Hallo
    Still to solve the problems of selection wonder how the subject should be written the following code:
    Sub Test()
        ActiveSheet.Shapes("Picture 309").Select        'I select the object
        ActiveSheet.Shapes("Picture 309").Deselect      'Here I would like to deselect the object
    Obviously, the code does not work ...
    Sub Test()
        ActiveSheet.Shapes("Picture 309").TopLeftCell.Select
  1. Set Adjust A Button Top Left Position Programmatically
    By jeffrey159 in forum Access Help
    Last Post: 02-02-2013, 06:24 PM
  2. Sort data sheet by right_click of mouse
    Last Post: 12-08-2012, 07:34 PM
  3. Replies: 2
    Last Post: 02-29-2012, 08:24 PM
  4. Replies: 3
    Last Post: 12-07-2011, 09:59 PM
    Last Post: 11-08-2011, 08:52 AM
