Thread: Create Random Number Generator VBA
    Lightbulb Create Random Number Generator VBA
    Hi All,
    Here is a UDF to create random number generator. Option to generate unique values as well(by default it's TRUE).
    Function RANDOMNUMGENERATOR(ByVal MinVal As Long, ByVal MaxVal As Long, _
                        ByVal HowMany As Long, Optional ByVal UNIQUE As Boolean = True)
        '// Created by  : Krishnakumar @ ExcelFox.com
        Dim i As Long, Diff     As Long
        Dim RNG() As Long, n    As Long
        Dim AC, RowsCount       As Long
        Dim ColCount            As Long
        Set AC = Application.Caller
        If Err.Number <> 0 Then
            Err.Clear: On Error GoTo 0: GoTo 2:
        If TypeName(AC) <> "Range" Then Exit Function
        RowsCount = AC.Rows.Count
        ColCount = AC.Columns.Count
        RANDOMNUMGENERATOR = CVErr(xlErrNum)
        If RowsCount > 1 And ColCount <> 1 Then Exit Function
        If RowsCount <> 1 And ColCount > 1 Then Exit Function
        If RowsCount >= 1 And ColCount = 1 Then
            If HowMany <> RowsCount Then Exit Function
        If ColCount >= 1 And RowsCount = 1 Then
            If HowMany <> ColCount Then Exit Function
        Diff = MaxVal - MinVal
        RANDOMNUMGENERATOR = Empty
        If UNIQUE Then
            With CreateObject("scripting.dictionary")
                Do While .Count <= HowMany - 1
                    Randomize
                    .Item(MinVal + Int(Rnd * Diff)) = Empty
                Loop
                RANDOMNUMGENERATOR = Application.Transpose(.keys)
            n = 1
            Do While n <= HowMany
                RNG(n) = MinVal + Int(Rnd * Diff)
                n = n + 1
            Loop
            RANDOMNUMGENERATOR = Application.Transpose(RNG)
    To use select a range, for e.g. if you want to generate 10 random numbers,
    select A1:A10 > apply the formula > hit CTRL + SHIFT + ENTER
    Here is another improved version.
                Optional HowMany As Long, Optional ByVal UNIQUE As Boolean = True)
        Dim Diff As Long, Tot   As Long
        Dim tmp, ColCount       As Long
        Dim r As Long, c        As Long
            RANDOMNUMGENERATOR = CVErr(xlErrRef)
            Exit Function
        Application.Volatile
        Tot = RowsCount * ColCount
        If HowMany <> Tot Then HowMany = Tot
        ReDim RNG(1 To RowsCount, 1 To ColCount)
    2:
        If UNIQUE Then
                    Randomize
                Loop
                tmp = .keys
                For r = 1 To RowsCount
                    For c = 1 To ColCount
                        RNG(r, c) = tmp(n)
                        n = n + 1
                RANDOMNUMGENERATOR = RNG 'Application.Transpose(.keys)
                    RNG(r, c) = MinVal + Int(Rnd * Diff)
    Use like
    Array enter
    =RANDOMNUMGENERATOR(1,100)
    in A1:B10 or
    A1:A10 or
    A1:J1
  1. Get Random List :
  2. Dynamic Worksheet Generator Sheet Copy
    By mfaisalrazzak in forum Excel Help
    Last Post: 03-01-2013, 05:38 PM
  3. Unique Random Number In Ascending Order
    Last Post: 11-04-2012, 04:15 PM
  4. Random Unique Number Generator Excel VBA
    Last Post: 10-18-2012, 01:00 PM
  5. Generate random numbers in Excel
    By Mahesh in forum Excel Help
    Last Post: 10-06-2011, 11:24 AM
