Results 1 to 10 of 10
Thread: Sort Data When a Header Is Clicked
    Apr 2011
    I have declared the variable 'HeaderRow' as a Public - so that is the row where I keep the Name(s) of the column header(s) - so now when I click any cell in the 'HeaderRow' the data below is sorted (like the property explorerbar in windows explorer) - It toggles between ascending and descending - however I have to set the focus to another cell (row different from HeaderRow) then click the same HeaderRow cell again - in order to toggke /ascending/descending - is there a way that I can click the same cell multiple times without going via another cell.
    I picked this code up from somebody else - cannot remember his name - but it is very cool - so if I can fix this quirk it would be nice - but I have tried other events in the workbook - but none seems to do what I want.
    Private Sub Workbook_SheetSelectionChange(ByVal Sh As Object, ByVal Target As Range)
        Select Case Target.Row
            Case HeaderRow
                If IsEmpty(Target.Value) Then Exit Sub
                Static MySortType As Integer
                If MySortType = 0 Then
                    MySortType = xlAscending
                ElseIf MySortType = xlAscending Then
                    MySortType = xlDescending
                ElseIf MySortType = xlDescending Then
                'Target.CurrentRegion.Offset(1).Sort key1:=Target, order1:=MySortType, Header:=xlYes
                Target.CurrentRegion.Offset(0).Sort key1:=Target, order1:=MySortType, Header:=xlYes
    xl2007 - Windows 7
    xl hates the 255 number
    Member littleiitin's Avatar
    Aug 2011
    Try this:
    Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
         Dim HeaderRow As Long
         HeaderRow = Target.Row
            Case HeaderRow
    Apr 2011
    Littleiitin
    It behave similar - you have to leave the cell and then put focus on it again. so lets say my header row is row 4 - If I click cell B4 - the data is sorted ascending from row 5 and down - now - to sort descending - I have to click some other cell then click B4 again - I am tryinmg to avoid having to click the other cell.
    xl2007 - Windows 7
    This should work.
    Const HeaderRow As Long = 4
    Private Sub Workbook_SheetBeforeDoubleClick(ByVal Sh As Object, ByVal Target As Range, Cancel As Boolean)
        Cancel = True
    Note: Code edited.
    Apr 2011
    Admin
    I have not tried yours yet - but I will. However I remembered the Calendar control example posted on this site - where you can right_click and the get the choices added. So using that code idea - this allow me to now right_click the HeaderRow and then sort ascending or descending. In this example my HeaderRow=4
    Here is my problem - how can I pass the HeaderRow value from my worksheet code down to the sub(s) in module1 - I have hardwired that HeaderRow=4 in the subs in module1 - but I want to remove that line.
    Is there a way I can pass the code residing in sheet1 - to any new sheets that I add - The code is passed if I copy a sheet - rather than adding a sheet - using the Excel GUI - But I would like to actually be ab;e to copy the worksheet code to any sheet of my choice. In a perfect world the worksheet code should reside in the workbook.
    I have attached the XLSM file
    Again - thank you Site mangers - this site is great.
    Worksheet code
    Private Sub DeleteOnRightClick()
        With Application
            .CommandBars("Cell").Controls("Sort Descending").Delete
            .CommandBars("Cell").Controls("Sort Ascending").Delete
    Private Sub AddOnRightClick()
        HeaderRow = 4 'How to pass the variable to the sub sorting the dat
        Dim SortAsceButton As CommandBarButton
        Dim SortDescButton As CommandBarButton
        With Application
            Set SortDescButton = .CommandBars("Cell").Controls.Add(Temporary:=True, Before:=1)
        With Application
            Set SortAsceButton = .CommandBars("Cell").Controls.Add(Temporary:=True, Before:=1)
        With SortAsceButton
           .BeginGroup = True
           .Style = msoButtonIconAndCaption
           .Caption = "Sort Ascending"
           .FaceId = 125
           .OnAction = "SortAscending"
        With SortDescButton
           .BeginGroup = True
           .Caption = "Sort Descending"
           .FaceId = 125
           .OnAction = "SortDesc"
        Set SortAsceButton = Nothing
        Set SortDescButton = Nothing
    Private Sub Worksheet_BeforeRightClick(ByVal Target As Range, Cancel As Boolean)
       AddOnRightClick
    Module1 code
    Sub SortDesc()
        HeaderRow = 4 'This variable should be passed from worksheet code
        Select Case ActiveCell.Row
            Case HeaderRow
                If IsEmpty(ActiveCell.Value) Then Exit Sub
                ActiveCell.CurrentRegion.Offset(0).Sort key1:=ActiveCell, order1:=MySortType, Header:=xlYes
                Err.Clear
    Sub SortAscending()
        HeaderRow = 4
            Case HeaderRow
                Err.Clear
    xl2007 - Windows 7
    Remove ALL the macros in both the sheet, as well as in the modules. Copy the below code to ThisWorkbook module. You can now add any number of sheets, and the right-click controls will be available.
    Also, the headerRow will now be available in the entire module, and just need to pass value to it in the AddOnRightClick() routine
    Private Sub Workbook_SheetBeforeRightClick(ByVal Sh As Object, ByVal Target As Range, Cancel As Boolean)
        AddOnRightClick
        With Application
        With Application
        With Application
        With SortAsceButton
           .BeginGroup = True
           .FaceId = 125
           .OnAction = "ThisWorkbook.SortAscending"
        With SortDescButton
           .BeginGroup = True
           .FaceId = 125
           .OnAction = "ThisWorkbook.SortDesc"
    Sub SortDesc()
            Case HeaderRow
                Err.Clear
    Sub SortAscending()
            Case HeaderRow
                Err.Clear
    Apr 2011
    Perfect - exactly what the Doctor ordered - Thanks
    Also use FaceId 3157 & 3158 - symbols for sorting
    I uploaded the final XLSM files under tips-Tricks and downloads - this is a very usefull tool - Excel Fox & Admin - thanks for your help.
    xl2007 - Windows 7
    Aug 2012
    Experience Vba co- New to this terrfic site - but cannot duplicate the sort procedure
    Hello Folks,
    Maybe I am just having first time hickups to the site but where is data passed for the sort?
    Or I am missing a point on this macro?
    Apr 2011
    Fioramonti
    This routine sorts the entire sheet from the headerrow down -- are you looking to only sort a single column of data or a range of cells?
    Rasm
    xl2007 - Windows 7
    Aug 2012
    Sorting in range
    Hello frasm,
    Yes, I would be sorting a range of rows, single column.
    fioramonti
  1. Sort Data Using Formula To Find Top X
    Last Post: 06-02-2013, 10:13 PM
  2. Replies: 6
    Last Post: 05-10-2013, 01:13 AM
  3. Sort data sheet by right_click of mouse
    Last Post: 12-08-2012, 07:34 PM
  4. Meger multiple file but header not same
    By rocky in forum Excel Help
    Last Post: 10-25-2012, 09:09 PM
  5. Excel Macro to Sort Data if a value changes in defined range
    Last Post: 09-05-2012, 10:31 AM
