Results 1 to 5 of 5
Thread: Remove first character then compare to another cell
    Jul 2015
    Hi all, new to this forum and forums in general, so I hope I posted my question correctly and that I am clear enough.
    I have two columns where column "E" has just numbers that are 6-10 digits in length and the second column "H" starts with an alphanumeric character (lets say the letter B) then 6-10 digits after it.
    The columns go from E1: E273 and H1:H273. (not always but long enough )
    I need to remove the first character in column H then compare the results to column E. If there is a different, I need to know and that can be up to your discretion, as long as I can see the results.. I could be notified by color, by putting a 0 or 1 in a different column, or by dropping the number in a any different column.
    What I have tried is creating a blank column G and putting in it the formula
    =REPLACE(H1,1,1,"")
    which removed the first character in column H and showed up in column G
    Then I put in blank column F the formula
    =IF(ISNA(MATCH(G1,E:E,0)),G1,1)
    which only copied the results from column G to column F as if to say they were different. If they were the same column F would have the results 1 and not the number.
    Not sure what I did wrong. And if it can be done through a VBA macro, that would be fantastic. I will be using it a lot.
    EX.
    Colum E
    14624720
    7802049
    24842259
    28675186
    32334880
    30466791
    2234169
    24717605
    45069143
    7825783
    16875105
    13656190
    9447593
    Column H
    B14624720
    B7802049
    B24842259
    B28675186
    B32334880
    B30466791
    J2234169
    J24717605
    J45069143
    B7825783
    B16875105
    B13656190
    B9447593
    Thank you for your time and help,
    Dave
    Moderator
    Jul 2012
    Here is another macro you can consider...
    Sub Test()
      Dim LastRow As Long
      LastRow = Cells(Rows.Count, "E").End(xlUp).Row
      Range("F1:F" & LastRow) = Evaluate(Replace("IF(E1:E#=0+MID(H1:H#,2,99),1,E1:E#)", "#", LastRow))
    Or:
    Sub M_snb()
       [I2:I200] = [if(E2:E200="","",if(E2:E200=abs(mid(H2:H200,2,100)),"x",""))]
  1. compare two tables
    By emmye998 in forum Excel Help
    Last Post: 03-24-2014, 04:25 AM
  2. Remove Special Characters From Text Or Remove Numbers From Text
  3. Macro To Delete Numbers With Trailing Character
    Last Post: 04-05-2013, 08:14 PM
  4. compare column a to b and b to a
    Last Post: 05-07-2012, 04:46 PM
  5. Count words having more than one character in a cell
    Last Post: 03-13-2012, 08:29 PM
