Thread: Range Difference VBA
    Lightbulb Range Difference VBA
    Hi All,
    Here is a method to extract the range difference.
    Function RangeDifference(ByRef ActualRange As Range, MinusRange As Range) As Range
        '// Author          : Krishnakumar
        '// Created on      : 08-Feb-2012
        Dim rngTemp         As Range
        Dim wksOriginal     As Worksheet
        Dim wksTemp         As Worksheet
        Dim lngSU           As Long
        With Application
            lngSU = .ScreenUpdating
            .ScreenUpdating = False
            .DisplayAlerts = False
            .EnableEvents = False
        Set wksOriginal = ActualRange.Parent
        Set wksTemp = Worksheets.Add
        Set rngTemp = wksTemp.Range(ActualRange.Address)
        rngTemp.Value = "z"
        wksTemp.Range(MinusRange.Address).Clear
        Set RangeDifference = wksOriginal.Range(rngTemp.SpecialCells(xlConstants).Address)
        wksTemp.Delete
        With Application
            .ScreenUpdating = lngSU
            .EnableEvents = True
            .DisplayAlerts = True
    Hi All,
        Dim lngSU           As Long
        With Application
        rngTemp.Value = "z"
        wksTemp.Range(MinusRange.Address) = 1
        Set RangeDifference = wksOriginal.Range(rngTemp.SpecialCells(2, 2).Address)
        wksTemp.Delete
        With Application
    While not critical in any sense of the word, I think it would be more straightforward to simply Clear the MinusRange rather than fill it with 1's, then just use a single argument (xlConstants) for the SpecialCells function call instead of the two arguments required by your method. So, my suggestion would be to replace the lines of code highlighted in red with these...
    Thanks Rick, code modified.
  1. Correcting “Negative” Time Difference Calculation in Excel
  2. VBA Looping Input Range and Output Range
  3. Effective way of calculating the difference
    By zzzqinzzz in forum Excel Help
    Last Post: 12-13-2012, 03:39 PM
  4. Move or Copy Duplicate Rows to Difference Sheet
    By Vgabond in forum Excel Help
    Last Post: 12-08-2012, 12:33 PM
  5. Get time difference in excel using vba
    Last Post: 10-09-2012, 07:57 AM
