ub FormatQuantumDataDumpCS()
' Rearranges Data into the correct format and inserts correct titles for Header Row
Columns("B:E").Select
Selection.Delete Shift:=xlToLeft
Columns("C:N").Select
Columns("D:E").Select
Columns("F:J").Select
Columns("I:AA").Select
Range("A1").Select
ActiveCell.FormulaR1C1 = "W/O #"
Columns("D:D").Select
Selection.Cut
Columns("B:B").Select
Selection.Insert Shift:=xlToRight
Selection.Cut
Columns("C:C").Select
Range("C1").Select
ActiveCell.FormulaR1C1 = "Model"
Columns("E:E").Select
Selection.Cut
Range("E1").Select
ActiveCell.FormulaR1C1 = "Date In"
Columns("G:G").Select
Selection.Cut
Columns("F:F").Select
Range("F1").Select
ActiveCell.FormulaR1C1 = "Date Quoted"
Columns("H:H").Select
Selection.Cut
Range("G1").Select
ActiveCell.FormulaR1C1 = "Date App"
Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
Columns("I:I").Select
Range("H1").Select
ActiveCell.FormulaR1C1 = "Ship Date"
Range("I1").Select
ActiveCell.FormulaR1C1 = "Cost Analysis"
Range("J1").Select
ActiveCell.FormulaR1C1 = "Revenue"
Range("K1").Select
ActiveCell.FormulaR1C1 = "Margin"
Range("L1").Select
ActiveCell.FormulaR1C1 = "Credit"
Range("M1").Select
ActiveCell.FormulaR1C1 = "Notes"
Range("N1").Select
ActiveCell.FormulaR1C1 = "Unique"
Columns("A:A").ColumnWidth = 27 'This is where I change column width and format Column J to Currency
Columns("M:M").ColumnWidth = 36
Columns("J:J").ColumnWidth = 20
Columns("J:J").Select
Selection.NumberFormat = "$#,##0.00"
Range("A1").Select
Sub GroupStatusbyInsertingUniqueValueCS()
'Searches for values in column D and if Found, Inserts New value (Replacement) in Column N
Dim i As Long, j As Long, r As Range, ff As String
Dim SearchKeys1, SearchKeys2, SearchKeys3, SearchKeys4, SearhKeys5, SearchKeys6, _
SearchKeys7, SearchKeys8, SearchKeys9, SearchKeys10, SearchKeysAll, Replacement
SearchKeys1 = Array("Pre Test", "Open", "Received", "Preliminary Ins", "Insp-APU", "Pending", "Inspection", "Clean", "Pre-Test")
SearchKeys2 = Array("Approved", "Disassemble", "RETURN AS IS", "Waiting Parts", "Waiting Compone", "Assembly", _
"Test", "Post Test", "QEC", "QC", "QC Discrepancy", "Shipping Prep", "Assembly-APU")
SearchKeys3 = Array("Customer Servic")
SearchKeys4 = Array("Lease")
SearchKeys5 = Array("Quote on Hold", "Quote")
SearchKeys6 = Array("Closed", "Invoicing")
SearchKeys7 = Array("Parking Lot")
SearchKeys8 = Array("Waiting App.")
SearchKeys9 = Array("Weld", "Balance Shop", "Cancelled", "Strip Coating", "Waiting Concess", "Machine Shop", "NDT", _
"Grind Shop", "Paint", "Plating", "Chrome/Cad", "Chrome Strip", "Shot Peen", "Outside Vendor", "Waiting manual", "Quoted for Exch", _
"Sub-Assembly", "Insp-LH", "Assembly-LH", "PO AN LRU", "Harness-LG", "concession")
SearchKeysAll = Array(SearchKeys1, SearchKeys2, SearchKeys3, SearchKeys4, SearchKeys5, _
SearchKeys6, SearchKeys7, SearchKeys8, SearchKeys9)
Replacement = Array("GATE 1", "GATE 2", "CUSTOMER SERVICE", "LEASE", "QUOTE", "SHIPPED", "SURPLUS PARTS", "WAITING APPROVAL", "OTHER")
With Intersect(ActiveSheet.UsedRange, Columns(4))
For i = LBound(Replacement) To UBound(Replacement)
For j = LBound(SearchKeysAll(i)) To UBound(SearchKeysAll(i))
Set r = .Find(SearchKeysAll(i)(j), lookat:=2)
If Not r Is Nothing Then
ff = r.Address
Do
Set r = .FindNext(r)
r.Offset(, 10) = Replacement(i)
Loop Until r.Address = ff
I run the code in this sequence:
