Results 1 to 1 of 1
Thread: PQ - UnZip an use Content in Power Query
    Sir Moderator sandy666's Avatar
    May 2018
    Cool PQ - UnZip an use Content in Power Query
    it works for local files but not from web/url (at least I failed)
    (ZIPFile) =>
    let
        Header = BinaryFormat.Record([
            MiscHeader = BinaryFormat.Binary(14),
            BinarySize = BinaryFormat.ByteOrder(BinaryFormat.UnsignedInteger32, ByteOrder.LittleEndian),
            FileSize   = BinaryFormat.ByteOrder(BinaryFormat.UnsignedInteger32, ByteOrder.LittleEndian),
            FileNameLen= BinaryFormat.ByteOrder(BinaryFormat.UnsignedInteger16, ByteOrder.LittleEndian),
            ExtrasLen  = BinaryFormat.ByteOrder(BinaryFormat.UnsignedInteger16, ByteOrder.LittleEndian)
        HeaderChoice = BinaryFormat.Choice(
            each if _ <> 67324752             // not the IsValid number? then return a dummy formatter
                then BinaryFormat.Record([IsValid = false, Filename=null, Content=null])
                else BinaryFormat.Choice(
                        BinaryFormat.Binary(26),      // Header payload - 14+4+4+2+2
                        each BinaryFormat.Record([
                            IsValid  = true,
                            Filename = BinaryFormat.Text(Header(_)[FileNameLen]),
                            Extras   = BinaryFormat.Text(Header(_)[ExtrasLen]),
                            Content  = BinaryFormat.Transform(
                                BinaryFormat.Binary(Header(_)[BinarySize]),
                                (x) => try Binary.Buffer(Binary.Decompress(x, Compression.Deflate)) otherwise null
                            type binary                   // enable streaming
        ZipFormat = BinaryFormat.List(HeaderChoice, each _[IsValid] = true),
        Entries = List.Transform(
            List.RemoveLastN( ZipFormat(ZIPFile), 1),
            (e) => [FileName = e[Filename], Content = e[Content] ]
    in
        Table.FromRecords(Entries)
    create function from code above, rename to UnzipContents
    then create Query with code:
    let
        Source = File.Contents("full path to your zip file"),
        Files = UnzipContents(Source)
    in
        Files
    use gear on the right side of Source step to choose a zip file
    https://i.postimg.cc/xjyn2vVs/unzip.png
    sandy
    I know you know but I forgot my Crystal Ball and don't know what you know also I may not remember what I did weeks, months or years ago so answer asap. Thinking doesn't hurt
  1. Access Query Help
    By Vipergs8v10 in forum Access Help
    Last Post: 05-08-2013, 06:32 PM
  2. Dynamic Chart Query
    Last Post: 11-26-2012, 04:50 PM
  3. Excel found unreadable content
    By zyousafi in forum Excel Help
    Last Post: 08-08-2012, 10:41 AM
  4. Unzip FilesBy VBA
    Last Post: 05-14-2012, 12:11 AM
