Results 1 to 10 of 14
Thread: obtain data from 3 input with conditions
    Nov 2011
    [solved]obtain data from 3 input with conditions
    i make this table and is it possible to obtain the data from other sheet with 3 input based on length, diameter and quality.please kindly help me to solve it to get the exact data.
    how to get the price from HJD-sono tab? If :
    1. class = a, price + 10% of price
    2. class = b, price + 7.5% of price
    3. class = c, price + 5 % of price
    4. class = d, price + 2.5% of price
    5. class = e, price
    i have attached the file too.hope you guys able to help me
    Hi mtsf26,
    Welcome to ExcelFox !!!
    It can be done with formulas, though you need to make some adjustments in the layout.
    Replace diameter
    0-19 20-29 30-39 40-49 50-59 60 up
    with
    0 20 30 40 50 60
    also replace length
    50 - 90
    100 - 190
    200 - 290
    300 - 390
    400 UP
    50 - 90
    100 - 190
    200 - 290
    300 - 390
    400 UP
    50 - 90
    100 - 190
    200 - 290
    300 - 390
    400 UP
    50 - 90
    100 - 190
    200 - 290
    300 - 390
    400 UP
    with
    50
    100
    200
    300
    400
    50
    100
    200
    300
    400
    50
    100
    200
    300
    400
    50
    100
    200
    300
    400
    In E2 and copied down
    =INDEX(Price,MATCH(C2,Quality,0)+MATCH(B2,{50,100, 200,300,400})-1,MATCH(A2,Dia))*LOOKUP(D2,{"a",1.1;"b",1.075;"c", 1.05;"d",1.025;"e",1})
    where Price,Quality,Dia are named ranges.
    HTH
    Member littleiitin's Avatar
    Aug 2011
    or you can use Below VBA Code:
    Follow Below Steps:
    1: Activate your file
    2: Press Alt+F11
    3: In Exteam Left side You can see list of your sheets. Just Right Click any of the sheet
    4: Click Insert--->Module
    5: Paste Below code in Blank Area
    6: Press F5
    Sub CalculatePrice()
        Dim rngCell     As Range
        Dim rngCellC    As Range
        Dim rngCellR    As Range
        Dim rngWholeC   As Range
        Dim rngWholeR   As Range
        Dim rngWholeRow As Range
        Dim rngWhole    As Range
        Dim rngQuality  As Range
        Dim lngCol      As Long
        Dim lngRow      As Long
        Dim sngPrice    As Single
        With ThisWorkbook.Worksheets("HJD-sono")
            Set rngWholeC = .Range(.Range("C3"), .Cells(3, .Columns.Count).End(xlToLeft))
            Set rngWholeR = .Range("A4:A" & .Range("A" & .Rows.Count).End(xlUp).Row)
        With ThisWorkbook.Worksheets("XXX")
            Set rngWhole = .Range("A2:A" & .Range("A" & .Rows.Count).End(xlUp).Row)
            For Each rngCell In rngWhole
               'Finding Column
                For Each rngCellC In rngWholeC
                    On Error GoTo X1:
                    If rngCell.Value >= CLng(Mid(rngCellC.Value, 1, InStr(1, rngCellC.Value, "-"))) And rngCell.Value <= CLng(Mid(rngCellC.Value, InStr(1, rngCellC.Value, "-") + 1, Len(rngCellC.Value) - InStr(1, rngCellC.Value, "-"))) Then
    X1:
                        lngCol = rngCellC.Column
                        Exit For
                Next rngCellC
                'Finding Quality
                Set rngWholeRow = Nothing
                For Each rngQuality In rngWholeR
                    If rngQuality.Value = rngCell.Offset(, 2).Value Then
                    If rngWholeRow Is Nothing Then
                        Set rngWholeRow = rngQuality
                        Set rngWholeRow = Union(rngWholeRow, rngQuality)
                'Finding Row
                Set rngWholeRow = rngWholeRow.Offset(, 1)
                For Each rngCellR In rngWholeRow
                    On Error GoTo X2:
                    If rngCell.Offset(, 1).Value >= CLng(Mid(rngCellR.Value, 1, InStr(1, rngCellR.Value, "-") - 2)) And rngCell.Offset(, 1).Value <= CLng(Trim(Mid(rngCellR.Value, InStr(1, rngCellR.Value, "-") + 1, Len(rngCellR.Value)))) Then
    X2:
                        lngRow = rngCellR.Row
                        Exit For
                Next rngCellR
                'Finding Price
                    sngPrice = .Cells(lngRow, lngCol).Value
                'Calculating Exact Price
                If rngCell.Offset(, 3).Value = "a" Then
                    rngCell.Offset(, 4) = sngPrice + (sngPrice * 0.1)
                ElseIf rngCell.Offset(, 3).Value = "b" Then
                    rngCell.Offset(, 4) = sngPrice + (sngPrice * 0.075)
                ElseIf rngCell.Offset(, 3).Value = "c" Then
                    rngCell.Offset(, 4) = sngPrice + (sngPrice * 0.05)
                ElseIf rngCell.Offset(, 3).Value = "d" Then
                    rngCell.Offset(, 4) = sngPrice + (sngPrice * 0.025)
                ElseIf rngCell.Offset(, 3).Value = "e" Then
            Next rngCell
    Nov 2011
    hi admin.thanks it work..
    @ littleiitin
    hey thanks for the code.but i just confused i cant debug it,and seems something wrong with this line:
    X2:
    i still curious with you code.hoep you can help to fix it too.thanks
    Aug 2011
    Hi mtsf26,
    Its working fine at my end. Please Re paste the code and Run it.
    If still facing issue please attach your file with code.
    I will fix it.
    Rahul Kumar Singh
    Hi mtsf26,
    Please don't quote entire the post until and unless it's unavoidable.
    Junior Member Haseeb A's Avatar
    Apr 2011
    Hello mtsf26,
    Try the attached with your original data structure.
    Nov 2011
    hi admin thanks to edit my post. sorry for quoting it.
    @haseeb what CurrRange function is?and when im copy it into other workbook its not wrking
    @littleiitin here the screenshoot of error http://i1106.photobucket.com/albums/...sf26/error.jpg and i also attached the file.so i add module in xxx sheet
    Aug 2011
    There is no Code in it. Please Paste code and save it as .xlsm file and then attach the file.
    Nov 2011
    i dont knw this is what u mean or not.hehehe
  1. Delete Rows Based on Conditions
    By AbiG2009 in forum Excel Help
    Last Post: 12-26-2018, 01:24 PM
  2. Nested If Formula With Multiple Conditions
    By lprc in forum Excel Help
    Last Post: 04-22-2013, 07:27 PM
  3. INPUT DATA FORM ON WORK SHEET
    By Ryan_Bernal in forum Excel Help
    Last Post: 12-30-2012, 05:56 PM
  4. split data into multiple workbooks with 3 conditions.
    By malaionfun in forum Excel Help
    Last Post: 05-11-2012, 11:26 AM
  5. Extract multiple data matching with input
    Last Post: 02-13-2012, 06:08 PM
