Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Tests and Notes for EMail Threads
    Further notes in support of answer to this Thread:
    http://www.excelfox.com/forum/showth...kbooks-at-once
    http://www.excelfox.com/forum/showth...0518#post10518
    Microsoft Outlook.
    WTF is that and HTF do you do anything with it, and WTF is it supposed to do.
    I didn't know. And still don't......
    The internet is full of stuff on this, but there is no clear explanation of what it is or what it should do or how you do anything with it.
    But I had a go
    Microsoft Outlook: what is that ( using manually )
    You would normally get the software to run on its own ( visible as it were ) in a similar way to which you might get Word or Excel to start, for example
    Find it single click on it:
    FindOutlook Start AllProgrammes Microsoft MicrosoftOutlook.JPG : https://imgur.com/LaGs6HA
    FindOutlook Start TypeInSearchBox Outlook.JPG : https://imgur.com/IbFOSHz
    Make a Desktop icon from a Copy/ paste and double click on it :
    MicrosoftOutlook Make a desktop Icon to double click on.JPG : https://imgur.com/ZNNPmOI
    The first time you try to open it with a click or two, a set up starts.
    Outlook2003Start.JPG https://imgur.com/tSQDoTe
    The main use of the Outlook software is to do Email stuff, so usually you will have at least one Email account “registered in it” You can do this at the set up or later.
    I had a go,
    the start was OK:
    Outlook2003Start.JPG https://imgur.com/R71pKfy
    Outlook2003Start2.JPG https://imgur.com/XUFMpEm
    These following steps took me a few hours of Emails, Internet surfing and annoying Telephone calls to my Internet provider before I
    _ chose IMAP here : Outlook2003Start3ServerType.JPG : https://imgur.com/Jmnd6Vb
    _ got the two required things to put in the 2 server information bars, and other stuff to fill in this : Outlook2003Start4ServerConfiguration.JPG : https://imgur.com/NXNAt9J
    Von: "Doc.AElstein@t-online.de"
    An: "elston, alan"
    Pop3
    *	Serveradresse	Port*	Sicherheit
    Posteingang	securepop.t-online.de	995	SSL / TLS
    Postausgang	securesmtp.t-online.de	465	SSL
    E-Mails über IMAP4 abrufen
    Posteingang	secureimap.t-online.de	993	SSL
    To: "elston, alan"
    pop3
    Server address Port Security
    Inbox securepop.t-online.de 995 SSL / TLS
    Outbox securesmtp.t-online.de 465 SSL
    Retrieve emails via IMAP4
    Inbox secureimap.t-online.de 993 SSL
    MyTelekomNameUsernamePassword.JPG : https://imgur.com/K6qZgsE
    TelekomInternetConfiguration.JPG : https://imgur.com/Z3XcsJu
    Then I hit Finish:
    Outlook2003Start5Fertig.JPG : https://imgur.com/wIMvqBb ´
    I get an error in the left Pane atz that point or later as well sometimes :
    Outlook2003Start6LeftpaneErrror.JPG : https://imgur.com/35XLQv6
    could not connect to the server  secureimap t online.JPG : https://imgur.com/UqEZtQe
    Fehler (0x800CCC0E) beim Ausführen der Aufgabe "Suchen nach neuen Nachrichten in den abonnierten Ordnern auf secureimap.t-online.de.": "Der Download des Ordners "(null)" von Konto "secureimap.t-online.de" vom IMAP-Mailserver ist fehlgeschlagen. Fehler: Die Verbindung zum Server konnte nicht hergestellt werden. Falls dieser Fehler weiterhin auftritt, wenden Sie sich an den Serveradministrator oder den Internetdienstanbieter."
    Fehler (0x800CCC0E) beim Ausführen der Aufgabe "secureimap.t-online.de: Posteingang - Auf neue E-Mail überprüfen.": "Der Download des Ordners "Posteingang" von Konto "secureimap.t-online.de" vom IMAP-Mailserver ist fehlgeschlagen. Fehler: Die Verbindung zum Server konnte nicht hergestellt werden. Falls dieser Fehler weiterhin auftritt, wenden Sie sich an den Serveradministrator oder den Internetdienstanbieter."
    Error (0x800CCC0E) while performing the task "Search for new messages in the subscribed folders on secureimap.t-online.de.": "Downloading the folder" (null) "from account" secureimap.t-online.de "from IMAP mail server failed Error: Unable to connect to server If this error persists, contact your server administrator or ISP. "
    Error (0x800CCC0E) when executing the task "secureimap.t-online.de: Inbox - Check for new e-mail.": "The download of the folder" Inbox "of account" secureimap.t-online.de "from IMAP- Mail server failed Error: Unable to connect to server If this error persists, contact your server administrator or ISP. "
    Every time I open Microsoft Outlook after that I get a pop up : could not connect to the server secureimap t online.JPG : https://imgur.com/UqEZtQe
    Es Konnte keine Verbindung zum Server hergestellt werden. secureimap.t-online.de befindet sich jetzt im Offlinemodus
    It could not connect to the server. secureimap.t-online.de is now in offline mode
    So I am still none the wiser, but It is worth doing all that anyway as you may need some of that information later in one or more of the ways to send an Email using VBA.
    A Folk, A Forum, A Fuhrer ….
    VBA to automate Send and Automatically Sending of E-Mai
    _1 ) Way 1) Use the CDO (Collaboration Data Objects ) object library available in VBA
    Main Code , Sub PetrasDailyProWay1_COM_Way() ,
    Function Code for solution to this Thread and Post
    Option Explicit ' Daily Diet plan, Sending of Notes and an Excel File
    Sub PetrasDailyProWay1_COM_Way() '  Allow access to deep down cods wollops from Microsoft to collaborating in particular in the form of messaging. An available library of ddl library functions and associated things is available on request, the  Microsoft CDO for Windows 2000. We require some of these '  CDO is an object library that exposes the interfaces of the Messaging Application Programming Interface (MAPI). API: interfaces that are fairly easy to use from a fairly higher level from within a higher level programming language. In other words this allows you to get at and use some of the stuff to do with the COM OLE Bollocks from within a programming language such as VBA  API is often referring loosely to do with using certain shipped with Windows software in Folders often having the extension dll. This extension , or rather the dll stands for direct link libraries. These are special sort of executable files of functions shared by many other (Windows based usually) software’s.
    ' Rem1 The deep down fundamental stuff , which includes stuff been there the longest goes by the name of Component Object Model. Stuff which is often, but not always, later stuff, or at a slightly higher level of the computer workings, or slightly more to a specific application ( an actual running "runtime" usage / at an instance in time , "instance of" ) orientated goes to the name of Object Linking and Embedding. At this lower level, there are protocols for communicating between things, and things relate are grouped into the  to Office  application available Library, CDO. An important object there goes by the name of Message.
    'Rem 1) Library made available            ====================#
      With CreateObject("CDO.Message") '   Folders mostly but not always are in some way referenced using dll, either as noted with the extension or maybe refered to as dll Files or dll API files.
    'Rem 2 ' Intraction protocols are given requird infomation and then set
        '2a) 'With --------------------* my Created LCDCW Library, (LCD 1.0 Library ) (Linking Configuration Data_Cods Wollups) which are used and items configured for the Exchange at Microsoft’s protocol thereof;   http://schemas.microsoft.com/cdo/configuration/ ......This section provides the configuration information for the remote SMTP server
        Dim LCD_CW As String: Let LCD_CW = "http://schemas.microsoft.com/cdo/configuration/" ' Linking Configuration Data : defines the majority of fields used to set configurations for various Linking Collaboration (LCD) Objects Cods Wollops: These configuration fields are set using an implementation of the IConfiguration.Fields collection.  https://msdn.microsoft.com/en-us/library/ms872853(v=exchg.65).aspx
         .Configuration(LCD_CW & "smtpusessl") = True ' ' ' HTTPS (Hyper Text Transfer Protocol Secure) appears in the URL when a website is secured by an SSL certificate. The details of the certificate, including the issuing authority and the corporate name of the website owner, can be viewed by clicking on the lock symbol on the browser bar. in short, it's the standard technology for keeping an internet connection secure and safeguarding any sensitive data that is being sent between two systems, preventing criminals from reading and modifying any information transferred, including potential personal details.  ' SSL protocol has always been used to encrypt and secure transmitted data
         .Configuration(LCD_CW & "smtpauthenticate") = 1  ' ... possibly this also needed ..   When you also get the Authentication Required Error you can add this three lines.
        '  ' Sever info
         .Configuration(LCD_CW & "smtpserver") = "smtp.gmail.com" ' "securesmtp.t-online.de"                 '"smtp.gmail.com" "smtp.mail.yahoo.com" "smtp.live.com" "pod51017.outlook.com"  "smtp-mail.outlook.com" "smtp.live.com"  "securesmtp.t-online.de"  465         SMTP is just used to mean the common stuff.....  Simple Mail Transport Protocol (SMTP) server is used to send outgoing e-mails. The SMTP server receives emails from your Mail program and sends them over the Internet to their destination.
        '  The mechanism to use to send messages.
         .Configuration(LCD_CW & "sendusing") = 2  '  Based on the LCD_OLE Data Base of type DBTYPE_I4
         .Configuration(LCD_CW & "smtpserverport") = 25 ' 465or25fort-online ' 465 'or 587 'or 25   ' The port of type somehow refered to by the last line
         .Configuration(LCD_CW & "sendusername") = "excelvbaexp@gmail.com" ' "Doc.AElstein@t-online.de" ' .... "server rejected your response".  AFAIK : This will happen if you haven't setup an account in Outlook Express or Windows Mail .... Runtime error '-2147220975 (800440211)': The message could not be sent to the SMTP server. The transport error code is 0x80040217. The server response is not available
         .Configuration(LCD_CW & "sendpassword") = "Bollocks" '              "Bollox"
        ' Optional - How long to try     ( End remote SMTP server configuration section )
         .Configuration(LCD_CW & "smtpconnectiontimeout") = 30 '    Or there Abouts ;) :)
        ' Intraction protocol is Set/ Updated
         .Configuration.Fields.Update ' 'Not all infomation is given, some will have defaults. - possibly this might be needed initially ..    .Configuration.Load -1 ' CDO Source Defaults
        'End With ' -------------------* my Created  LCDCW Library ( Linking Configuration Data Cods Wollups)  which are  used and items configured for the Exchange at Microsoft's protocol therof;
       '2b) ' Data to be sent
       '.To = "Doc.AElstein@t-online.de"
       .To = "excelvbaexp@gmail.com"
       .CC = ""
       .BCC = ""
       .from = """Alan"" "
       .Subject = "Bollox"
       '.TextBody = "Hi" & vbNewLine & vbNewLine & "Please find the Excel workbook attached."
       .HTMLBody = MyLengthyStreaming
       .AddAttachment "G:\ALERMK2014Marz2016\NeueBlancoAb27.01.2014\AbJan2016\Übersicht aktuell.xlsx" ' ' Full File path and name. File must be closed
     Rem 3 Do it
       .Send
     End With ' CreateObject("CDO.Message") (Rem 1 Library End =======#
    Public Function MyLengthyStreaming() As String
    Rem 1 Make a long string from a Microsoft Word doc
    '1(i) makes available the Library of stuff, objects, Methods etc.
    Dim Fso As Object: Set Fso = CreateObject("Scripting.FileSystemObject")
    '1(ii) makes the big File Object                       " Full path and file name of Word doc saved as .htm       "
    Dim FileObject As Object: Set FileObject = Fso.GetFile("G:\ALERMK2014Marz2016\NeueBlancoAb27.01.2014\AbJan2016\ProMessage.htm"): Debug.Print FileObject
    '1(iii) sets up the data  "stream highway"
    Dim Textreme As Object:  Set Textreme = FileObject.OpenAsTextStream(iomode:=1, Format:=-2)        '   reading only, Opens using system default            https://msdn.microsoft.com/en-us/library/aa265341(v=vs.60).aspx
    '1(iv) pulls in the data, in our case into a simple string variable
     Let MyLengthyStreaming = Textreme.ReadAll         '        Let MyLengthyStreaming = Replace(MyLengthyStreaming, "align=center x:publishsource=", "align=left x:publishsource=")
     Textreme.Close
     Set Textreme = Nothing
     Set Fso = Nothing
    Rem 2 possible additions to MyLengthyStreaming
    Last bit of Function ( must go here in the excelfox Test Sub Forum in HTML Tags as there are HTML Tags in the final text string string and this makes a mess in normal BB code tags, because in excelfox Test Forum HTML is activated ) :
    HTML Code:
     Let MyLengthyStreaming = "<p><span style=""color: #ff00ff;"">Start=========== " & Format(Now(), "DD MMMM YYYY") & " " & Now() & " ------------------------------------</span></p>" & MyLengthyStreaming & "<p><span style=""color: #ff00ff;"">-- " & Format(Now(), "DD MMMM YYYY") & " " & Now() & " ==End, Sent from Doc.AElstein Mail ======</span></p>"
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwviLabd7r_3KpP6wh4AaABAg.9h5lFRmix1R9h78GftO_ iE
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9h77HSGDH 4A
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9h76fafzc EJ
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9h759YIjl aG
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg.9h740K6COOA9h74pjGcb Eq
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgzJJUDVv2Mb6YGkPYh4AaABAg.9h5uPRbWIZl9h7165DZd jg
    HTML For CDO.Message.HTMLBody in VBA Emails sending
    Linked in my Binding Function, MyLenghtyString LBF_MLS
    In support of this Thread:
    HTM / HTML is a very typical electronic message language recognised by most software devices associated with Email and similar.
    In two ways considered in this Thread , http://www.excelfox.com/forum/showth...0512#post10512 , the main Message Text body to be sent in an Email can be supplied as a single HTML code string.
    One convenient way to supply this is with a simple Word.doc file which can simply saved with a htm file extension
    Word doc to htm.JPG : https://imgur.com/vhRE9CC
    By opening this with a simple text editor, the actual text along with much more htm code detail can be revealed
    LastBitOfProMessage htm.JPG : https://imgur.com/mT6l40I
    LastBitOfProMessage htm 2.JPG : https://imgur.com/s0U8419
    This is the actual text required to be given after the an Email data filling code line like:
    _ .HTMLBody =
    The actual file held anywhere will likely include all sorts of computery stuff in addition to that text.
    We can get at just the text in several ways.
    A typical way in VBA is to make use of one of a number of Object Orientated stuff held in the Visual Basic FileSystemObject Object. This is in turn part of the Bundle in the available to application programs (such as Excel VBA) Library, Microsoft Scripting Runtime
    The way this works is as follows.
    For a given file, a large object can be made within the Microsoft Scripting Runtime Library Class type Module like Library, ** Polymorphically speaking.
    The Microsoft Scripting Runtime FileSystemObject Object GetFile method returns this object requiring only its full file path in order to “Get at it” . ( The returned object is pseudo in the streaming runtime instant direct compiling linking .Net technology held as a running link, ( indeed by assigning the object to, or using in an environment of, String will itself return that arguments string reference ) )
    **:From Microsoft documentation: Visual Basic provides polymorphism through multiple ActiveX interfaces. In the Component Object Model (COM) that forms the infrastructure of the ActiveX specification, multiple interfaces allow systems of software components to evolve and break existing code.
    In this sense interface is a set of related properties and methods. Much of the ActiveX specification is concerned with implementing standard interfaces to obtain system services or to provide malfunctionality to other programs.
    The actual processes involved are in the meantime so messed up that it is a wonder that anything still works, and I doubt it will be long before nothing does.
    The large FileObject in the Microsoft Scripting Runtime Library Class type Module like Library has information , amongst other things of neighbouring things , and as is typical in this mixed up messed up process , a short tem path or highway is made, and more often than not a “text stream object”, something like a continuous stream of data or like a highways going around in circles, and this will only be of a runtime existence, or at any rate should.. during this lifetime it can be “read”. I guess for any file of any type data within it will be recognised as such and can be handled in this simple text stream way.
    The original coding goes quite a way back and does not really fit in Object Orientated Visual basic hierarchical structure of the original implementation of File I/O in Visual Basic. But it does at lest work well in getting at text stream string things which we are interested in
    The available methods and the such reflect all the above…
    -…So code will have a string getting section that..
    1(iii) sets up the data “stream highway”
    _.____
    I have decided for my requirement to use a “Function” for this, not just to house tidily the above steps, but also as I may add some additional bits from time to time too the main inner body string for my Email message, which the main function of this all is to produce.
    To recap on the Function idea here ( http://www.excelfox.com/forum/showth...blem#post10503 )
    In end effect I want a String. In fact in the main code in which this should be embedded has this as a variable
    Pseudo, Linked in my Binding Function, ObjectLinkedEbeded Stuff
    In place of an actual static linked variable_...
    Dim MyLenghtyString As String
    _ Let MyLenghtyString = “static linked at pseudo Compile String”
    _.. I have
    Function MyLenghyString(Export) As String
    _ Pall MyLenghyString()_Import
    _.. or Let MyLenghtyString = “direct linked runny runable library”
    The end result is that in my code I will have simply pulling of
    _ .HTMLBody = MyLengthyStreaming
    Function Code description:
    This uses the File System Object way discussed above to finally produce a long text string in variable _ MyLengthyStreaming _ This string probably has a of unnecessary stuff as well as the required part of the HTML code, but appears to be able to be handled and manipulated as if it were just the required part. Presumably the rest is ignored by things such as internet browsers
    This allows for some extra simple string data to be added. If you are not familiar with HTML code then you can easily get the required string from text to HTML converters of which there are many freely available in internet
    Note: If you have any in your required HTML string, then you will need to replace them in the given string in the VBA code with “”
    http://www.excelfox.com/forum/showth...rmat#post10448
    ' https://support.microsoft.com/en-in/kb/186118
    https://www.youtube.com/watch?v=nj8mU3ecwsM
    https://www.youtube.com/watch?v=f8s-jY9y220&t=1813s
    Note: ' path in code must be changed to reflect where you save .htm file
    Pubic Function MyLengthyStreaming() As String
    Dim FileObject As Object: Set FileObject = Fso.GetFile("G:\ALERMK2014Marz2016\NeueBlancoAb27.01.2014\AbJan2016\ProMessage.htm"): Debug.Print FileObject  ' path in code must be changed to reflect where you save it
     Textreme.Close
     Set Fso = Nothing
    HTML Code:
    MyLengthyStreaming = "[color=Black]<[/color]p[color=Black]>[/color][color=Black]<[/color]span style=""color: #ff00ff;""[color=Black]>[/color]Start=========== " & Format(Now(), "DD MMMM YYYY") & " " & Now() & " ------------------------------------[color=Black]<[/color]/span[color=Black]>[/color][color=Black]<[/color]/p[color=Black]>[/color]" & MyLengthyStreaming & "[color=Black]<[/color]p[color=Black]>[/color][color=Black]<[/color]span style=""color: #ff00ff;""[color=Black]>[/color]-- " & Format(Now(), "DD MMMM YYYY") & " " & Now() & " ==End, Sent from Doc.AElstein Mail ======[color=Black]<[/color]/span[color=Black]>[/color][color=Black]<[/color]/p[color=Black]>[/color]"
     Textreme.Close
     Set Fso = Nothing
    Results Example:
    Used htm Word File.JPG : https://imgur.com/mwihFBT
    "ProMessage.htm" ( Saved from Word as .htm ) : https://app.box.com/s/cbtodk5srg76a5lowfemrdvei91mfmdq
    Attachment 1969
    Recieved Email gmail.jpg : https://imgur.com/x0NybLa :
    Attachment 1972
    Recieved EMail Telekom : https://imgur.com/wqPJSCt
    Recieved EMail Telekom 2.JPG : https://imgur.com/o5mRkak
       '.To = "excelvbaexp@gmail.com"
    Attachment 1970Attachment 1971
    _.________________________________________________ ____________________________
    Uploaded file had to be done as .docx to get it to upload at excelfox ( .htm were not permitted to be uploaded )
    To use in code it must be resaved as .html ( ' and path in code must be changed to reflect where you save it )
    HTML Code seen in Text Editor
    HTML as seen in Text Editor, for this Post:
    http://www.excelfox.com/forum/showth...0524#post10524
    OpenProMessageHTMLWithTextEditor.JPG : https://imgur.com/4zev9Kv
    ProMessageHTMLInTextEditor.JPG : https://imgur.com/eTUd17q
    HTML Code:
    <body lang=DE style='tab-interval:35.4pt'>
    <div class=WordSection1>
    <p style='margin:0cm;margin-bottom:.0001pt'><span style='font-size:10.0pt;
    font-family:"Times","serif";color:black'>T <span class=SpellE>Andale</span>
    Mono</span></p>
    <p style='margin:0cm;margin-bottom:.0001pt'><span style='color:red'> </span><span
    style='font-size:10.0pt;font-family:"Arial","sans-serif";color:red'>T Arial</span></p>
    <p style='margin:0cm;margin-bottom:.0001pt'><span style='font-family:"Arial Black","sans-serif";
    color:#FF9900'>T Arial Black</span></p>
    font-family:"Comic Sans MS";color:#99CC00'>T Comic <span class=SpellE>Sans</span>
    MS</span></p>
    font-family:"Courier New";color:#33CCCC'>T Courier New</span></p>
    font-family:"Georgia","serif";color:#3366FF'>T Georgia</span></p>
    font-family:"Helvetica","sans-serif";color:purple'>T <span class=SpellE>Helvetics</span></span></p>
    font-family:"Impact","sans-serif";color:#999999'>T Impact</span></p>
    font-family:"Tahoma","sans-serif";color:#993300'>T <span class=SpellE>Tahoma</span></span></p>
    font-family:"monaco","serif";color:fuchsia'>T Terminal</span></p>
    color:olive'>T Times New Roman</span></p>
    font-family:"Trebuchet MS","sans-serif";color:#FF6600'>T <span class=SpellE>Trebuchet</span>
    MS</span></p>
    <p class=MsoNormalCxSpFirst><o:p> </o:p></p>
    <p class=MsoNormalCxSpMiddle><span style='font-size:9.0pt;line-height:115%;
    font-family:"Verdana","sans-serif";color:#C00000'>W9 <span class=SpellE>Verdana</span><o:p></o:p></span></p>
    <p class=MsoNormalCxSpMiddle><span style='font-family:"Arial Narrow","sans-serif";
    color:red'>W11 Arial <span class=SpellE>Narrow</span><o:p></o:p></span></p>
    <p class=MsoNormalCxSpMiddle><span style='font-size:14.0pt;line-height:115%;
    font-family:"Batang","serif";color:#FFC000'>W14 <span class=SpellE>Batang</span><o:p></o:p></span></p>
    <p class=MsoNormalCxSpMiddle><span style='font-size:16.0pt;line-height:115%;
    mso-ascii-font-family:Calibri;mso-fareast-font-family:Batang;mso-hansi-font-family:
    Calibri;color:#92D050'>W16 Calibri<o:p></o:p></span></p>
    <p class=MsoNormalCxSpMiddle><span style='font-size:18.0pt;line-height:115%;
    font-family:"Cambria Math","serif";mso-fareast-font-family:Batang;color:#00B050'>W18
    <span class=SpellE>Cambri</span> <span class=SpellE>Math</span><o:p></o:p></span></p>
    <p class=MsoNormalCxSpMiddle><span style='font-size:20.0pt;line-height:115%;
    font-family:FangSong;color:#00B050'>W20 <span class=SpellE>FangSong</span><o:p></o:p></span></p>
    <p class=MsoNormalCxSpMiddle><span style='font-size:22.0pt;line-height:115%;
    font-family:"Gungsuh","serif";color:#00B0F0'>W22 <span class=SpellE>Gungsuh</span><o:p></o:p></span></p>
    <p class=MsoNormalCxSpMiddle><span style='font-size:24.0pt;line-height:115%;
    font-family:GungsuhChe;color:#0070C0'>W24 <span class=SpellE>GungsuhChe</span></span><span
    style='font-size:24.0pt;line-height:115%;font-family:"Franklin Gothic Heavy","sans-serif";
    mso-fareast-font-family:Batang;color:#0070C0'> <o:p></o:p></span></p>
    <p class=MsoNormalCxSpMiddle><span style='font-size:26.0pt;line-height:115%;
    font-family:"Times New Roman","serif";mso-fareast-font-family:Batang;
    color:#002060'>W26 Times New Roman<o:p></o:p></span></p>
    <p class=MsoNormalCxSpLast><span style='font-size:28.0pt;line-height:115%;
    font-family:"Franklin Gothic Heavy","sans-serif";mso-fareast-font-family:Batang;
    color:#7030A0'>W28 Franklin <span class=SpellE>Gothic</span><span
    style='mso-spacerun:yes'>  </span>Heavy<o:p></o:p></span></p>
    </div>
    </body>
    </html>
    Modified initial function and additional second function for German telekom EMail workaround
    Function codes discussed in this Post:
    http://www.excelfox.com/forum/showth...0527#post10527
    Dim FileObject As Object: Set FileObject = Fso.GetFile("G:\ALERMK2014Marz2016\NeueBlancoAb27.01.2014\AbJan2016\ProMessageTelekom.htm"): Debug.Print FileObject
     Textreme.Close
     Set Fso = Nothing
     Let MyLengthyStreaming = MyLenghtyDiesScreaming_Telekom(MyLengthyStreaming) ' After this code line is done we have the string modified so that it gives the correct results in German Telekom Freemail t-online.de
    '  The second function below is mainly intended to make a modification to get the correct results in German Telekom Freemail t-online.de , but also the large html text not required from the start and a small amount at the end is also removed. (It does not need to be removed as it appears that it is ignored)
    Public Function MyLenghtyDiesScreaming_Telekom(ByVal MyLengfyScream As String) As String '  Effectively this Dim's  MyLenghtyDiesScreaming_Telekom  as a String variable and  MyLenghtyDiesScreaming_Telekom  can be used as such in this function code.  Assigning a variable to this in a main code will cause  the value held by VBA in the variable  MyLenghtyDiesScreaming_Telekom   at that point to be out in the assigned variable, but fist the main code will be paused at  this "calling"  code line whilst the Function code is carried out.  So we have the chance to do something in the function to fill that variable, MyLenghtyDiesScreaming_Telekom . We can take one or more things in in the ( ) to use . In this case we want to take a string in and then return it modified , hence the last code line is simply   MyLenghtyDiesScreaming_Telekom = MyLengfyScream
    Dim CntPus As Long '      A number constant for the positions of characters used in a couple of places.        Long is very simple to handle, - final memory "size" type is known (123.456 and 000.001 have same "size" computer memory ) , and so a Address suggestion can be given for the next line when the variable is filled in.  '( Long is a Big whole Number limit (-2,147,483,648 to 2,147,483,647) If you need some sort of validation the value should only be within the range of a Byte/Integer otherwise there's no point using anything but Long.--upon/after 32-bit, Integers (Short) need converted internally anyways, so a Long is actually faster. )       https://www.mrexcel.com/forum/excel-questions/803662-byte-backward-loop-4.html
    ' Take off all the first lot on unecessary required HTML
     Let CntPus = InStr(1, MyLengfyScream, "<div class=WordSection1>", vbTextCompare) '  return the position (starting from the fist character ,  Looking in the string  ,  for that text  ,  doing a text comparison which is case insensitive  )
     Let MyLengfyScream = Mid(MyLengfyScream, CntPus + 26)
    ' Add to this array below all possible fonts in quotes      I have to use Variant type as the VBA Array( ) Method used below pruduces a 1 dimmansional Array of Variant types.   I may assing a dynamic Array of variant types to what the VBA Array( ) Function returns
    Dim arsFonts() As Variant: Let arsFonts() = Array("""Andale Mono""", """Times""", """serif""", """Arial""", """sans-serif""", """Arial Black""", """Comic Sans MS""", """Courier New""", """Georgia""", """Helvetics""", """Impact""", """Tahoma""", """Terminal""", """monaco""", """Times New Roman""", """Trebuchet MS""", """Verdana""", """Arial Narrow""", """Batang""", """Calibri""", """Cambri Math""", """FangSong""", """Gungsuh""", """GungsuhChe""", """Franklin Gothic Heavy""")
    Dim arschFont As Variant ' It is a required syntax that the stearing element in the For Each loop to be Variant type or Object type, ( the object type can be  Object   or ther specific object. if I do not specify specifically then VBVA defaults to all simialr ngs in the thing you are going through        '  http://www.excelfox.com/forum/showthread.php/2157-Re-Defining-multiple-variables-in-VBA?p=10192#post10192
    ' Look for things like "Font"  and replace the " with an arbitrary string like ScrotumSack , so  "Font"  becomes  ScrotumSackFontScrotumSack
        For Each arschFont In arsFonts() ' Loop to look for and replce each Font held in "s with the same font but in 's
         If InStr(1, MyLengfyScream, arschFont, vbTextCompare) > 1 Then ' case a Font in quotes , like "font"  ,  so for that font in quotes... and ...
         Dim FontSingleScrQuote As String: Let FontSingleScrQuote = Replace(arschFont, """", "ScrotumSack", 1, 2, vbBinaryCompare) ' ...Make a that font in ScrotumSack  like ScrotumSackfontScrotumSack ... and ...     I use ScrotumSack arbitrarily as I find it funny and I doubt anyone else does.. does use it, so I won't have that already in the text. I cannot go straight to using the '  because if I do that now then I won't be able to distinguisch the existing ' which I want to change to "  in the next bit
          Let MyLengfyScream = Replace(MyLengfyScream, arschFont, FontSingleScrQuote, 1, -1, vbTextCompare) ' .... replace all "fonts" with ScrotumSackfontsScrotumSack
         Else '  no arsch Font in My lengfy scream
        Next arschFont
    ' replace any ' with "  This is mainly intended to replace enclosed in ' strings like   askjhhsa ='kasjhScrotumSackfontScrotumSackfcb qwq 63 = Bollocks' jdgsjag   with     askjhhsa ="kasjhScrotumSackfontScrotumSackfcb qwq 63 = Bollocks" jdgsjag
     Let MyLengfyScream = Replace(MyLengfyScream, "'", """", 1, -1, vbTextCompare)
    ' Scratch my Scrotum sacks, - that is to say replace them with a with  '   I can do this now since the existing  '  have been changeed to "  so the ScrotumSacks , which were originally "s , can now be chnged to 's
     Let MyLengfyScream = Replace(MyLengfyScream, "ScrotumSack", "'", 1, -1, vbTextCompare)
    ' take last unecessary bit of HTML off
     Let CntPus = InStrRev(MyLengfyScream, "</div>", -1, vbTextCompare) ' get the position counting from the left but looking from the right   ( in MyLengfyScream , of </div> , start looking from end , make text comparison which is case insensitive )
     Let MyLengfyScream = Left(MyLengfyScream, CntPus - 1)
    ' Finally we set here what is actually returned by virtue of effectively putting something in the pseudo variable  MyLenghtyDiesScreaming_Telekom
     Let MyLenghtyDiesScreaming_Telekom = MyLengfyScream
    Tests and notes required for Threads cocerning EMail and VBA
    http://www.excelfox.com/forum/showth...he-excel-sheet
    https://www.youtube.com/watch?v=bs-urI_o8jo&lc=UgyBACXgNY4j_cHgH5J4AaABAg.9oTkVdzfqfm9wlhQrYJP 3M
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgxoHAw8RwR7VmyVBUt4AaABAg.9C-br0lEl8V9xI0_6pCaR9
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=Ugz5DDCMqmHLeEjUU8t4AaABAg.9bl7m03Onql9xI-ar3Z0ME
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgxYnpd9leriPmc8rPd4AaABAg.9gdrYDocLIm9xI-2ZpVF-q
    https://www.youtube.com/watch?v=0ltJS7uHfK4&lc=UgyjoPLjNeIAOMVH_u94AaABAg.9id_Q3FO8Lp9xHyeYSuv 1I
    https://www.youtube.com/watch?v=LP9fz2DCMBE&lc=UgzbPgJUMCztIOQDym14AaABAg.9wdo_rWgxSH9wdpcYqrv p8
    In support of this thread:
    http://www.excelfox.com/forum/showth...ified-email-id
    ( Details: https://stackoverflow.com/questions/...51963#55451963 )
    Current working ( gmail send ) pro macro, October 2019
    Sub PetrasDailyProWay1_COM_Way(ByVal SmptySvrPrt) '  Allow access to deep down cods wollops from Microsoft to collaborating in particular in the form of messaging. An available library of ddl library functions and associated things is available on request, the  Microsoft CDO for Windows 2000. We require some of these '  CDO is an object library that exposes the interfaces of the Messaging Application Programming Interface (MAPI). API: interfaces that are fairly easy to use from a fairly higher level from within a higher level programming language. In other words this allows you to get at and use some of the stuff to do with the COM OLE Bollocks from within a programming language such as VBA  API is often referring loosely to do with using certain shipped with Windows software in Folders often having the extension dll. This extension , or rather the dll stands for direct link libraries. These are special sort of executable files of functions shared by many other (Windows based usually) software's.
     Call DieseArbeitsmappe1.FillMeGlobsUpMate
        '2a) 'With --------------------* my Created LCDCW Library, (LCD 1.0 Library ) (Linking Configuration Data_Cods Wollups) which are used and items configured for the Exchange at Microsoft's protocol thereof;   http://schemas.microsoft.com/cdo/configuration/ ......This section provides the configuration information for the remote SMTP server
        '  ' Sever info
         .Configuration(LCD_CW & "smtpserverport") = SmptySvrPrt  ' 465 or 25 for t-online.de ' 465 'or 587 'or 25   ' The port of type somehow refered to by the last line
         .Configuration(LCD_CW & "sendusername") = "123456789012345678909123456@gmail.com" '"123456789012@gmail.com"   '   "12345678901@gmail.com" ' "123456789012@t-online.de" ' .... "server rejected your response".  AFAIK : This will happen if you haven't setup an account in Outlook Express or Windows Mail .... Runtime error '-2147220975 (800440211)': The message could not be sent to the SMTP server. The transport error code is 0x80040217. The server response is not available
         .Configuration(LCD_CW & "sendpassword") = "123456789012345678"              '      "1234567890123"              '                   '  "123456789012345" '           "12345678901"
                                                     '.To = "123456@gmail.com"
       .To = "123456789012@t-online.de"
       '.To = "12345678901@gmail.com"
       .cc = "123456789012@gmail.com"
       .BCC = ""
       .from = """Stinkpflopp"" <12345678901234567890123456@gmail.com>"
       .Subject = "Pro für " & DieseArbeitsmappe1.LisWbProWb.Name
       '.htmlbody = ProTble
    ' Add all text file attachments
        Dim DirTxtFl As String: Let DirTxtFl = Dir(ThisWorkbook.Path & "\" & "*.txt")
            Do While DirTxtFl <> ""
                If VBA.Left$(DirTxtFl, 22) = "MonatsUebersichtAnhang" Then .AddAttachment ThisWorkbook.Path & "\" & DirTxtFl
             Let DirTxtFl = Dir
            Loop
       '.AddAttachment ThisDocument.Path & "\MallaMessage2.docm" '"G:\ALERMK2014Marz2016\NeueBlancoAb27.01.2014\AbJan2016\Übersicht aktuell.xlsx" ' ' Full File path and name. File must be closed
       '.AddAttachment ThisDocument.Path & "\MallaMessage2.txt"
    Rem 3 Do it initially attempt with  25  ,  then in Malta as well maybe with  465
      On Error GoTo Malta        ' Intended to catch a possible predicted error in the next line when running the routine in Malta, or/ and an error in the second attempt at a code run        ' if the next line errors, then I scheduule the routine to run again with  "smtpserverport") = 465
       .send
       MsgBox Prompt:="Done (with " & SmptySvrPrt & ")"                                               ' This will typically give either  "Done (with 25)"  or else  "Done (with 465)"  if the routine worked
    Exit Sub        ' Normal routine end for no error exceptional errected situation
    Malta:        ' Intended to catch a predicted error when running the routine in Malta, or/ and an error in the second attempt at a code run
        If SmptySvrPrt = "465" Then MsgBox Prompt:="Also did not work with  465  , Oh Poo!": Exit Sub ' case error with attempt with  465
     Application.OnTime Now(), "'" & ThisWorkbook.Path & "\" & "NeuProAktuelleMakros.xlsm'" & "!'ProAktuelleMacrosMtsch.PetrasDailyProWay1_COM_Way ""465""'"
    ' On Error GoTo -1: On Error GoTo 0                                                               ' I do not need this as the  End Sub  will effectively bring down the errection state
    Sub plopy(ByVal stink As String)
    In Support of this Thread
    https://telekomhilft.telekom.de/t5/E-Mail-Programme/Die-Nachricht-wurde-nicht-an-den-SMTP-Server-gesendet-werden-Der/m-p/4219080#M72050
    https://telekomhilft.telekom.de/t5/E...4219080#M72050
    https://telekomhilft.telekom.de/t5/E...4229774#M72110
    Main procedure, ( example Calling procedure in next post )
    Sub GermanTelekom_Send_FromTests(ByVal UsrNme As String, ByVal PsWd As String, ByVal CDO_Msg_Find As String)  ' CDO_Msg_Find used here is a local variable belonging to this routine - it "dies" when the routine ends: it is seperate from CDO_Msg_Find in the calling routine - I could have used different names in the two routines and that would have had no effect on anything
       With CreateObject("CDO.Message") '                  ' -------------------*  with LCDCW Library ( Linking Configuration Data Cods Wollups)  which are  used and items configured for the Exchange at Microsoft's protocol therof
         .Configuration(LCD_CW & "smtpusessl") = "True" '
        '  ' Sever info
         .Configuration(LCD_CW & "smtpserver") = "securesmtp.t-online.de" '
         .Configuration(LCD_CW & "smtpserverport") = 465 ' or 465
         .Configuration(LCD_CW & "sendusername") = UsrNme   '
         .Configuration(LCD_CW & "sendpassword") = PsWd
         .Configuration.fields.Update '
        'End With                                          ' -------------------* End with LCDCW Library ( Linking Configuration Data Cods Wollups)  which are  used and items configured for the Exchange at Microsoft's protocol therof
        ' Data to be sent
        .CC = "" ' "mail2taste@gmail.com"
        .BCC = ""
        .From = CDO_Msg_Find
        .Subject = "Hello from  " & UsrNme & "   using  GermanTelekom_Send_FromTests"     '
        .TextBody = "Hi" & vbCr & vbLf & "Testing. Please ignoor this EMail"
        ' Do it
         On Error GoTo Bed        ' Intended to catch a possible predicted error in the next line when running the routine
          .send
        Debug.Print "Done " & Format(Now(), "hh mm") & "    with Username:  " & UsrNme & vbCr & vbLf
        End With '                                                       End With  CreateObject("CDO.Message") (Rem 1 Library End =======#
    Bed:
     Debug.Print "Fail " & Format(Now(), "hh mm") & "    with Username:  " & UsrNme & vbCr & vbLf & "  " & Err.Number & ":  " & Err.Description & vbCr & vbLf
    Example Calling procedure for previous post
    Sub Testies_GermanTelekom_Send_FromTests()  '   https://telekomhilft.telekom.de/t5/E-Mail-Programme/Die-Nachricht-wurde-nicht-an-den-SMTP-Server-gesendet-werden-Der/m-p/4219080#M72050
    Dim CDO_Msg_Find As String
    '_1) Some basic points: ( Relevant for when there in no < > pair in the .From string, and no Commas  ,  )
    Let CDO_Msg_Find = "  f    @wx"
     Call GermanTelekom_Send_FromTests("MaxHaedroom@t-online.de", "MaxHaedSend", CDO_Msg_Find): Call GermanTelekom_Send_FromTests("Bouncing-Tigger@t-online.de", "Tiggysending.!*", CDO_Msg_Find)
    Let CDO_Msg_Find = "  f n   @wxyz     "
    Let CDO_Msg_Find = "  f n   ""k@wxyz""       "
    Let CDO_Msg_Find = "  f    @w  x    "   ' Fail: contradicts _1(ii)
    '       -2147220979:  Es ist mindestens eines der Felder "Von" oder "Absender" erforderlich, es wurde jedoch keines der Felder gefunden.
    Let CDO_Msg_Find = "e   g  ""@wxyz   ""  "    '  Fail: conradicts _1(ii)
    Let CDO_Msg_Find = "@wxyz"   '  Fail: contradicts _1(vi)
    '        -2147220975:  Die Nachricht konnte nicht an den SMTP-Server gesendet werden. Der Transportfehlercode lautet 0x800ccc6f. Die Serverantwort lautet 554 5.7.1 Database error. / This is not one of your allowed aliases              -2147220975:  Die Nachricht konnte nicht an den SMTP-Server gesendet werden. Der Transportfehlercode lautet 0x800ccc6f. Die Serverantwort lautet 554 5.7.1 Database error. / Der angegebene Absender ist keiner Ihrer erlaubten Aliase.
    Let CDO_Msg_Find = "e f 1234   g  hash@wxyz   "
    Let CDO_Msg_Find = "e f ""1234""   g  hash@wxyz   "
    Let CDO_Msg_Find = "This is a very long piece of text. It seems to have no effect        kjsh 12345   g  hash@wxyz   "
    Let CDO_Msg_Find = "This is a very long piece of text. It seems to have no effect    Dies ist ein sehr langer Text. Es scheint keine Wirkung zu haben     kjsh 12345   g  hash@wxyz   "
    '  In the above working examples, for example, imagine an Email address such as  MaxHaedroom@t-online.de ,
    ' Then in that case , I would see this in the InBox list , .._
    ' MaxHaedroom InBox.JPG :  https://imgur.com/qxZyvAO , https://imgur.com/pou2a45
    '_.. and this is how the Email looks
    '    Von_ MaxHaedroom in EMail.JPG : https://imgur.com/fXDCQO7
    '_--------------------------------
    '_2) Choosing the text in the InBox list.
    '_2a)  Using a single comma ,
    '-2a)(i) Using a comma at some distant point to the right of a long text
    Let CDO_Msg_Find = "12345678,9012345678901234567890 This is a very long piece of text. It ..... ..... kjsh 12345   g  hash@wxyz   "
    '_2b) Multiple commas
    Let CDO_Msg_Find = "12345678,9012345678901234567890 This is a very long piece of te , xt. It ..... ..... kjsh 12345   g  hash@wxyz   "
    '2)c) The effect of quotes in the string
    '2)c)(i) We no longer can have a space before the @ if we want to choose the InBox text ,...  This will not error, and the Email will  be sent. But The InBox will show the Email address used in the program's sendusername code line       .From = "  nnnnnn  f "" n     m n"" n @wx   "
    Let CDO_Msg_Find = "  nnnnnn  f "" n     m n"" n@wx   "
    ' 2c)(iii) ... the position of the first quote seems irrelevant
    Let CDO_Msg_Find = "  n""nnnnn  f  n     m n"" n@wx   "
    Let CDO_Msg_Find = "  n""nnnnn  f  n     m n""n@wx   "
    ' 2c)(iv) The position of the second quote pair is important, the next two are OK....
    Let CDO_Msg_Find = "n""nnnnn  f  n     m n""n@wx   "
    ' ... the next will result in the InBox text reverting back to the Email address used in the program's sendusername code line
    Let CDO_Msg_Find = "  n""nnnnn  f  n     m n""       y     n@wx   "
    ' 2d) effect of comer and quotes combination
    ' 2d)(i) If a comer appears within the pair of VBA quotes, then it is taken as a simple literal comer, rather than "text choice type" of comer discussed in 2a) and 2b)
    Let CDO_Msg_Find = "hhkhk,h  n""nnnn,n  f  n     m n""            n@wx   "
    ' In InBox list is  hhkhk , h n nnnn,n f n m n
    ' 2d(ii)
    Let CDO_Msg_Find = "hhkhk,h  n""nnnn,n  f  n     m n""       kk     n@wx   "
    ' In InBox list      hhkhk ,
    ' 2e) Use of <   >  within the .From string
    ' Here 5 working examples for 2e)
    Let CDO_Msg_Find = "hh  <  9  @  > ggt      <   jjhh""h "" h  @ kk 89  uit>  nn mk"
    ' in InBox list is    hh ggt nn mk
    Let CDO_Msg_Find = "  <   jjhh""h "" h  @ kk 89  uit> "
    ' in InBox list is ...  In this case  in the InBox will be  the Email address used in the program's sendusername code line , (  unless the Email is recognised as one in your address book, in which case the name from your address book will be shown )
    Let CDO_Msg_Find = " m <   jjhh""h "" h  @ kk 89  uit> n"
    ' in InBox list is     m n
    Let CDO_Msg_Find = "hh  <  9  @ m > ggt      <   jjhh""h "" h  @ kk 89  uit>  nn mk"
    Let CDO_Msg_Find = "hh  ""<  @  >"" ggt      <   jjhh""h "" h  @ kk 89  uit>  nn mk"
    ' in InBox list is    hh @ ggt nn mk
    Let CDO_Msg_Find = "hh  ""<  Spammer@t-online.de  >"" ggt      <   jjhh""h "" h  @ kk 89  uit>  nn mk"
    ' in InBox list is    hh Spammer@t-online.de..
    '  Note: in the last 5 examples, after the Von: In the Email , the shown text string will appear , (  unless the Email is recognised as one in your address book, in which case the name from your address book will be shown. This is perhaps  a bit unexpected, as it is replacing the shown text string with the name, rather than replacing the Email address with the name, as was noted as the case in 1)  !!! )
    ' 2e)(v) The following two examples will error:          -2147220975:  Die Nachricht konnte nicht an den SMTP-Server gesendet werden. Der Transportfehlercode lautet 0x800ccc6f. Die Serverantwort lautet 554 5.7.1 Database error. / This is not one of your allowed aliases              -2147220975:  Die Nachricht konnte nicht an den SMTP-Server gesendet werden. Der Transportfehlercode lautet 0x800ccc6f. Die Serverantwort lautet 554 5.7.1 Database error. / Der angegebene Absender ist keiner Ihrer erlaubten Aliase.
    Let CDO_Msg_Find = "hh  <    @ x > ggt      <   jjhh""h "" h  @ kk 89  uit>  nn mk"
    Let CDO_Msg_Find = "hh  <    @  > ggt      <   jjhh""h "" h  @ kk 89  uit>  nn mk"
    '_------------------------------------
    'Let CDO_Msg_Find = ""
    ' Call GermanTelekom_Send_FromTests("MaxHaedroom@t-online.de", "MaxHaedSend", CDO_Msg_Find): Call GermanTelekom_Send_FromTests("Bouncing-Tigger@t-online.de", "Tiggysending.!*", CDO_Msg_Find)
    Post to be added to later
    ( need the url first )
  3. Table Tests. And Thread Copy Tests No Reply needed
  4. Replies: 9
    Last Post: 07-02-2013, 06:59 PM
  5. Send Lotus Notes Email Using VBA
    Last Post: 09-08-2011, 09:00 AM
