Page 5 of 56 FirstFirst ... 345671555 ... LastLast
Results 41 to 50 of 551
Thread: Tests Copying pasting Cliipboard issues
  1. #41
    Table from above again
    Using Excel 2007 32 bit
    J
    K
    Weekly
    Date of Service
    Weekly
    Next Service
    Monthly
    Date of Service
    Monthly
    Next Service
    Quarterly
    Date of Service
    Quarterly
    Next Service
    06.04.2018
    13.04.2018
    15.03.2018
    12.04.2018
    N/A
    N/A
    11.04.2018
    18.04.2018
    28.03.2018
    25.04.2018
    N/A
    N/A
    06.04.2018
    13.04.2018
    15.03.2018
    12.04.2018
    N/A
    N/A
    N/A
    N/A
    16.03.2018
    13.04.2018
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    10.04.2018
    17.04.2018
    N/A
    N/A
    09.03.2018
    06.04.2018
    23.04.2018
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    04.04.2018
    02.05.2018
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    13
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    14
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    15
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    16
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    17
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    18
    06.04.2018
    13.04.2018
    N/A
    N/A
    N/A
    N/A
    19
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    20
    N/A
    N/A
    N/A
    N/A
    15.02.2018
    15.03.2018
    21
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    22
    28.01.1900
    Worksheet: Equipment PM
    _...KILL A MODERATOR!!
  2. #42
    Code for this Thread:
    http://www.excelfox.com/forum/showth...and-send-email
    Private Sub Workbook_Open()
    Rem 1 Worksheets Info.
    Dim Ws As Worksheet: Set Ws = ThisWorkbook.Worksheets("Equipment PM")
    Dim Lr As Long: Let Lr = Ws.Range("A" & Ws.Rows.Count & "").End(xlUp).Row
    Rem 2 data range
    Dim arrIn() As Variant: Let arrIn() = Ws.Range("A1:K" & Lr & "").Value2
    Rem 3 Todays date as Double(Long) number
    Dim TdyDbl As Long: Let TdyDbl = CLng(Now()) ' like 43233 for 13 May 2018
     Let TdyDbl = CLng(DateSerial(2018, 3, 15)) - 3 ' To test only #####
    Rem 4 Rows for due date for next service for weekly(G), Monthly(I), and Quarterly(K). Code to pick up the date from these columns and automatic send email notification 3 days before the due date.
    '4a) determine rows as string or those row numbers
    Dim Rw As Long
        For Rw = 4 To Lr Step 1
            If arrIn(Rw, 7) = TdyDbl + 3 Or arrIn(Rw, 9) = TdyDbl + 3 Or arrIn(Rw, 11) = TdyDbl + 3 Then
        Dim strRws As String 'String of rows for criteria met in  G   Or  I  Or  K
         Let strRws = strRws & " " & Rw
            Else ' No "3 days before due service date" criteria met for this row
        Next Rw
        If strRws = "" Then Exit Sub ' case no criteria met for the day this workbook was opened.
     Let strRws = VBA.Strings.Mid$(strRws, 2) ' take off first space
    '4b) Array of rows
    Dim arrRws() As String: Let arrRws() = VBA.Strings.Split(strRws, " ", -1, vbBinaryCompare)
    Rem 5 HTML Table of required output '
    Dim ProTble As String
    '5a) Table start
    Let ProTble = _
    "<table width=520>" & vbCrLf & _
    "<col width=30>" & vbCrLf & _
    "<col width=150>" & vbCrLf & _
    "<col width=40>" & vbCrLf & vbCrLf
    '5b) data rows
    Dim iCnt As Long, jCntStear As Variant, jCnt As Long ' data "columns" ,     "rows"
        For Each jCntStear In arrRws() ' To Loop for all rows meeting criteria
         Let jCnt = jCnt + 1  ' Rows count for table to send
        Dim LisRoe As String
         Let LisRoe = LisRoe & "<tr height=16>" & vbCrLf
            For iCnt = 1 To 5
             Let LisRoe = LisRoe & "<td>" & arrIn(arrRws(jCnt - 1), iCnt) & "</td>" & vbCrLf ' -1 is because Split Function returns array of string types in 1 Dimensional array starting at indice 0, so our jCnt is one too big
            Next iCnt
         Let LisRoe = LisRoe & "</tr>" & vbCrLf & vbCrLf
         Let ProTble = ProTble & LisRoe
         Let LisRoe = ""
        Next jCntStear
     Let ProTble = ProTble & "</table>" ' table end
     Debug.Print ProTble
    Rem 6 EMail send 'For info see:  http://www.excelfox.com/forum/showth...once#post10519
    'Working at my end With my With End With Created LCDCW Library, (LCD 1.0 Library ) (Linking Configuration Data_Cods Wollups)
        With CreateObject("CDO.Message") ' -Linking Cods Wollups--------
        Dim LCD_CW As String: Let LCD_CW = "http://schemas.microsoft.com/cdo/configuration/"
         .Configuration(LCD_CW & "smtpusessl") = True '
         .Configuration(LCD_CW & "smtpauthenticate") = 1  '
        '  ' Sever info
         .Configuration(LCD_CW & "smtpserver") = "smtp.gmail.com" ' "securesmtp.t-online.de" "smtp.mail.yahoo.com" "smtp.live.com" "pod51017.outlook.com"  "smtp-mail.outlook.com" "smtp.live.com"  "securesmtp.t-online.de"
        '  The mechanism to use to send messages.
         .Configuration(LCD_CW & "sendusing") = 2  '  Based on the LCD_OLE Data Base of type DBTYPE_I4
         .Configuration(LCD_CW & "smtpserverport") = 25 ' 465 or 25 for t-online.de 'or 587 'or 25
         .Configuration(LCD_CW & "sendusername") = "YourEMailAddress"
         .Configuration(LCD_CW & "sendpassword") = "YourEMailPassword"
        ' Optional - How long to try
         .Configuration(LCD_CW & "smtpconnectiontimeout") = 30 '
        ' Intraction protocol is Set/ Updated
         .Configuration.Fields.Update '
        'End With ' ----------------------      my Created  LCDCW Library
        'With ' --- ' Data to be sent------     my Created  LCDCW Library
         Dim strHTML As String: Let strHTML = ProTble 'ProTble(rngArr()) ' Let strHTML = RangetoHTML(rng)
        '         Dim Highway1 As Long: Let Highway1 = FreeFile(0) '
        '          Open ThisWorkbook.Path & "" & "jawaharse.txt" For Output As #Highway1 '
        '          Print #Highway1, strHTML
        '          Close #Highway1
        .To = "Doc.AElstein@t-online.de" '
        .cc = ""
        .BCC = ""
        .from = """Equipment- Maint Records.xlsm"" <YourEMailAddresseOrAnyCrap>"
        .Subject = Ws.Range("A1").Value
        .HTMLBody = strHTML
        '        .AddAttachment ThisWorkbook.Path & "\jawaharse.txt"
        .Send ' Do it
        End With ' CreateObject("CDO.Message") -----my Created  LCDCW Library
  3. #43
    Re Post code with Code tags
    To support this Thread
    http://www.excelfox.com/forum/showth...0679#post10679
    Re post code in Code tags, Like ....
    Please use CODE TAGS if you are writing codes in your post.
    To use code tags,
    either
    select your entire code and press the code tag button # in the editor below,
    simply type your code as below
    [Code]Your Code Here[/Code]
    [Code]
    Your Code Here
    [/Code]
    [Code]
    Private Sub cmdNot_Click()
    Dim OutApp As Object
    Dim OutMail As Object
    [/Code]
    BBCodeCodeTags.JPG : https://imgur.com/4HunNcs
    Attachment 2060
    _.__________________
    If you post using Code tags, then it will come out in the final post in a Code Window, like this:
    Dim fileName As String
    Dim mSubject As String
    Dim signature As String
    Dim fname As String
    Dim mBody As String
    Dim rng As Range
    Dim rng1 As Range
    Dim ws As Worksheet
    Dim mailTo As String
     Set ws = Sheets("MRO")
     fname = ws.Range("B4")
     mSubject = "MRO " & " For " & Range("C6").Value
     Set OutApp = CreateObject("Outlook.Application")
     Set OutMail = OutApp.CreateItem(0)
    'mBody = "2-SO\Material Request Form .xlsm"
    Dim Path As String
     mBody = "<font size=""3"" face=""Calibri"">" & _
    "Dear Team,<br><br>" & _
    "Please open the file from below link and put your signature on the respective cell after you completed your task.<br><B>" & _
    fileName & ".xlsm" & "</B> is created.<br>" & _
    "Click on this link to open the file : " & _
    "<A HREF=""file://" & Path & fileName & ".xlsm" & _
    """>Files are saved here</A>" & "-->" & Range("C6").Value & _
    "<br><br>Best Regards," & _
    "<br><br></font>"
        With OutMail
         .display
     signature = OutMail.body
        With Application
         .EnableEvents = False
         .ScreenUpdating = False
        With OutMail
         '.To = "email"
         .To = ""
         .CC = ""
         .BCC = ""
         .Subject = mSubject
         '.body = "Dear Team," & vbCrLf & vbCrLf & "Please open the file from below link and put your signature on the respective cell and save the sheet"
         '.htmlbody = RangetoHTML(rng)
         .htmlbody = mBody
         '.Attachments.Add fileName
         .display
     'ws.PageSetup.RightHeader = "&""Calibri,italic""&11& " & ws.Range("A1")
     ActiveWorkbook.Close False
     Set OutMail = Nothing
     Set OutApp = Nothing
        With Application
         .ScreenUpdating = True
         .EnableEvents = True
  4. #44
    Code in code tags from here:
    http://www.excelfox.com/forum/showth...0699#post10699
    Dim fname As String
    Dim mBody As String
    Dim rng As Range
    Dim rng1 As Range
    Dim ws As Worksheet
     fname = ws.Range("A1")
     mSubject = "Equipment" & " For " & Range("A1").Value
     'mBody = "Z:\2\Form\\Manufacturing Order.xlsm"
    Dim Path As String
     ws.Protect ("Equipment")
     Path = "\\Equipment- Maint RecordsThai1.xlsm"
       "Please open the file from below link and change the date on the respective cell after you completed your task.<br><B>" & _
       """>Files are saved here</A>" & "-->" & Range("A1").Value & _
       "<br><br></font>"
        With OutMail
         .display
        With Application
        If Application.UserName = "Thai Nguyen" Then
        Dim ws As Worksheet: Set ws = Sheets("Name")
        Dim rng As Range, rng1 As Range
        Dim fileName As String, fname As String
         Let fname = ws.Range("B4")
         Let mSubject = "Name"
        Dim OutApp As Object, OutMail As Object
        Dim Subject As String, signature As String, mBody As String, mailTo As String
            'mBody = "copy you link path in here"
         Let mBody = "<font size=""3"" face=""Calibri"">" & _
         "Hi Team,<br><br>" & _
         ActiveWorkbook.Name & "</B> is created.<br>" & _
         "<A HREF=""file://" & ActiveWorkbook.FullName & """>Link to the file</A>" & _
         "<br><br>Regards," & _
         "<br><br>Thai Nguyen</font>    "
         OutMail.display
         Let signature = OutMail.body
            With Application
            With OutMail
            '.To = "email"
                If ws.Range("EU16") = True Then
                 Let mailTo = mailTo + "Thai Nguyen;"
                If ws.Range("EU17") = True Then
                mailTo = mailTo + "email"
                If ws.Range("EU18") = True Then
                 Let mailTo = mailTo + "email"
                If ws.Range("EU19") = True Then
             .To = mailTo
             .CC = "Thai Nguyen"
             .BCC = ""
             .Subject = mSubject
             '.body = "Hi Team," & vbCrLf & vbCrLf & "Please open the file from below link and put your signature on the respective cell and save the sheet"
             .htmlbody = mBody
             .display
         ws.Protect ("Name")
         ActiveWorkbook.Save
            With Application
         MsgBox "You are not authorised to send BOM form, please check with BOM owner"
  5. #45
    Share account for testing file access from a hyperlink in a received EMail
    In support of a possible solution to this post in this Thread:
    http://www.excelfox.com/forum/showth...0724#post10724
    It is required to have a simple hyperlink to an Excel File appear in the received Email sent to members of a team.
    I am not sure currently how to get a link directly to the File.
    An second alternative involves storing the file at a File sharing site and using the link to the file as the URL part of a hyperlink.
    This post discusses the setting up of such an account to allow storing of, and sharing via a supplied link to, the file.
    As an example of a file sharing site we consider the free version of box.net
    Some googling my be needed to finally get at the free version which may go under the name of “free” , “Individual rate”, “Personal free”
    Currently you need to find your way to the free 10GB offer. This is currently at this link:
    https://account.box.com/signup/n/personal#fbms6
    Free10GB box net account register.JPG : https://imgur.com/NB3GThi
    Note , by registering, you can choose a language to suit you.
    Free10GB Select language .JPG : : https://imgur.com/aNzW1kq
    ( You can change the language to a different one after registering also
    Free10GB Change language .JPG : https://imgur.com/IosqbAI )
    For this registering , I use the created gmail account used for experiments in the current thread which this post supports, excellearning12@gmail.com ( excelfox Thread : http://www.excelfox.com/forum/showth...and-send-email )
    The password I pass on privately to those needing
    Free10GB box net account register 2.JPG : https://imgur.com/Y2pLogO
    Free10GB box net account register 3.JPG : https://imgur.com/QhCR8fP
    Free10GB box net account register Verify Email 4.JPG : https://imgur.com/ffG7erw
    Various steps are then gone through, they may be slightly different to the following:
    At some point you should you should see the possibility to upload a file, following steps similar to these:
    Free10GB box net 5 .JPG : https://imgur.com/lNWvQwF
    To upload a file and get a URL link to use in a hyperlink to it:
    Upload Files:
    Free10GB box net 6 .JPG : https://imgur.com/rTU1Xbk
    Select a file:
    Free10GB box net 7 .JPG : https://imgur.com/wKKlqoO
    Select share to obtain a URL link to the file :
    Free10GB box net 8 .JPG : https://imgur.com/R3VbyhR
    Copy link to be used in Hyperlink :
    Free10GB box net 9 .JPG : https://imgur.com/8yaYwaK
  6. #46
    Testing Hyperlinks in received EMail
    Testing codes in support of this Thread
    http://www.excelfox.com/forum/showth...0727#post10727
    Codes for Alf and sandy666
    Sub SendfromExcelVBAExpgmail()
    Rem 6 EMail send 'For info see:  http://www.excelfox.com/forum/showthread.php/2233-Urgent-support-needed-Multiple-emails-multiple-Excel-workbooks-at-once#post10519
        '6a(i)
        '  ' Sever info
         .Configuration(LCD_CW & "smtpserver") = "smtp.gmail.com" ' "smtp.office365.com" ' "smtp.live.com" ' "smtp-mail.outlook.com" ' "smtp.live.com" ' "smtp.gmail.com" ' "securesmtp.t-online.de" "smtp.mail.yahoo.com" "smtp.live.com" "pod51017.outlook.com"  "smtp-mail.outlook.com" "smtp.live.com"  "securesmtp.t-online.de"
         .Configuration(LCD_CW & "smtpserverport") = 465 ' 465 or 25 for gmail '587 ' 25  ' 465 or 25 for t-online.de 'or 587 'or 25
         .Configuration(LCD_CW & "sendusername") = "ExcelVBAExp@gmail.com" '
         .Configuration(LCD_CW & "sendpassword") = "xxxxxxxxxxxxxx"       '                                  '
    '     .Configuration(LCD_CW & "sendusername") = "YourEMailAddress"
    '     .Configuration(LCD_CW & "sendpassword") = "YourEMailPassword"
        'End With 6a(i)' ----------------------        my Created  LCDCW Library
        '6a(ii) With   ' -- ' Data to be sent---       my Created  LCDCW Library
         Dim strHTML As String: Let strHTML = "<font size=""3"" face=""Calibri"">" & _
         "This is sent from EMail account:" & _
         "<br>Username: ""ExcelVBAExp@gmail.com""" & _
         "<br>Password: ""xxxxxxxxxxxxxxxxxxxxxx""" & _
         "<br><br>" & _
         "<br>Please click on the 5 links below and tell me what happens, thanks!" & _
         "<br>1 <A HREF=""https://app.box.com/s/x01liz3ralbdrt152i52fpwb0wx40ff3"">link to box net cloud free file sharing</A>" & _
         "<br>2 <A HREF=""file://" & ThisWorkbook.Path & "\" & "Test file DOThtm to be stored on your computer to try to open with a Hyperlink in a received EMail.htm"""">htm file on your computer</A>" & _
         "<br>3 <A HREF=""file://" & ThisWorkbook.Path & "\" & "Test file DOThtm to be stored on your computer to try to open with a Hyperlink in a received EMail.htm"""">htm file on your computer</A>" & _
         "<br>4 <A HREF=""file://" & ThisWorkbook.Path & "\" & "Empty test file DOTxls stored on your computer to try to open from Hyperlink in arrived Email.xls"""">empty xls file on your computer</A>" & _
         "<br>5 <A HREF=""file:///" & ThisWorkbook.Path & "\" & "Empty test file DOTxls stored on your computer to try to open from Hyperlink in arrived Email.xls"""">empty xls file on your computer</A>"
        .To "xxxxxxxxxxxxxx"
        .CC "xxxxxxxxxxxxxa"
        .BCC = ""
        .from = """ExcelVBAExp@gmail.com"" <ExcelVBAExp@gmail.com>"
        .Subject = "Sent from EMail address: ExcelVBAExp@gmail.com"
        .htmlbody = strHTML
        .Send ' Do it
        End With ' 6a(ii) CreateObject("CDO.Message") ---my Created  LCDCW Library
    Sub SendfromFahrradprinzessinunterwegsgmail()
        '6a(i)
        '  ' Sever info
         .Configuration(LCD_CW & "sendusername") = "Fahrradprinzessinunterwegs@gmail.com" '
         .Configuration(LCD_CW & "sendpassword") = "xxxxxxxxxxxxx"       '                                  '
         "<br>Username: ""Fahrradprinzessinunterwegs@gmail.com""" & _
         "<br>Password: ""xxxxxxxxxxxxxxxxxxx""" & _
         "<br><br>" & _
        .To "xxxxxxxxxxxxxxxxxxxx"
        .CC "xxxxxxxxxxxxxxxxxxx"
        .BCC = ""
        .from = """Fahrradprinzessinunterwegs@gmail.com"" <Fahrradprinzessinunterwegs@gmail.com>"
        .Subject = "Sent from EMail address: Fahrradprinzessinunterwegs@gmail.com"
        .htmlbody = strHTML
        .Send ' Do it
    Sub SendfromDocAlnsteinGermanTelekom()
        '6a(i)
        '  ' Sever info
         .Configuration(LCD_CW & "smtpserver") = "securesmtp.t-online.de" ' "smtp.gmail.com" ' "smtp.office365.com" ' "smtp.live.com" ' "smtp-mail.outlook.com" ' "smtp.live.com" ' "smtp.gmail.com" ' "securesmtp.t-online.de" "smtp.mail.yahoo.com" "smtp.live.com" "pod51017.outlook.com"  "smtp-mail.outlook.com" "smtp.live.com"  "securesmtp.t-online.de"
         .Configuration(LCD_CW & "sendusername") = "Doc.Alnstein@t-online.de" '
         .Configuration(LCD_CW & "sendpassword") = "xxxxxxxxx"       '                                  '
         "<br>Username: ""Doc.Alnstein@t-online.de""" & _
         "<br>Password: ""xxxxxxxxxxx""" & _
         "<br><br>" & _
        .To "xxxxxxxxxxxxxxxxxxxxxxxx"
        .CC "xxxxxxxxxxxxxxxxxxxxxxxxx"
        .BCC = ""
        .from = """Doc.Alnstein@t-online.de"" <Doc.Alnstein@t-online.de>"
        .Subject = "Sent from EMail address: Doc.Alnstein@t-online.de"
        .htmlbody = strHTML
        .Send ' Do it
    Instructions:
    Three files are attached. Please download them and store them all somewhere on your computer. They can be stored anywhere, but important is that they are all stored in the same Folder :
    All 3 files stored in same place.JPG : https://imgur.com/rFu0TML
    Please open only one file “Test File xxxx to send EMail containing Hyperlinks to Files.xlsm
    Enable macros.
    There are three codes in file “Test File xxxx to send EMail containing Hyperlinks to Files.xlsm”.
    The codes are very similar, differing only in the Email account used as the .Sender:
    Please try to run those codes.
    Each code should send you an Email which on arrival will look something similar to this:
    Typical received EMail.JPG : https://imgur.com/4oNXNtW
    Please click on the 5 Hyperlinks and tell me what happens.
    My final goal is to get a Hyperlink which when clicked opens an Excel or Word File.
    I have tested the codes sending to my gmail and German Telekom Email accounts.
    But so far, only link 1 works. But link 1 does not open a file: It simply sends you to a file sharing site. So link 1 is a temporary solution for me.
    Code for Thai in next post....
  7. #47
    Code for Thai .
    Sub Sendfromexcellearninggmail()
        '6a(i)
        '  ' Sever info
         .Configuration(LCD_CW & "sendusername") = "excellearning12@gmail.com" '
         "<br>Username: ""excellearning12@gmail.com""" & _
         "<br>Password: ""xxxxxxxxxxxxx""" & _
         "<br><br>" & _
        .To = "THai xxxxxxxxx"
        '.CC = "xxxxxxxxxxxxx"
        .BCC = ""
        .from = """excellearning12@gmail.com"" <excellearning12@gmail.com>"
        .Subject = "Sent from EMail address: excellearning12@gmail.com"
        .htmlbody = strHTML
        .Send ' Do it
    Testing files( sent privately ) :
    I have also posted 3 files to you using our share g mail account , ExcelVBAExp@gmail.com
    Please can you also try out the test…
    Please do the following.
    _1) Download all three files , and important: All must be stored in the same Folder.
    ( the three files are:
    Test file DOThtm to be stored on your computer to try to open with a Hyperlink in a received Email.htm
    Test File Thai to send EMail containing Hyperlinks to Files.xlsm
    _2) Open only file Test File Thai to send EMail containing Hyperlinks to Files.xlsm
    Run code Sub Sendfromexcellearninggmail()
    You should receive an Email similar to these:
    Alan 5 Links in German Telekom.JPG : https://imgur.com/LeASbhf
    Attachment 2079
    Alan 5 Links in gmail.JPG : https://imgur.com/0sdyZEj
    Attachment 2080
    _3) Please click on the links.
    _4) Please reply and tell me what happens when you click each link
  8. #48
    First test code for solution to this thread:
    http://www.excelfox.com/forum/showth...le-or-two-tabs
    ( Run code Sub TestieCalls() )
    Sub TestieCalls()
     Call Testie(Worksheets("Sheet1"), Worksheets("Sheet2"))
    Sub Testie(Ws1 As Worksheet, Ws2 As Worksheet)
    Rem 1 Worksheet data info
    '1a capture data
    '1a(i) last data rows
    Dim lr1_1 As Long, Lr1_2 As Long, Lr2_1 As Long, Lr2_2 As Long, Lr1 As Long, lr2 As Long
     Let lr1_1 = Ws1.Cells(Rows.Count, 1).End(xlUp).row
     Let Lr1_2 = Ws1.Cells(Rows.Count, 2).End(xlUp).row: Lr2_1 = Ws2.Cells(Rows.Count, 1).End(xlUp).row: Lr2_2 = Ws2.Cells(Rows.Count, 2).End(xlUp).row
        If lr1_1 > Lr1_2 Then
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
     Let lr2 = Lr2_2: If Lr2_1 > Lr2_2 Then Let lr2 = Lr2_1
    '1a(ii) capture data into arrays in one go
    Dim arrSht1() As Variant, arrSht2() As Variant
     Let arrSht1() = Ws1.Range("A1:B" & Lr1 & "").Value
     Let arrSht2() = Ws2.Range("A1:B" & lr2 & "").Value
    Rem 2 arrays for check and output
    Dim arrSht1b() As String, arrOut() As String
    '2a size arrays to that of sheet 2 data
     ReDim arrSht1b(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
     ReDim arrOut(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
    '2b fill modified sheet 1 array, arrSht1b() , initially with sheet 1 data
        For Cnt = 1 To UBound(arrSht1(), 1) Step 1
         Let arrSht1b(Cnt, 1) = arrSht1(Cnt, 1): Let arrSht1b(Cnt, 2) = arrSht1(Cnt, 2)
    Rem 3 main loop   ' == Start main loop ==========
        For Cnt = 1 To UBound(arrSht2(), 1) - 1 Step 1 ' Counting at each row
        Dim DifCnt As Long 'Count of different cells
            ' Condition check
            If (arrSht2(Cnt, 1) <> arrSht1b(Cnt, 1) Or arrSht2(Cnt, 2) <> arrSht1b(Cnt, 2)) And (arrSht2(Cnt + 1, 1) = arrSht1b(Cnt + 1, 1) And arrSht2(Cnt + 1, 2) = arrSht1b(Cnt + 1, 2)) Then  ' condition for changed row but next row is as previous : row had data changed, but a row was not inserted
             Let arrSht1b(Cnt, 1) = arrSht2(Cnt, 1): arrSht1b(Cnt, 2) = arrSht2(Cnt, 2) 'change any changed cell
                If arrSht1b(Cnt, 1) <> arrSht1(Cnt, 1) Then
                 Let arrOut(Cnt, 1) = arrSht1b(Cnt, 1) & "  <>  " & arrSht1(Cnt, 1)
                 Let DifCnt = DifCnt + 1
                Else: End If
                If arrSht1b(Cnt, 2) <> arrSht1(Cnt, 2) Then
                 Let arrOut(Cnt, 2) = arrSht1b(Cnt, 2) & "  <>  " & arrSht1(Cnt, 2)
                Else: End If
            ' Condition check
            ElseIf ((arrSht2(Cnt, 1) <> arrSht1b(Cnt, 1) Or arrSht2(Cnt, 2) <> arrSht1b(Cnt, 2)) And (arrSht2(Cnt + 1, 1) <> arrSht1b(Cnt + 1, 1) Or arrSht2(Cnt + 1, 2) <> arrSht1b(Cnt + 1, 2))) Then   ' main condition suggesting added new row
            Dim AdedRows As Long: Let AdedRows = AdedRows + 1
            '3b we need to shift all data down to allow space for new row in arrSht2()
            Dim CntIn As Long
                For CntIn = (UBound(arrSht2(), 1) - 1) To Cnt Step -1 'loop for all but last from this row
                 Let arrSht1b(CntIn + 1, 1) = arrSht1b(CntIn, 1): arrSht1b(CntIn + 1, 2) = arrSht1b(CntIn, 2) ' This effectively pulls up each row by one
                Next CntIn
            '3c add the new data to the modified array, Let arrSht1b()
                If arrSht1b(Cnt, 1) = "" Then arrSht1b(Cnt, 1) = "           " ' Just to make final output more neat
                If arrSht1b(Cnt, 2) = "" Then arrSht1b(Cnt, 2) = "           "
            '3d add info to the output array
                If Cnt > UBound(arrSht1(), 1) Then ' case of new lines
                 Let arrOut(Cnt, 1) = "An new extra line contains  " & arrSht1b(Cnt, 1): arrOut(Cnt, 2) = "An new extra line contains  " & arrSht1b(Cnt, 2)
                   Else: End If
                   Else: End If
             Let Cnt = Cnt + 1 ' we need to skip the next row as that was just effectively added so we are done with it
            Else ' row has not been added here
        Next Cnt ' ========= End main loop ==========
    Rem 4 last row may be new
        If arrSht2(lr2, 1) <> arrSht1(Lr1, 1) Or arrSht2(lr2, 2) <> arrSht1(Lr1, 2) Then ' either cell in last row is different
            If arrSht2(lr2, 1) <> arrSht1(Lr1, 1) Then
             Let arrOut(lr2, 1) = arrSht2(lr2, 1) & "  on last row is new"
            Else: End If
            If arrSht2(lr2, 2) <> arrSht1(Lr1, 2) Then
             Let arrOut(lr2, 2) = arrSht2(lr2, 2) & "  on last row is new"
            Else: End If
        Else 'last row on sheet2 is as on sheet1
    Rem 5 Output in new file For testing purposes, I give the output in a third worksheet, Tabelle3
    Dim Ws3 As Worksheet: Set Ws3 = ThisWorkbook.Worksheets("Tabelle3")
     Ws3.Cells.ClearContents
     Let Ws3.Range("A1:B1").Value = "Sheet1": Ws3.Range("C1:D1").Value = "Test Output": Ws3.Range("E1:F1").Value = "Sheet2"
     Let Ws3.Range("A2").Resize(UBound(arrSht1(), 1), UBound(arrSht1(), 2)).Value = arrSht1()
     Let Ws3.Range("C2").Resize(UBound(arrOut(), 1), UBound(arrOut(), 2)).Value = arrOut()
     Let Ws3.Range("E2").Resize(UBound(arrSht2(), 1), UBound(arrSht2(), 2)).Value = arrSht2()
     Ws3.Columns.AutoFit
    Rem 6 MsgBoox output
     MsgBox Prompt:="inserted lines is   " & AdedRows & vbCrLf & "Changed cells is  " & DifCnt
  9. #49
    Test runs from code
    Sub TestyCalls() ' http://www.excelfox.com/forum/showthread.php/2277-Vba-button-Comparison-data-between-two-file-or-two-tabs?p=10741#post10741
    ' Call Testie(Worksheets("Sheet1"), Worksheets("Sheet2"))
     Call Testy(Worksheets("Sheet1"), Worksheets("Sheet2"))
    For support of this excelfox Thread:
    http://www.excelfox.com/forum/showth...0741#post10741
    Sheet1 Sheet1 Test Output Test Output Sheet2 Sheet2
    Customer Assembly Customer Assembly
    Nu Torque
    13456
    Nu Torque
    13456
    Blu Origin Spaceship Blu Origin Spaceship
    Jet Blue21 ABC
    Alaska
    789
    Toyota Supra
    Emirate ABC12345
    Jet Blue21 ABC
    Alaska
    789
    Toyota Supra
    Emirate ABC12345
    Dup 2 of Toyota Dup 2 of Supra Toyota Supra
    Dup 2 of Emirate Dup 2 of ABC12345 Emirate ABC12345
    Spaceship 12 Spaceship
    Worksheet: Tabelle3
    Nu Torque
    13456
    Nu Torque
    13456
    Blu Origin Spaceship Alaska
    789
    Jet Blue21 ABC Excel123 HiThai Excel123 HiThai
    Alaska
    789
    Toyota Supra Emirate ABC12345
    Emirate ABC12345 Jet Blue21 ABC
    Toyota Supra
    Worksheet: Tabelle3
  10. #50
    Code in support of this Post
    Sub Testy(Ws1 As Worksheet, Ws2 As Worksheet)
    '1a capture data
         Let Lr1 = lr1_1
         Let Lr1 = Lr1_2
    Dim arrSht1b() As String, arrOut() As String, arrSht1Chk() As String, arrSht2Chk() As String
    ' ReDim arrSht1b(1 To UBound(arrSht2(), 1), 1 To UBound(arrSht2(), 2))
     ReDim arrSht1Chk(1 To UBound(arrSht1(), 1)): ReDim arrSht2Chk(1 To UBound(arrSht2(), 1)) ' Arrays for concatenated data
    '2b make check arrays        fill modified sheet 1 array, arrSht1b() , initially with sheet 1 data
    '     Let arrSht1b(Cnt, 1) = arrSht1(Cnt, 1): Let arrSht1b(Cnt, 2) = arrSht1(Cnt, 2)
         Let arrSht1Chk(Cnt) = arrSht1(Cnt, 1) & "|" & arrSht1(Cnt, 2)
        For Cnt = 1 To UBound(arrSht2(), 1) Step 1
         Let arrSht2Chk(Cnt) = arrSht2(Cnt, 1) & "|" & arrSht2(Cnt, 2)
    '2c make contents of array for output initially all dat from Sheet2
         Let arrOut(Cnt, 1) = CStr(arrSht2(Cnt, 1)): arrOut(Cnt, 2) = CStr(arrSht2(Cnt, 2))
    Rem 3 main loop   ' == Start Main loop ================
        For Cnt = 1 To UBound(arrSht1(), 1) Step 1 ' Counting at each row of Sheet2
        Dim MtchRes As Variant
         Let MtchRes = Application.Match(arrSht1Chk(Cnt), arrSht2Chk(), 0)
        '3a action whilst match is found --Inner Loop------
            Do While Not IsError(MtchRes) ' The 3a Loop
            Dim DupyCnt As Long: Let DupyCnt = DupyCnt + 1
                If DupyCnt > 1 Then
                 Let arrOut(MtchRes, 1) = "Dup " & DupyCnt & " of " & arrOut(MtchRes, 1): arrOut(MtchRes, 2) = "Dup " & DupyCnt & " of " & arrOut(MtchRes, 2)
                 Let arrOut(MtchRes, 1) = "": arrOut(MtchRes, 2) = "" ' remove the found data from array for output so that next line can look again for a possible duplicate
                 Let arrSht2Chk(MtchRes) = "" ' remove entry in check array so that next line can look for possible duplicate
            Loop ' ----------------------------------------
         Let DupyCnt = 0 ' reset the Duplicated data count for next row of data in Sheet1
        Next Cnt ' ========= End main loop ================= effectively we go to next row of data in Sheet1 with this line
     Ws3.Columns.AutoFit
    Rem 6 MsgBox output
    ' MsgBox Prompt:="Inserted lines is   " & AdedRows & vbCrLf & "Changed cells is  " & DifCnt
  1. Table Tests. And Thread Copy Tests No Reply needed
  3. Replies: 11
  4. Replies: 1
    Last Post: 09-14-2013, 12:49 PM
  5. Replies: 7
    Last Post: 08-28-2013, 12:57 AM
