Thread: Speed up excel to word VBA
    May 2012
    Orange - Report as at 2012-05-15 A A.zipExample 2012-05-15.xls
    Hello
    I need to create about 100 word reports from an excel "database"
    Please help me with speeding up the following code:
    ' Working 2012-05-15
    Sub WordGenerate()
        Dim CL As Range, rdata As Range, filt As Range
        Dim UniqueClient As Range, CUniqueClient As Range, Dest As Range
        Dim Client As String, RM() As String, TA() As String, TA_Email() As String, TA_Phone() As String
        Dim ContractTYPE() As String, Supplier() As String, FundID() As String, FundName() As String, Email() As String
        Dim Phone() As String, Mobile() As String, JobTitle() As String, Initials() As String, Surname() As String
        Dim i As Integer, j As Integer, k As Integer, y As Integer, Speed As Date
        Dim wrdApp As Object, tmpDoc As Object, wrdDoc As Object, WRng As Object, wrdRange As Object
        Dim WDoc As String, myDoc As String, x As String, Path As String, t As String, MyName As String
        Dim strBar As String
        Dim lngLoop As Integer
        Application.EnableEvents = False
        Speed = Now()
    With Worksheets("DB")
        Set CL = Range(.Range("A1"), .Range("A1").End(xlDown))
        Set UniqueClient = .Range("A1").End(xlDown).Offset(5, 0)
        CL.AdvancedFilter xlFilterCopy, , UniqueClient, True
        Set UniqueClient = Range(UniqueClient.Offset(1, 0), UniqueClient.End(xlDown))
        Set rdata = .Range("A1").CurrentRegion
        rdata.Sort key1:=.Range("A1"), header:=xlYes
        MyName = ThisWorkbook.Path
        myDoc = "Fund Purchasing Report - Template.doc"
        WDoc = MyName & Application.PathSeparator & myDoc
        MkDir MyName & "\Reports as at " & Format(Date, "yyyy-mm-dd")
        i = 1
        For Each CUniqueClient In UniqueClient
            x = CUniqueClient.Value
            lngLoop = UniqueClient.Rows.Count
            rdata.AutoFilter field:=1, Criteria1:=x
            Set filt = rdata.Offset(1, 0).Resize(rdata.Rows.Count - 1).SpecialCells(xlCellTypeVisible)
            Client = filt.Areas(1).Cells(1, "A").Value
            j = filt.Areas(1).Rows.Count
            i = i + 1
            strBar = String(Round(i / lngLoop * 15, 0), ChrW(&H25A0)) & String(15 - Round(15 * i / lngLoop, 0), ChrW(&H25A1))
            Application.StatusBar = strBar & Format((i - 1) / lngLoop, "  0%") & "  Save report for: " & x
                ReDim RM(1 To j)
                ReDim TA(1 To j)
                ReDim ContractTYPE(1 To j)
                ReDim Supplier(1 To j)
                ReDim FundID(1 To j)
                ReDim FundName(1 To j)
                ReDim Email(1 To j)
                ReDim Phone(1 To j)
                ReDim Mobile(1 To j)
                ReDim JobTitle(1 To j)
                ReDim Initials(1 To j)
                ReDim Surname(1 To j)
                ReDim TA_Email(1 To j)
                ReDim TA_Phone(1 To j)
            For k = 1 To j
                Client = filt.Areas(1).Cells(k, "A").Value
                RM(k) = filt.Areas(1).Cells(k, "B").Value
                TA(k) = filt.Areas(1).Cells(k, "C").Value
                ContractTYPE(k) = filt.Areas(1).Cells(k, "E").Value
                Supplier(k) = filt.Areas(1).Cells(k, "F").Value
                FundID(k) = filt.Areas(1).Cells(k, "H").Value
                FundName(k) = filt.Areas(1).Cells(k, "I").Value
                Email(k) = filt.Areas(1).Cells(k, "J").Value
                Phone(k) = filt.Areas(1).Cells(k, "K").Value
                Mobile(k) = filt.Areas(1).Cells(k, "L").Value
                JobTitle(k) = filt.Areas(1).Cells(k, "M").Value
                Initials(k) = filt.Areas(1).Cells(k, "N").Value
                Surname(k) = filt.Areas(1).Cells(k, "O").Value
                TA_Email(k) = filt.Areas(1).Cells(k, "P").Value
                TA_Phone(k) = filt.Areas(1).Cells(k, "Q").Value
            Next k
            For k = 1 To j
            MkDir MyName & "\Reports as at " & Format(Date, "yyyy-mm-dd") & Application.PathSeparator & Surname(k)
            Next k
            Set wrdApp = GetObject(, "Word.Application")
            If wrdApp Is Nothing Then
                 ' no current word application
                Set wrdApp = CreateObject("Word.application")
                Set wrdDoc = wrdApp.Documents.Open(WDoc)
                wrdApp.Visible = False
                ' word app running
                For Each tmpDoc In wrdApp.Documents
                    If StrComp(tmpDoc.FullName, WDoc, vbTextCompare) = 0 Then
                         ' this is your doc
                        Set wrdDoc = tmpDoc
                        Exit For
                If wrdDoc Is Nothing Then
                     ' not open
            Set wrdRange = wrdDoc
            With wrdDoc
                wrdApp.Selection.Style = "DocTitle"
                wrdApp.Selection.ParagraphFormat.Alignment = wdAlignParagraphLeft
                wrdApp.Selection.Font.Color = RGB(166, 166, 166)                        'Title
                wrdApp.Selection.Font.Name = "Georgia"
                wrdApp.Selection.Font.Size = 26
                wrdApp.Selection.ParagraphFormat.SpaceAfter = 18
                wrdApp.Selection.ParagraphFormat.LineSpacingRule = "At least"
                wrdApp.Selection.ParagraphFormat.LineSpacing = 13
                wrdApp.Selection.TypeText Text:="Trader SRL"
                wrdApp.Selection.TypeParagraph
                wrdApp.Selection.Font.Color = RGB(51, 51, 153)                       'Title
                wrdApp.Selection.Font.Size = 23
                wrdApp.Selection.ParagraphFormat.SpaceAfter = 0
                wrdApp.Selection.ParagraphFormat.LineSpacing = 0
                wrdApp.Selection.TypeText Text:="Report for"
                wrdApp.Selection.TypeText Text:=Client
    '--------------------------------------------------------------------------- Funds on first page
                    wrdApp.Selection.Style = "DocSubtitle"
                For k = 1 To j
                    wrdApp.Selection.Font.Color = RGB(255, 0, 0)
                    wrdApp.Selection.Font.Name = "Arial"
                    wrdApp.Selection.Font.Size = 11
                    wrdApp.Selection.Font.Bold = True
                    t = vbTab
                    For y = 1 To j
                        If Len(ContractTYPE(y)) > 3 Then
                        t = vbTab & vbTab
                    Next y
                    If Len(ContractTYPE(k)) > 3 Then
                        wrdApp.Selection.TypeText Text:=ContractTYPE(k) & ":" & vbTab & FundName(k) & " - " & Supplier(k)
                    wrdApp.Selection.TypeText Text:=ContractTYPE(k) & ":" & t & FundName(k) & " - " & Supplier(k)
                Next k
    '--------------------------------------------------------------------------- Date
                    wrdApp.Selection.TypeText Text:="Date:" & t & Format(Date, "dd MMMM yyyy")
    '--------------------------------------------------------------------------- Funds and graphs on page
                For k = 1 To j
                    If FileFolderExists(ThisWorkbook.Path & "\Graphs " & Format(Date, "yyyy-MM-dd") _
                                & Application.PathSeparator & FundID(k) & " - " & FundName(k) & " - " & Client & ".doc") Then
                            wrdApp.Selection.InsertFile ThisWorkbook.Path & "\Graphs " & Format(Date, "yyyy-MM-dd") _
                                & Application.PathSeparator & FundID(k) & " - " & FundName(k) & " - " & Client & ".doc", "", False, False, False
                            wrdApp.Selection.Style = "Heading 1"
                            wrdApp.Selection.TypeText Text:=ContractTYPE(k) & ": " & FundName(k)
                                & Application.PathSeparator & "___" & FundID(k) & " - " & FundName(k) & ".doc", "", False, False, False
                Next k
    '--------------------------------------------------------------------------- Coments
                    wrdApp.Selection.InsertFile ThisWorkbook.Path & "\Coments.doc", "", False, False, False
    '--------------------------------------------------------------------------- Contacts
                    wrdApp.Selection.TypeText Text:="Contacts"
                    wrdApp.Selection.Style = "No Spacing"
                    wrdApp.Selection.Font.Bold = False
                    wrdApp.Selection.ParagraphFormat.LineSpacingRule = "Single"
                    wrdApp.Selection.TypeText Text:="For further information please contact your Relationship Manager:"
    '--------------------------------------------------------------------------- Contacts RM
                    k = 1
                    wrdApp.Selection.TypeText Text:=RM(k)
                    wrdApp.Selection.TypeText Text:=JobTitle(k)
                If Len(Phone(k)) > 1 Then
                    wrdApp.Selection.TypeText Text:="T   " & Phone(k)
                If Len(Mobile(k)) > 1 Then
                    wrdApp.Selection.TypeText Text:="M  " & Mobile(k)
                    wrdApp.Selection.TypeText Text:="E  "
                    Dim RngEmail As Word.Range
                    Set RngEmail = .Content
                    RngEmail.Collapse wdCollapseEnd
                    .Hyperlinks.Add Anchor:=RngEmail, Address:="Mailto:%20" & _
                            Email(k), SubAddress:="", ScreenTip:="", TextToDisplay _
                            :=Email(k), Target:="": RngEmail.Collapse wdCollapseEnd
                If Len(TA(k)) > 1 Then
                    wrdApp.Selection.TypeText Text:="Trading Assistant contact details:"
                    wrdApp.Selection.TypeText Text:=TA(k)
                    wrdApp.Selection.TypeText Text:="Trading Assistant"
                    If Len(TA_Phone(k)) > 1 Then
                        wrdApp.Selection.TypeText Text:="T   " & TA_Phone(k)
                            TA_Email(k), SubAddress:="", ScreenTip:="", TextToDisplay:=TA_Email(k), Target:=""
                    wrdApp.Selection.TypeText Text:="Address"
    '---------------------------------------------------------------------------Disclaimer
                    wrdApp.ActiveWindow.ActivePane.View.Type = 3
                    wrdApp.ActiveWindow.ActivePane.View.SeekView = 10
                    wrdApp.Selection.InsertParagraphAfter
                    wrdApp.Selection.InsertFile ThisWorkbook.Path & "\Disclaimer.doc", "", False, False, False
                    wrdApp.Selection.InsertAfter "REPORT - " & Client
    '--------------------------------------------------------------------------- Display only text (not blank space)
                    'With wrdApp.ActiveWindow.ActivePane.View
                    '    .SeekView = wdSeekMainDocument
                    '    .DisplayPageBoundaries = Not .DisplayPageBoundaries
                    'End With
                    .SaveAs (MyName & "\Reports as at " & Format(Date, "yyyy-mm-dd") & Application.PathSeparator & Surname(k) & Application.PathSeparator & Client & _
                        " - Report as at " & Format(Date, "yyyy-MM-dd") & " " & Initials(k) & ".doc")
                    .Content.Clear
                    wrdApp.Quit ' close the Word application
                    Set wrdDoc = Nothing
                    Set wrdApp = Nothing
                    .AutoFilterMode = False
        Next CUniqueClient
            Range(.Cells(Rows.Count, "A").End(xlUp), .Cells(Rows.Count, "A").End(xlUp).End(xlUp)).Cells.Clear
        Application.StatusBar = False
        Application.EnableEvents = True
        MsgBox "Elapsed Time " & Format(Now() - Speed, "hh:mm:ss")
    Public Function FileFolderExists(strFullPath As String) As Boolean
        On Error GoTo EarlyExit
        If Not Dir(strFullPath, vbDirectory) = vbNullString Then FileFolderExists = True
    EarlyExit:
    Thank you
    Bogdan
    May 2012
    That's a lot of objects. I would look at taking the portion of code which sets your Word application object, and remove it from your loop. You only need one application instance really. Not having to go through that will help. You're doing quite a bit with your code, it stands to reason it will take a while. Something I don't understand is where you're setting a Style in Word, but then you go into details on changing the format/paragraph. The point of Style's is to have a pre-formed set of formats/paragraphs you can set all at once. I doubt it'll speed your code up too much, but it might improve things.
    I'll have a look at this, but can you tell me what will happen for clients like Time,Vodafone who do not have 4 lines. And what if there are more than 4 lines per client?
    Can you attach a few samples for those also.
    May 2012
    Thank you for your time spent on my macro
    I will put examples for clients with more than 4 lines, but is no difference: macro will add another page with that line (if client have 1 line - report will have 4 pages (first page + report page+Comments page+Contacts page)(2 line means 2*"report page" - total of 5 pages, 5 lines means report of 8 pages )
    I will be back soon with examples
    regarding styles: "Heading 1" is default style in word
    I change styles because I dont want all lines to be Heading 1 and I dont know how to setup a style for further use....but I can digg on forums.
    (Except array which is made by Sir Venkat from Mr. Excel forum, everything is made after I read and try/run diferent posts/articles )
    Anyhow....
    Thank you again
  1. Replies: 7
    Last Post: 08-24-2015, 10:58 PM
  2. Excel Chart into Word VBA
    By dhiraj.ch185 in forum Word Help
    Last Post: 12-26-2012, 11:23 AM
  3. Replies: 1
    Last Post: 10-16-2012, 01:53 PM
  4. Speed up Loop VBA
    By PcMax in forum Excel Help
    Last Post: 04-09-2012, 04:20 PM
  5. Excel Chart To Word Convertor
    By Excel Fox in forum Download Center
    Last Post: 04-04-2011, 06:21 AM
