Ever wished you could have all your recent Office files' MRU / Most Recently Used / Recent link from Word, PowerPoint and Access in the same place? Office 2010 has the recent folders list in the Backstage view. But how about something similar in Excel 2007, especially with the Win XP, and other pre-Windows 7 releases?
Chronos Twelve (Chronos=Related to Time (recency); Twelve=Office 12.0) is an Excel based add-in that does just about this. For developers who are interested, I will post both the XML code as well as the VBA code below. This is still in nascent stage of development, and I will add enhancements as and when time permits. Feedback and suggestions are welcome.
Dim objRib As IRibbonUI
Dim strControlID As String
Dim varArrayValues As Variant
Dim varArrayTypes As Variant
Dim lngSht As Long
Sub GetRecentFiles(Optional blnExcludeHostApplication As Boolean = True)
Dim lngLoop As Long
Dim lngApps As Long
Dim lngArrayLoop As Long
Dim strRegistryPath As String
Dim strKeyValue As String
Dim strApps As Variant
Dim strVers As Variant
Dim objSh As Object
Dim objDic As Object
Set objSh = CreateObject("wscript.shell")
Set objDic = CreateObject("Scripting.Dictionary")
strApps = Array("Excel", "Access", "Word", "PowerPoint")
strVers = Array("10.0", "11.0", "12.0", "14.0")
For lngApps = 0 To UBound(strApps)
For lngArrayLoop = 0 To UBound(strVers)
If Not (blnExcludeHostApplication And strApps(lngApps) & strVers(lngArrayLoop) = Replace(Application.Name, "Microsoft ", "") & Application.Version) Then
strRegistryPath = "HKEY_CURRENT_USER\Software\Microsoft\Office\" & RegiPath(CStr(strApps(lngApps)), CStr(strVers(lngArrayLoop)))
For lngLoop = 1 To 50 'Because Office Applications Until Version 14.0 do not have the feature to record more than 50 most recently used files
strKeyValue = objSh.RegRead(strRegistryPath & lngLoop)
If strKeyValue = "" Then
Exit For
If InStr(1, strKeyValue, "*") Then
objDic.Add Split(strKeyValue, "*")(1), CStr(strApps(lngApps)) & " " & CStr(strVers(lngArrayLoop)) & " " & lngLoop
objDic.Add strKeyValue, CStr(strApps(lngApps)) & " " & CStr(strVers(lngArrayLoop)) & " " & lngLoop
strKeyValue = ""
Next lngLoop
Err.Clear: On Error GoTo 0: On Error GoTo -1
Next lngArrayLoop
Next lngApps
varArrayValues = objDic.Keys
varArrayTypes = objDic.Items
Application.StatusBar = False
Set objDic = Nothing
Set objSh = Nothing
Function RegiPath(strApp As String, strVer As String) As String
Select Case Val(strVer)
Case 10, 11
Select Case strApp
Case "Excel"
RegiPath = strVer & "\" & strApp & "\Recent Files\File"
Case "Access"
RegiPath = strVer & "\" & strApp & "\Settings\MRU"
Case "Word"
RegiPath = strVer & "\" & strApp & "\Data Settings\MRU"
Case "PowerPoint"
RegiPath = strVer & "\" & strApp & "\Recent File List\File"
Case 12, 14
Select Case strApp
Case "Access"
Case Else
RegiPath = strVer & "\" & strApp & "\File MRU\Item "
'Callback for rxLst, rxFol getContent
Sub rxDynMenuGetContent(control As IRibbonControl, ByRef returnedVal)
Dim xml As String
Dim lng As Long
lngSht = Empty
If control.ID = "rxLst" Then
GetRecentFiles
For lng = 0 To UBound(varArrayTypes)
xml = xml & "<button id=""dynSubMenu" & lng & """ imageMso=""" & ImageName(CStr(varArrayTypes(lng))) & """ tag=""" & ParseXML(CStr(varArrayValues(lng))) & """ label=""" & GiveFile(CStr(varArrayValues(lng))) & """ screentip=""" & ParseXML(CStr(varArrayValues(lng))) & """ onAction=""FileCustomOpen""/>" & vbLf
Next lng
Else 'xlFol
GetRecentFiles False
If InStr(1, xml, """" & GiveFolder(CStr(varArrayValues(lng))) & """") = 0 Then
xml = xml & "<button id=""dynSubMenu" & lng & """ imageMso=""MenuPublish"" tag=""" & GiveFolder(CStr(varArrayValues(lng))) & """ label=""" & GiveFolder(CStr(varArrayValues(lng))) & """ onAction=""FileCustomOpen""/>" & vbLf
Next lng
xml = "<menu xmlns=""http://schemas.microsoft.com/office/2006/01/customui"" title=""ExcelFox.com Solutions"">" & vbLf & _
xml & "</menu>"
returnedVal = xml
If IsArray(varArrayTypes) Then Erase varArrayTypes
If IsArray(varArrayValues) Then Erase varArrayValues
lngSht = ActiveWorkbook.Sheets.Count
If lngSht > 0 Then
objRib.InvalidateControl control.ID
strControlID = control.ID
'Callback's for the macro's
Sub FileCustomOpen(control As IRibbonControl)
If lngSht = 0 Then
objRib.InvalidateControl strControlID
Shell "explorer.exe " & control.Tag, 3 'vbMaximizedFocus
Function ImageName(strType As String) As String
Select Case Left(strType, InStr(1, strType, " ") - 1)
Case "Excel"
ImageName = "MicrosoftExcel" '"FileSaveAsExcelXlsx"
Case "Word"
ImageName = "FileSaveAsWordDotx"
Case "PowerPoint"
ImageName = "MicrosoftPowerPoint" '"FileSaveAsPowerPointPptx"
Case "Access"
ImageName = "MicrosoftAccess" '"FileSaveAsAccess2007"
'Callback for customUI.onLoad
Sub rxLoad(ribbon As IRibbonUI)
Set objRib = ribbon
Function GiveFolder(strPath As String) As String
Dim lng As Long
lng = InStrRev(strPath, "\")
GiveFolder = Left(strPath, lng)
Function GiveFile(strPath As String) As String
Dim lng As Long
GiveFile = ParseXML(Mid(strPath, lng + 1))
Function ParseXML(strText As String) As String
ParseXML = Replace(strText, "&", "&&")
ParseXML = Replace(ParseXML, "'", "'")
PHP Code:
<customUI onLoad="rxLoad" xmlns="http://schemas.microsoft.com/office/2006/01/customui">
<ribbon startFromScratch="false">
<officeMenu>
<dynamicMenu
id="rxLst"
imageMso="AppointmentColorDialog"
getContent="rxDynMenuGetContent"
label="Recent Office Files"/>
<dynamicMenu
id="rxFol"
imageMso="MenuPublish"
label="Recent Office Folders"/>
</officeMenu>
</ribbon>
</customUI>
