Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: copy,paste,calculate Cell value based on calculations & comparisonsother cells same row. Decimal places
    Jul 2019
    “Moderator” Notice
    September 2020
    Given up with this “OP” , Avinash around September 2020. https://excelfox.com/forum/showthrea...ll=1#post14972
    I am no longer monitoring what its doings. It had curiosity appeal for a while, but even that has worn off me now!
    It’s getting worse by the Day. Its still doing whatever it is that it is doing and getting Replies and answers at excelforum.com and likely a few places I don’t know about.
    vba code will be placed in a seperate file macro.xlsm
    i have one more file 1.xls (all files are located in a different path)
    i have attached a sample pic of 1.xls & result pic too
    check if Column H is greater or lower than column D
    if column H is greater than column D then calculate 1% of column H and paste it to column J and then subtract Column H & column J and paste the result to column K
    Or
    if column H is lower than column D then calculate 1% of column H and paste it to column J and then add Column H & column J and paste the result to column K
    Plz help me in solving this problem sir
    Almost the same as from MoldyBread at excelforum
    https://www.excelforum.com/excel-pro...ml#post5338184
    Some more recent cross posted duplicsate on another one of Avinashes infinite cycles of starting again
    https://eileenslounge.com/viewtopic.php?f=30&t=34932
    https://chandoo.org/forum/threads/pu...9/#post-266257 ( Leonardo1234 starting again )
    This is so simple, that even I find it easy to do, with a formula...
    J
    K
    NSE ACC EQ
    1087
    1030
    955.5
    998.45
    1079.9
    22
    =IF(H2>D2,1/100*H2,IF(H2))
    =IF(H2>D2,H2-J2,IF(H2))
    NSE ADANIPOWER EQ
    148.05
    27.75
    25.65
    25.65
    146.5
    25
    =IF(H3>D3,1/100*H3,IF(H3))
    =IF(H3>D3,H3-J3,IF(H3))
    NSE DLF EQ
    265
    419.7
    350.05
    387.25
    267.15
    17388
    =IF(H4>D4,1/100*H4,IF(H4))
    =IF(H4>D4,H4-J4,IF(H4))
    NSE AMBUJACEM EQ
    30.4
    155.8
    142.55
    145.85
    29.95
    15083
    =IF(H5>D5,1/100*H5,IF(H5))
    =IF(H5>D5,H5-J5,IF(H5))
    Worksheet: 1-Sheet1
    J
    K
    NSE ACC EQ
    1087
    1030
    955.5
    998.45
    1079.9
    22
    NSE ADANIPOWER EQ
    148.05
    27.75
    25.65
    25.65
    146.5
    25
    NSE DLF EQ
    265
    419.7
    350.05
    387.25
    267.15
    17388
    NSE AMBUJACEM EQ
    30.4
    155.8
    142.55
    145.85
    29.95
    15083
    Worksheet: 1-Sheet1
    Each formula uses 2 Excel If functions, one is nested in the other...
    (    If  _>_   , Do this ,  Else [ If _<_ , Do this  , Else "......"    ]    )
        If ( _>_   , Do this ,  Else  If( _<_ , Do this  , Else "......"    )    )
    Column J
      =IF(H2>D2,1/100*H2,
                         IF(H2Else
                                           "D is equal to H"))
    Column K
     if column H is greater than column D subtract Column H & column J
      =IF(H2>D2,H2-J2,
               if column H is lower than column D  add Column H & column J
                      IF(H2Else
                                       "D is equal to H"))
    https://support.office.com/en-us/art...rs=en-US&ad=US
    https://www.techonthenet.com/excel/formulas/if.php
    _...KILL A MODERATOR!!
    Jul 2019
    Sub STEP8()
      Dim Wb1 As Workbook, Ws1 As Worksheet, Lr1 As Long
      Set Wb1 = Workbooks.Open("C:\Users\WolfieeeStyle\Desktop\1.xls")
      Set Ws1 = Wb1.Worksheets.Item(1)
      Let Lr1 = Ws1.Range("H" & Ws1.Rows.Count).End(xlUp).Row
       Ws1.Range("J2:J" & Lr1 & "").Value = "=IF(H2>D2,1/100*H2,IF(H2
    Doc Sir i am getting error sir i dont know why i got it plz have a look sir
    http://www.eileenslounge.com/viewtopic.php?f=30&t=34670
    Your macro is very good.
    You have written good coding.
    It is almost perfect.
    There is just one very small problem. It is just because VBA is confused when quotes are inside quotes. VBA does not like to see quotes inside other quotes. It get confused.
    If VBA see this: …_
    _.. VBA does not know what it is. VBA thinks maybe it is either this
    or this
    VBA does not like to see inside quotes 1 quote or 3 quotes or 5 quotes … etc
    VBA must always see 2 quotes "" ( or 4 quotes m"""", or 6 quotes """""" )etc..
    We must do a trick , like this
    Or this:
    If you do this trick, then VBA will see for "" just one quote.
    So in your macro , like this is the problem: "________"_D is equal to H_"____"
    "=IF(H2>D2,1/100*H2,IF(H2"D is equal to H"))"
    We must do trick: "________""_D is equal to H_""____"
    "=IF(H2>D2,1/100*H2,IF(H2""D is equal to H""))"
    So in your macro,
    change the single quotes inside the outermost enclosing quotes to double quotes
    like this:
    ______________Ws1.Range(" 2: " & Lr1 & "").Value =__"__________""_D is equal to H_""____"
    Sub STEP8()
       Ws1.Range("J2:J" & Lr1 & "").Value = "=IF(H2>D2,1/100*H2,IF(H2""D is equal to H""))"
       Ws1.Range("J2:J" & Lr1 & "").Value = Ws1.Range("J2:J" & Lr1 & "").Value
       Ws1.Range("K2:K" & Lr1 & "").Value = "=IF(H2>D2,H2-J2,IF(H2""D is equal to H""))"
       Ws1.Range("K2:K" & Lr1 & "").Value = Ws1.Range("K2:K" & Lr1 & "").Value
       Wb1.Save
       Wb1.Close
    You did almost perfect in your macro. It was very close.
    Jul 2019
    remove third number after decimal and then remove the decimal
    I will place the macro in a seperate file macro.xlsm
    and i have a file name 1.xls
    in 1.xls in column K i have data (i have attached the sample pic of that)
    what i need is i need a macro that will remove third number after decimal and along with it it should remove the decimal
    Result will be
    1090.699 after runing the macro the ouput will be 109069
    147.965 after runing the macro the ouput will be 14796
    264.4785 after runing the macro the ouput will be 26447
    30.2495 after runing the macro the ouput will be 3024
    plz help me in solving this problem by vba
    Using simple VBA techniques
    ' We can find the position of the . using Instr function https://docs.microsoft.com/en-us/off...instr-function
    ' Then we can take the left of the number for a length equal to the position of the . + 2 using the Left function https://docs.microsoft.com/en-us/off.../left-function
    ' Then we can remove the . using the Replace function , https://docs.microsoft.com/en-us/off...place-function
    Sub TrimRemoveDot() '  http://www.excelfox.com/forum/showthread.php/2456-Remove-decimals-by-vba?p=13068#post13068
    Dim Ws1 As Worksheet
     Set Ws1 = Workbooks("1.xls").Worksheets.Item(1) ' First worksheet in open workbooks 1.xls
     Dim LrK As Long: Let LrK = Ws1.Range("K" & Ws1.Rows.Count & "").End(xlUp).Row
    Dim RngK As Range: Set RngK = Ws1.Range("K2:K" & LrK & "")
    Dim SnglCel As Range
        For Each SnglCel In RngK
        Dim Pos As Long: Let Pos = InStr(1, SnglCel.Value, ".", vbBinaryCompare)      '    We can find the position of the . using Instr function                                                            https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/instr-function
         Let SnglCel.Value = Left(SnglCel.Value, Pos + 2)                             '    Then we can take the left of the number for a length equal to the position of the . + 2 using the Left function   https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/left-function
         Let SnglCel.Value = Replace(SnglCel.Value, ".", "", 1, -1, vbBinaryCompare)  '    Then we can remove the . using the Replace function                                                               https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/replace-function
        Next SnglCel
    Or using formulas
    K
    264.4785
    30.2495
    Worksheet: 1-Sheet1
    L
    M
    N
    O
    =FIND(".",K2)
    =LEFT(K2,L8+2) =SUBSTITUTE(M8,".","") =SUBSTITUTE(LEFT(K2,FIND(".",K2)+2),".","")
    =FIND(".",K3)
    =LEFT(K3,L9+2) =SUBSTITUTE(M9,".","") =SUBSTITUTE(LEFT(K3,FIND(".",K3)+2),".","")
    =FIND(".",K4)
    =LEFT(K4,L10+2) =SUBSTITUTE(M10,".","") =SUBSTITUTE(LEFT(K4,FIND(".",K4)+2),".","")
    =FIND(".",K5)
    =LEFT(K5,L11+2) =SUBSTITUTE(M11,".","") =SUBSTITUTE(LEFT(K5,FIND(".",K5)+2),".","")
    Worksheet: 1-Sheet1
    L
    M
    N
    O
    1090.69 109069 109069
    147.96 14796 14796
    264.47 26447 26447
    Worksheet: 1-Sheet1
    Or using a final formula in Evaluate Range One liner technique
    Sub EvaluateRangeTrimRemoveDot() '  http://www.excelfox.com/forum/showthread.php/2456-Remove-decimals-by-vba?p=13068#post13068
     Let RngK.Value = Evaluate("=if({1},SUBSTITUTE(LEFT(" & RngK.Address & ",FIND("".""," & RngK.Address & ")+2),""."",""""))")
    Jul 2019
    Thnx Alot Doc Sir for ur Great Support
    Problem Solved
    Sir Moderator sandy666's Avatar
    May 2018
    Cool
    just for fun with Power Query
    let
        Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content],
        Split = Table.SplitColumn(Table.TransformColumnTypes(Source, {{"raw", type text}}, "en-GB"), "raw", Splitter.SplitTextByDelimiter(".", QuoteStyle.Csv), {"raw.1", "raw.2"}),
        Extract = Table.TransformColumns(Split, {{"raw.2", each Text.Start(Text.From(_, "en-GB"), 2), type text}}),
        Merge = Table.CombineColumns(Table.TransformColumnTypes(Extract, {{"raw.1", type text}}, "en-GB"),{"raw.1", "raw.2"},Combiner.CombineTextByDelimiter("", QuoteStyle.None),"Result"),
        Type = Table.TransformColumnTypes(Merge,{{"Result", Int64.Type}})
    in
        Type
    raw Result
    1090.699
    109069
    147.965
    14796
    264.4785
    26447
    30.2495
    3024
    should be ok
    thanks Alan
    sandy
    I know you know but I forgot my Crystal Ball and don't know what you know also I may not remember what I did weeks, months or years ago so answer asap. Thinking doesn't hurt
    Another obvious solution which I missed…
    K
    L
    109069
    14796
    264.4785
    26447
    30.2495
    3024
    K
    L
    =INT(K2*100)
    =INT(K3*100)
    264.4785
    =INT(K4*100)
    30.2495
    =INT(K5*100)
    And thank you Mr Sandy sir, for your interesting alternative solution
    Jul 2019
    Thnx Sandy Sir for ur great help
  1. Replies: 26
    Last Post: 09-26-2020, 05:56 PM
  2. Replies: 6
    Last Post: 08-28-2019, 09:42 AM
  3. copy data and paste it in another sheet
    By newbie2 in forum Excel Help
    Last Post: 07-15-2015, 01:38 PM
  4. Trapping Copy To Range Before Copy/Cut Paste
    Last Post: 04-07-2011, 07:48 PM
