Results 1 to 10 of 10
Thread: Programmatically format VBA buttons
    Sep 2012
    Question Programmatically format VBA buttons
    Hi everyone,
    First time I've joined and posted on an excel forum :D
    As the title suggests I'm having issues programmatically formatting buttons, rather than;
    userform1.CommandButton1.backcolor = 12648447
    userform1.CommandButton2.backcolor = 12648447
    I would like to do something like:
    For x = 1 To 2
            userform1.CommandButton & x.backcolor = 12648447
    Any suggestions?
    Hi Belleye,
    Welcome to ExcelFox !!!
    this goes in Userform module.
    Dim i   As Long
        With Me
            For i = 0 To .Controls.Count - 1
                If TypeName(.Controls(i)) = "CommandButton" Then
                    .Controls(i).BackColor = RGB(0, 64, 0)
    Sep 2012
    Hey Admin,
    Thanks for your reply, correct me if I'm wrong but the above code references the buttons by which order they where created in? I was hoping to reference the buttons by name, is this possible?
    Thanks.
    Quote Originally Posted by Belleye View Post
    You can use the Controls collection to address a control direcly by name as well...
    X = 2
    Me.Controls("CommandButton" & X).BackColor = vbRed
    So X could be the variable used as a For..Next loop counter as you seem to want.
    Yes your assumption is right. You could also try this way as well
    If .Controls(i).Name Like "abc*" Then 'begins with abc,"*abc" > ends with abc, "*abc*" contains abc
    '//or use like
    'If .Controls(i).Name = "abc" Then
    Sep 2012
    Sorted thanks very much +1
    Based on who the Threaded View of this forum shows you responded to, I think our messages may have crossed... I think you will want to read the message I posted (Message #5) as I believe it does what you might have been originally looking for.
    Sep 2012
    LOL yes they did... +1s all round today and that is what I was looking for thanks very much.
    Just to add:
    If you put this in the userform's codemodule you can use:
    sub snb()
      For j = 1 To 2
        Me("CommandButton" &j).backcolor = 12648447
    end sub
    it's the shorthand for
    sub snb_longer()
      For j = 1 To 2
        controls("CommandButton" &j).backcolor = 12648447
    end sub
    sub snb_still_longer()
      For j = 1 To 2
        Me.controls("CommandButton" &j).backcolor = 12648447
    end sub
    Sep 2012
    Solved
    Thanks all that helped.... I guess it would be wrong to take and not give back; So here is the non-activeX calendar I was working on for you to use/modify/laugh at.
    Cheers!
  1. Replies: 5
    Last Post: 04-18-2013, 02:30 AM
  2. Clearing UsedRange Of WorkSheet Programmatically
    By tfurnivall in forum Excel Help
    Last Post: 12-04-2012, 09:05 AM
  3. HP Calculator Buttons
    By Howardc in forum Word Help
    Last Post: 12-01-2012, 11:12 AM
  4. Add ribbon programmatically to Excel 2010 using VBA
    By heapifyman in forum Excel Ribbon and Add-Ins
    Last Post: 07-18-2011, 09:16 PM
  5. Social Network Buttons
    By Excel Fox in forum Den Of The Fox
    Last Post: 07-10-2011, 10:15 AM
