Results 1 to 9 of 9
Thread: Msgbox notification with paasword by vba macro
    Jul 2019
    I am looking for a macro that will do the things mentioned below
    when i run the macro it should create a msg box stating "upload the file" & that msgbox can only be closed by paasword & paasword will be 1234
    without paasword that msgbox shouldn't be closed or disappear
    So plz have a look & help me in solving this problem
    Thnx in Advance
    https://www.excelforum.com/excel-pro...ml#post5356703
    Jul 2019
    Sub ABC()
    If TextBox1 = "" Then
        MsgBox "PLEASE ENTER THE PASSWORD", vbInformation, ""
        TextBox1.SetFocus
    ElseIf TextBox1 = "1234" Then
        MsgBox "SUCCESSFUL"
        Application.Visible = True
        Unload Me
        MsgBox "THAT PASWWORD IS INCORRECT", vbInformation, ""
        TextBox1 = ""
        TextBox1.SetFocus
    Sub CommandButton2_Click()
    MsgBox "THIS CONTAINS YOUR CODE THAT UPLOADS THE FILE"
    Sub UserForm_Initialize()
    Call SystemButtonSettings(Me, False)
    I got this
    i need only 1 macro that will do the things
    Feb 2017
    You can't do that with a Message Box.
    You will need to create a UserForm that looks like a Message Box and include the macro for the password.
    Jul 2019
    Yes I am looking for the same only
    But I don't know how to do it Logit Sir
    Feb 2017
    Jul 2019
    I am unable to make it Logit Sir
    Could u make it & provide it to me Sir
    It will be a Great Help
    Jul 2019
    Avinash,
    If you get an answer somewhere else, Then
    Please always give the solution, ( and if you can, then explain it also )
    Please always give a URL link to the solution
    Please do this in all places that you cross post
    You have already been asked to do that here and in other places. You still don’t always do it. It is your choice, - do what you want. But if I ever see that you do not do it anywhere ever again, then I will choose to Ban you here and also in some other places. Just my choice , that’s all
    _...KILL A MODERATOR!!
    Jul 2019
    Sure Sir
    It will not be repeated
    I am posting the solution here also
    Sub Upload()  '   https://eileenslounge.com/viewtopic.php?p=271231#p271231
        Do
        Loop Until InputBox(Prompt:="Enter password", Title:="Upload the file") = "1234"
  1. VBA Macro to open a file and extract data
    By jeremiah_j2k in forum Excel Help
    Last Post: 05-22-2017, 03:17 PM
  2. Excel VBA/Macro Help required URGENT
    By shushom in forum Excel Help
    Last Post: 09-20-2016, 11:24 PM
  3. VBA Macro for Bulks and an attachment
    By UsmanKhalid in forum Excel Help
    Last Post: 01-27-2014, 12:13 PM
  4. SQL output from Excel VBA macro
    By goldenbutter in forum Excel Help
    Last Post: 05-07-2013, 08:07 PM
  5. Replies: 11
    Last Post: 11-10-2011, 12:32 AM
