Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: String text in Word html. Passing info between Word and Excel
    Some string text in Word Tests and Experiments
    Not doing anything special here, not yet anyway. I just want a quick coding to
    _ take a highlighted text in a word .doc , and
    _ pick out any URL links, and
    _ put those links in the clipboard in some convenient form to paste somewhere.
    What have we got
    A good start point is to check what a typical text containing the URLs is, in particular we need to look in a bit more detail to see what non obvious, so called “invisible” characters may be there.
    This is the coding to run after selecting some text in a word .doc
    '        https://www.excelfox.com/forum/showthread.php/2302-quot-What%E2%80%99s-in-a-String-quot-VBA-break-down-Loop-through-character-contents-of-a-string?p=21221&viewfull=1#post21221      https://www.excelfox.com/forum/showthread.php/2348-String-text-in-Word-html-Passing-info-between-Word-and-Excel?p=21222&viewfull=1#post21222        String text in Word html.doc
    Sub WhatsInIt()
    Dim Str As String ' To hold the selected text in word
     Let Str = Selection.Text
    Call WatchaGotWord(Str)
    The function can be found here https://www.excelfox.com/forum/showt...1221#post21221
    Here is an example of some text
    I indicated there, areas to be looked at.
    Here is a few results of what the coding shows me
     "Hub" & "." & vbCr & vbCr & "The " & "$"
    "sUQxO5CVyx4AaABAg" & vbCr & vbCr & vbCr & "1 of " & "4"
    "https" & ":" & "/" & "/" & "www" & "." & "youtube" & "." & "com" & "/" & "watch" & "?" & "v" & "=" & "yVgLmj0aojI" & "&" & "lc" & "=" & "UgwWg8x2WxLSxxGsUP14AaABAg" & "." & "9k3ShckGnhv9k89LsaigoO  1" & vbCr
    Conclusions of text content investigation
    No big surprises. It seems that a new line is indicated by vbCr – That is occaisionally used instead of the more typical 2 characters , vbCr & vbLf.
    A solution for a quick coding would be:
    _ Replace any vbCr ( or any pair of vbCr & vbLf just incase that is used anywhere ) , with a space.
    _ Do a VBA Split using spaces as the separator.
    _ Go through each array element, take any looking like a link.
    _ Put those links in the clipboard in a convenient way to paste out
    This will do for now
    Sub URLsToClipboard()   '     https://www.excelfox.com/forum/showthread.php/2348-String-text-in-Word-html-Passing-info-between-Word-and-Excel?p=21222#post21222
     Let Str = Replace(Str, vbCr & vbLf, " ", 1, -1, vbBinaryCompare) ' Do this first before next line or else I might end up with   vbLfs   which may mess things up.  For now I assume the   vbLf   on its own wont be used anywhere. It rarely is
     Let Str = Replace(Str, vbCr, " ", 1, -1, vbBinaryCompare)
    Dim SpltStr() As String
     Let SpltStr() = Split(Str, " ", -1, vbBinaryCompare)
    '  Go through the array elements fromm the  Split  and build a string from any looking like  URLs   , I may as well join them in a string with a   vbCr & vbLf   as the joining but, since then i automatically have  the start of a convenient form to put in the clipboard, since likely I will want to paste the  URLs  in a list
        For Cnt = LBound(SpltStr) To UBound(SpltStr)
        Dim StrClp As String ' The final string to put in clipboard
            If InStr(1, SpltStr(Cnt), "https://www", vbBinaryCompare) > 0 Then
             Let SpltStr(Cnt) = Trim(SpltStr(Cnt)) ' I think I probably don't need this, never mind
            Dim URL1 As String: Let URL1 = SpltStr(Cnt)
            Dim URL2 As String: Let URL2 = Replace(URL1, "tps://ww", "[color=white]tps://ww[/color]", 1, 1, vbBinaryCompare)  ' A version with  disguised  URL
            ' build the final forum post type string
            Dim FrmStr As String
             Let FrmStr = FrmStr & "[url=" & URL1 & "][color=white]" & URL2 & "[/color][/url]" & vbCr & vbLf
             ' element text is not a  URL
    '   Put the string in the clipboard
        With GetObject("New:{1C3B4210-F441-11CE-B9EA-00AA006B1A69}")  '   web.archive.org/web/20200124185244/http://excelmatters.com/2013/10/04/late-bound-msforms-dataobject/
         .SetText FrmStr
         .PutInClipboard
    https://www.youtube.com/watch?v=ySENWFIkL7c
    https://www.youtube.com/watch?v=ySENWFIkL7c&lc=UgyqIYcMnsUQxO5CVyx4AaABAg
    https://www.youtube.com/watch?v=yVgLmj0aojI
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgwWg8x2WxLSxxGsUP14AaABAg. 9k3ShckGnhv9k89LsaigoO
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgxxxIaK1pY8nNvx6JF4AaABAg. 9k-vfnj3ivI9k8B2r_uRa2
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=UgxKFXBNd6Pwvcp4Bsd4AaABAg
    https://www.youtube.com/watch?v=yVgLmj0aojI&lc=Ugw9X6QS09LuZdZpBHJ4AaABAg
    Then I did this one, because like a twat I forgot where I put the last one
    Sub WhiteSpamUrl()              '    https://www.excelfox.com/forum/showthread.php/2348-String-text-in-Word-html-Passing-info-between-Word-and-Excel?p=21222&viewfull=1#post21222
    Dim ClipTxt As String: Let ClipTxt = "[url=https://www.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHA] [COLOR=white] htt[COLOR=white]p[/COLOR]s:/[COLOR=white]/w[/COLOR]ww.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHA [/color] [/url]" & vbCr & vbLf
    Dim SelText As String
     Let SelText = Selection.Text
    Dim RwTxt() As String
     Let RwTxt() = Split(SelText, vbCr, -1, vbBinaryCompare)
    Dim RwCnt As Long
        For RwCnt = LBound(RwTxt()) To UBound(RwTxt())
        Dim ClmTxt() As String
         Let ClmTxt() = Split(RwTxt(RwCnt), " ", -1, vbBinaryCompare)
        Dim ClmCnt As Long
            For ClmCnt = LBound(ClmTxt()) To UBound(ClmTxt())
                If InStr(1, Trim(ClmTxt(ClmCnt)), "//www.", vbBinaryCompare) > 0 Then
                Dim URL As String, URL2 As String
                 Let URL = Trim(ClmTxt(ClmCnt))
                 Let URL2 = Replace(URL, "http", "ht[color=white]tp[/color]", 1, 1, vbBinaryCompare)
                 Let URL2 = Replace(URL2, "//www.", "/[color=white]/ww[/color]w.", 1, 1, vbBinaryCompare)
                 Let ClipTxt = ClipTxt & "[url=" & URL & "] [color=white] " & URL2 & " [/color] [/url]" & vbCr & vbLf
                ' no url
            Next ClmCnt
        Next RwCnt
     Let ClipTxt = ClipTxt & "[url=https://www.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHA] [COLOR=white] htt[COLOR=white]p[/COLOR]s:/[COLOR=white]/w[/COLOR]ww.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHA [/color] [/url]"
         .SetText ClipTxt
         .PutInClipboard
    https://www.youtube.com/watch?v=vXyMScSbhk4
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgynOSp1dleo-Z8L_QN4AaABAg.9jJLDC1Z6L-9k68CuL4aTY
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgwV5N_ulFXYMNbyQG54AaABAg. 9itCkoVN4w79itOVYVvEwQ
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgyOh-eR43LvlIJLG5p4AaABAg.9isnKJoRfbL9itPC-4uckb
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=Ugy1B1aQnHq2WbbucmR4AaABAg. 9isY3Ezhx4j9itQLuif26T
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgxxajSt03TX1wxh3IJ4AaABAg. 9irSL7x4Moh9itTRqL7dQh
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgwJAAPbp8dhkW2X1Uh4AaABAg. 9iraombnLDb9itV80HDpXc
    https://www.youtube.com/watch?v=vXyMScSbhk4&lc=UgzIzQ6MQ5kTpuLbIuB4AaABAg. 9is0FSoF2Wi9itWKEvGSSq
    Sub WhiteSpamUrl()   '   White Spam URL  WhiteSpamUrl WhiteSpamUrl()  [url]https://www.excelfox.com/forum/showthread.php/2348-String-text-in-Word-html-Passing-info-between-Word-and-Excel?p=21222&viewfull=1#post21222[/url]     [url]https://www.excelfox.com/forum/showthread.php/2824-Tests-Copying-pasting-Cliipboard-issues?p=18376&viewfull=1#post18376[/url]
    Dim RwCnt As Long
        Dim ClmCnt As Long
                If InStr(1, Trim(ClmTxt(ClmCnt)), "//www.", vbBinaryCompare) > 0 Or InStr(1, Trim(ClmTxt(ClmCnt)), "https://", vbBinaryCompare) > 0 Or InStr(1, Trim(ClmTxt(ClmCnt)), "http://", vbBinaryCompare) > 0 Then
                ' no url
            Next ClmCnt
        Next RwCnt
    ' Check string length
    Dim LenClipTxt As Long: Let LenClipTxt = Len(ClipTxt)
    MsgBox Prompt:=LenClipTxt
         .SetText ClipTxt
         .PutInClipboard
  2. #22
    Sub FuckoffvbCrandvbLfinwordtext()  '   https://www.excelfox.com/forum/showthread.php/2824-Tests-Copying-pasting-Cliipboard-issues?p=18377&viewfull=1#post18377
    Dim ClipTxt As String ': Let ClipTxt = "  https://www.youtube.com/channel/UCnxwq2aGJRbjOo_MO54oaHA  " & vbCr & vbLf
     Let ClipTxt = Replace(SelText, vbCr, "", 1, -1)
     Let ClipTxt = Replace(ClipTxt, vbLf, "", 1, -1)
         .SetText ClipTxt
         .PutInClipboard
  1. Replies: 1
    Last Post: 04-02-2019, 03:04 PM
  2. Export data (text) Excel to Ms Word Format
    By muhammad susanto in forum Excel Help
    Last Post: 10-06-2017, 09:36 AM
  3. Replies: 7
    Last Post: 08-24-2015, 10:58 PM
  4. VBA How to pass formatted text from Excel to MS Word
    By johnweber in forum Excel Help
    Last Post: 03-01-2015, 08:41 PM
    Last Post: 10-16-2012, 01:53 PM
