Thread: Need to modify VBA code to import data from other workbook
    Oct 2014
    Hello guys,
    Need a little help to modify the below codes. Currently it copies data from the the source workbook if its column label matches what we have in ThisWorkbook.Worksheets("Sheet1").Range("B1:V1"). The below code requires the target workbook to have its column labels on A1 for it to work and this is where i'm having problem now. I want to export data from another workbook which has all its column labels on A5 to AH5 and i need to figure out how to edit the vba to capture and import data. Hope anyone can help on this. Thanks in advanced
     Sub Export_RAW()
        'Selection.AutoFilter
        With Application.FileDialog(msoFileDialogFilePicker)
            .AllowMultiSelect = False
            .ButtonName = "Import"
            .Filters.Clear
            '.Filters.Add "Excel Files", "*.csv"
            '.Filters.Add "CSV File", "*.xlsx"
            .Title = "Import Data"
            .Show
            If .SelectedItems.Count Then
                strFileSelected = .SelectedItems(1)
                'MsgBox "Cancelled by user!"
        fncFileSelected = strFileSelected
        With Workbooks.Open(Filename:=fncFileSelected, ReadOnly:=True)
            .Sheets(1).Cells(1).End(xlToRight).Offset(, 2).Resize(, 21).Value = ThisWorkbook.Worksheets("Sheet1").Range("B1:V1").Value
            .Sheets(1).Cells(1).CurrentRegion.AdvancedFilter Action:=xlFilterCopy, CopyToRange:=.Sheets(1).Cells(1).End(xlToRight).Offset(, 2).CurrentRegion, Unique:=False
            With .Sheets(1).Cells(1).End(xlToRight).Offset(, 2).CurrentRegion
                ThisWorkbook.Worksheets("Sheet1").Range("B1:V1").Resize(.Rows.Count, .Columns.Count).Value = .Value
            ActiveWorkbook.RefreshAll
            Workbooks(.Name).Close 0
        .Sheets(1).Cells(5, 1).End(xlToRight).Offset(, 2).Resize(, 21).Value = ThisWorkbook.Worksheets("Sheet1").Range("B1:V1").Value
        Dim r  As Long, Rng As Range
        r = .Sheets(1).Range("a" & .Sheets(1).Rows.Count).End(3).Row
        Set Rng = .Sheets(1).Range("A5:U" & r)
        Rng.AdvancedFilter Action:=xlFilterCopy, CopyToRange:=.Sheets(1).Cells(5, 1).End(xlToRight).Offset(, 2).CurrentRegion, Unique:=False
        With Rng.Cells(1, 1).End(xlToRight).Offset(, 2).CurrentRegion
    Oct 2014
    Thanks admin for immediate response. its working fine now. I appreciate your help
    You are welcome
  1. Need help to modify the VBA code
    By jeremiah_j2k in forum Excel Help
    Last Post: 10-23-2014, 01:44 PM
  2. Replies: 4
    Last Post: 04-19-2014, 05:08 PM
  3. Replies: 1
    Last Post: 05-09-2013, 08:56 AM
  4. Replies: 7
    Last Post: 05-08-2013, 07:12 PM
  5. VBA Code to Open Workbook and copy data
    Last Post: 08-15-2012, 06:58 PM
