Page 1 of 3 123 LastLast
Results 1 to 10 of 35
Thread: Redistribute a Delimited Column Of Data into Separate Rows (Keeping Other Data As Is)
    *** NOTE - Revised code posted August 12, 2013 in response ***
    *** to a problem Marcelo Branco pointed out in Message #19 ***
    The following scenario seems to come up somewhat often at the various forums I participate in... take a table of data where one column contains delimited data and split that delimited data so that each item is on a row of its own, copying the associated data into the blank cells created by the split. Visually, we want to go from this table...
    A B C D
    1 Name Client
    Number
    Parts
    Ordered
    2 Rick 1111111 P1, P2, P3
    3 Sam 2222222 P2, P5
    4 Joe 3333333 P3
    5 Bill 4444444 P4, P6, P7, P8
    to this one
    A B C D
    1 Name Client
    Number
    Parts
    Ordered
    2 Rick 1111111 P1
    3 Rick 1111111 P2
    4 Rick 1111111 P3
    5 Sam 2222222 P2
    6 Sam 2222222 P5
    7 Joe 3333333 P3
    8 Bill 4444444 P4
    9 Bill 4444444 P6
    10 Bill 4444444 P7
    11 Bill 4444444 P8
    Below is a macro that will accomplish this task. Note though that I have generalize it somewhat. Usually in the requests the delimited data is in the last column as shown above, however, there is no need for this to be the case... this macro will allow any column to be the delimited column.
    Sub RedistributeData()
      Dim X As Long, LastRow As Long, A As Range, Table As Range, Data() As String
      Const Delimiter As String = ", "
      Const DelimitedColumn As String = "C"
      Const TableColumns As String = "A:C"
      Const StartRow As Long = 2
      LastRow = Columns(TableColumns).Find(What:="*", SearchOrder:=xlRows, _
                SearchDirection:=xlPrevious, LookIn:=xlFormulas).Row
      For X = LastRow To StartRow Step -1
        Data = Split(Cells(X, DelimitedColumn), Delimiter)
        If UBound(Data) > 0 Then
          Intersect(Rows(X + 1), Columns(TableColumns)).Resize(UBound(Data)).Insert xlShiftDown
        If Len(Cells(X, DelimitedColumn)) Then
          Cells(X, DelimitedColumn).Resize(UBound(Data) + 1) = WorksheetFunction.Transpose(Data)
      LastRow = Cells(Rows.Count, DelimitedColumn).End(xlUp).Row
      Set Table = Intersect(Columns(TableColumns), Rows(StartRow).Resize(LastRow - StartRow + 1))
      If Err.Number = 0 Then
        Table.SpecialCells(xlBlanks).FormulaR1C1 = "=R[-1]C"
        Columns(DelimitedColumn).SpecialCells(xlFormulas).Clear
        Table.Value = Table.Value
    There are four constants (the Const statements) that you need to match to your actual worksheet conditions in order to work. The first is named Delimiter and it can be one or more characters long. The second is named DelimitedColumn and specifies the column letter containing the delimited cells. The third is named TableColumns and it specifies the columns occupied by your data (which must always include the column with the delimited cells. The last one is named StartRow and it specifies the row containing the first piece of data (that is, it is the row number below the headers, if any).
    Hi Rick
    I tried to develop an alternative that doesn't need any writing into any worksheet. It will be done in memory completely (except writing the results of course).
    You can see that I make use of all the special facilities that arrays offer us.
    The macro is built on the example in this thread.
    Sub M_snb()
        sn = Sheets(1).Cells(1).CurrentRegion
        For j = 1 To UBound(sn)
            c00 = c00 & "|" & Replace(String(UBound(Split(sn(j, 3), ",")), "|"), "|", j & "|") & j
        sq = Application.Index(sn, Application.Transpose(Split(Mid(c00, 2), "|")), Evaluate("transpose(row(1:" & UBound(sn, 2) & "))"))
        sp = Split(Join(Application.Transpose(Application.Index(sn, 0, 3)), ","), ",")
        For j = 0 To UBound(sp)
            sq(j + 1, 3) = sp(j)
        Cells(10, 1).Resize(UBound(sq), UBound(sq, 2)) = sq
    or another method:
    Sub M_snb0()
        sn = Split(Join([transpose(A2:A6 & "_" & B2:B6 & "_" & substitute(C2:C6,", ","," & A2:A6 & "_" & B2:B6 & "_"))], ","), ",")
        Cells(20, 1).Resize(UBound(sn) + 1) = Application.Transpose(sn)
        Cells(20, 1).CurrentRegion.TextToColumns , , , , False, False, False, False, True, "_"
    https://www.youtube.com/watch?v=f7xZivqLZxc&lc=UgwhVTFaD469mW9wO194AaABAg. 9gJzxwFcnPU9gORqKw5tW_
    Apr 2013
    hi why this macro is not working.
    Hi Rick
    Sub M_snb()
    or another method:
    Sub M_snb0()
    Hi my problem is same like DAT only. but this macro is not working for issue. when apply the macro it's showing error Run-time error '1004': Application-defined or object-defined error.
    Quote Originally Posted by venkatgoutham View Post
    You quote the code that 'snb' posted in response to my article, so I'll let him deal with your question (whenever he next checks into this thread) as it relates to his code, but I was wondering if you tried the code I posted in main article and whether you had problems using it as well?
    Apr 2013
    yep i tried. it's working fine which u posted in main article .yesterday it's working fine for me. but today i am getting error (which i told in previous quote). so i have to know one thing. which times that error come. what i need check whether it's error came.
    Can you attach a copy of the workbook that is giving you the error so that I can test the code out on your exact data to see where the problem is located at?
    I hope it's obvious that:
    - this macro resides in the macromodule it refers to
    - the ranges (A1:A6, B1:B6, etc.) have to be adapted to your specific situation
    - the delimiter in column C is ", " and may have to be adapted to your specific situation
    Sub M_snb()
    Your feedback is too limited to analyse what could have caused the error.
    Posting a sample workbook could shed some more light.
    May 2013
    Hi Rick,
    I tried to use your macro and after updating the 4 constants I get a runtime error 1004 on the following line.
    May 2013
    I only changed the constants to:
    Const Delimiter As String = ";#"
    Const DelimitedColumn As String = "D"
    Const TableColumns As String = "A:D"
    Any ideas what could trigger the error on that line?
    Can you attach a sample file (that fails to work) to a response so that I can see what is happening directly? To attach a file, I think you would click the Reply link in the bottom border of this message and then click the "Go Advanced" button under the new reply box that appears... somewhere below that new reply box should be a button that will allow you to upload a file as an attachment.
  1. Move data from rows into columns for every unique value
    Last Post: 06-13-2013, 03:02 AM
  2. Replies: 4
    Last Post: 05-01-2013, 09:49 PM
  3. Replies: 3
    Last Post: 03-16-2013, 05:13 PM
  4. Replies: 12
    Last Post: 08-19-2012, 06:17 PM
  5. Transpose data into Rows
    By vikash200418 in forum Excel Help
    Last Post: 04-10-2012, 11:02 PM
