Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Lookup First URL From Google Search Result Using VBA
    May 2013
    hi, is this possible to automate, every day i get like 2000 company names of NGOs across usa, in excel, i have to copy each company name and put it in google and get the URL...is it possible to automate it through excel programming or macros.
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgxzpgHWTLGj0C3q3gx4AaABAg. 9gxsUMU53al9k5c8W6QGE8
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg. 9gxDYq2iiZ89h4ISxLD17d
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg. 9gxDYq2iiZ89h4LdsDETim
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugz2PzvZTJyxHz70eVF4AaABAg. 9gxDYq2iiZ89h32czjtyR_
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugw_smEwvNffCPr_nrB4AaABAg. 9gvyL53lI1l9gxwd_9-V6z
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=Ugy7vmiHsQ0oUt2QCPZ4AaABAg. 9gvoy4OW6lU9gxwxC5-rL9
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgzuX3uYmqJRtsZIbqF4AaABAg. 9gth61YhXKB9gxxCMdRLA0
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgxcPC64RQGmXwO5rft4AaABAg. 9gtQLXaeg0e9gxxNuc5CCM
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwCY8vOs1DFHgYSJwF4AaABAg. 9godrFcyWYw9gxy1odpiRj
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgyL5nh_j8w70-YBoUt4AaABAg.9goMcRjwjtc9gxyslvuZKx
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwwWRgmRZNqJKptHR14AaABAg. 9go-DbayTZa9gxzPbefHXf
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgwF3wECwc8tVoRmz6B4AaABAg. 9go-5xLQM8P9gxzmB7nkVQ
    https://www.youtube.com/watch?v=xLCWtC6UYrM&lc=UgyRDmGTHnMdT7dl_qx4AaABAg
    Here's how you do it. I've attached a working file also (Excel 2007+). Post back if you are using Excel 2003-.
    For those interested in the code, and don't want to download the file itself, this is what it looks like
    Dim var As Variant
    Sub SearchGoogle()
        Dim IE As InternetExplorer
        Dim objDoc As HTMLDocument
        Dim objTextBox As HTMLInputElement
        Dim objSubmitButton As HTMLButtonElement
        Dim rng As Range
        Dim obj As Object
        Dim lngCol As Long
        Worksheets("Sheet1").Range("B2:B" & Rows.Count).ClearContents
        Set rng = Worksheets("URLEncoding").Cells(1).CurrentRegion
        ReDim var(1 To rng.Rows.Count, 1 To 2)
        For Each rng In rng.Columns(1).Cells
            var(rng.Row, 1) = rng.Text
            var(rng.Row, 2) = rng.Offset(, 1).Text
        Next rng
        Const STRURL = "http://www.google.com/#output=search&sclient=psy-ab&q=|+|&rlz=1W1LENP_enIN497&oq=|+|&gs_l=hp.12..0l4.22785.22785.0.52909.1.1.0.0.0.0.183.183.0j1.1.0...0.0...1c..12.psy-ab.Zd3_T9FwkMg&pbx=1&bav=on.2,or.r_qf.&bvm=bv.46471029,d.bmk&fp=dd21897ce84632f&biw=1704&bih=928"
        Set IE = CreateObject("InternetExplorer.Application")
        IE.Visible = True
        For Each rng In Worksheets("Sheet1").Range("A2:A20000")
            If Not IsEmpty(rng) Then
            IE.Navigate Replace(STRURL, "|+|", URLENCODED(rng.Value))
            While IE.Busy: Wend 'wait until IE is done loading page.
            While IE.readyState <> READYSTATE_COMPLETE: Wend
            Application.Wait Now() + TimeValue("00:00:02")
            Set objDoc = IE.document
            For Each obj In objDoc.getElementsByTagName("A")
                If MIMEINCLUDE(obj.mimeType) Then lngCol = lngCol + 1
                If lngCol = 6 Then
                    rng.Offset(, 1).Value = obj.href
                    lngCol = 0
                    Exit For
            Next obj
                Exit For
        Next rng
        Set objDoc = Nothing
        Set objTextBox = Nothing
        Set rng = Nothing
        IE.Quit
    Private Function URLENCODED(str) As String
        Dim lng As Long
        Dim lngRow As Long
        For lngRow = LBound(var) To UBound(var)
            str = Replace(str, var(lngRow, 1), var(lngRow, 2))
        Next lngRow
        URLENCODED = str
    Private Function MIMEINCLUDE(str As String)
        Const strDOM As String = "COM,ORG,IN,AU,US"
        Dim lng As Long
        For lng = LBound(Split(strDOM, ",")) To UBound(Split(strDOM, ","))
            If str = Split(strDOM, ",")(lng) & "/ File" Then
                MIMEINCLUDE = True: Exit For
        Next lng
    I don't claim it to be 100% fool proof. I may be missing or overlooking something that should be very obvious, but it's working for me!
    May 2013
    thanks for the quick reply and your help, after i hit Run, this is what comes up in URL. Any help?
    http://www.blogger.com/?tab=wj
    You could have corrected it by increasing the Wait time, but I thought let's go one step better.
    Try this...
    Dim var As Variant
    Sub SearchGoogle()
        Dim rng As Range
        Dim obj As Object
        Dim lngCol As Long
        Next rng
        Const strURL = "http://www.google.com/#output=search&sclient=psy-ab&q=|+|&rlz=1W1LENP_enIN497&oq=|+|&gs_l=hp.12..0l4.22785.22785.0.52909.1.1.0.0.0.0.183.183.0j1.1.0...0.0...1c..12.psy-ab.Zd3_T9FwkMg&pbx=1&bav=on.2,or.r_qf.&bvm=bv.46471029,d.bmk&fp=dd21897ce84632f&biw=1704&bih=928"
        Set IE = New InternetExplorer 'CreateObject("InternetExplorer.Application")
        IE.Visible = True
            INavigate IE, "http://www.google.com/"
                INavigate IE, Replace(strURL, "|+|", URLENCODED(rng.Value))
                While obj Is Nothing
                    Set obj = Nothing
                    Set obj = IE.document.getElementById("ires")
                    Err.Clear: On Error GoTo 0: On Error GoTo -1
                Wend
                While obj.readyState <> "complete": Wend
                Set obj = Nothing
                    If lngCol = 6 Then
                        lngCol = 0
                        Exit For
                Next obj
                Exit For
            Set obj = Nothing
        Next rng
        Set rng = Nothing
        IE.Quit
        Dim lng As Long
        Dim lngRow As Long
        Next lngRow
        URLENCODED = str
        Dim lng As Long
        Next lng
    Private Sub INavigate(IE As InternetExplorer, strURL)
        IE.Navigate strURL
    A much better alternative to my URLENCODED function is given at FreeVBCode code snippet: URLEncode for Large Strings
    May 2013
    hey fox...thank you for your efforts...i tried all your ways...the latest one.look up file. tried with the code as well. when i hit run..nothin happens, later on i get a pop up...waiting for olean application..then i click okay...it hangs.
    Working absolutely fine for me. For this to work, you must not be logged in to Google account, and your default domain should be a .COM instead of anything else.... I haven't figured a work around for this.
    You may also try this:
    My data is staring from A2 and A1 contains heading.
    Sub lm_GetGooleFirstSearchAddres()
        Dim strHtml                 As String
        Dim lngLoop                 As Long
        Dim rngRange                As Range
        Dim rngCell                 As Range
        With ThisWorkbook.Worksheets("Sheet1")
            Set rngCell = .Range("A1").CurrentRegion.Resize(, 1)
            Set rngRange = Nothing
            Set rngRange = Intersect(rngCell, rngCell.Offset(1))
            On Error GoTo -1: On Error GoTo 0: Err.Clear
            If Not rngRange Is Nothing Then
                For Each rngCell In rngRange
                    With CreateObject("MSXML2.XMLHTTP")
                        .Open "get", URLEncode(rngCell.Value), False
                        .send
                        strHtml = .responseText
                        strHtml = Mid(strHtml, InStr(1, strHtml, "<div id=""ires"">"))
                        strHtml = Mid(strHtml, 1, InStr(1, strHtml, "<div class=""s"">"))
                        strHtml = Mid(strHtml, InStr(1, strHtml, "<a href="))
                        strHtml = Mid(strHtml, InStr(1, strHtml, "<a href="), InStr(1, strHtml, """ onmousedown="""))
                        strHtml = Mid(strHtml, InStr(1, strHtml, """"), Len(strHtml) - 1)
                        rngCell.Offset(, 1).Value = Mid(Trim(strHtml), 2, Len(Trim(strHtml)) - 2)
                Next rngCell
                MsgBox "Search completed.", vbInformation, "Google Search..."
                MsgBox "No data found to search.", vbCritical, "Google Search..."
        strHtml = vbNullString
        lngLoop = Empty
        Set rngCell = Nothing
    Function URLEncode(EncodeStr As String) As String
        Dim i As Integer
        Dim erg As String
        Const strGogSrchUrl         As String = " http://www.google.co.in/search?output=search&sclient=psy-ab&q=|||&btnK="
        Const strConcatDelima       As String = "|||"
        erg = EncodeStr
        ' *** First replace '%' chr
        erg = Replace(erg, "%", Chr(1))
        ' *** then '+' chr
        erg = Replace(erg, "+", Chr(2))
        For i = 0 To 255
            Select Case i
                ' *** Allowed 'regular' characters
                Case 37, 43, 48 To 57, 65 To 90, 97 To 122
                Case 1  ' *** Replace original %
                    erg = Replace(erg, Chr(i), "%25")
                Case 2  ' *** Replace original +
                    erg = Replace(erg, Chr(i), "%2B")
                Case 32
                    erg = Replace(erg, Chr(i), "+")
                Case 3 To 15
                    erg = Replace(erg, Chr(i), "%0" & Hex(i))
                Case Else
                    erg = Replace(erg, Chr(i), "%" & Hex(i))
        URLEncode = Replace(strGogSrchUrl, strConcatDelima, erg)
        'URLEncode = strGogSrchUrl & erg
        i = Empty
        erg = vbNullString
    Junior Member SirJB7's Avatar
    May 2013
    Another approach
    Hi, joparo!
    This is a link to an alternative suggested solution posted at Chandoo's website where you started this topic/thread too :
    Search Result Using Query Table
    Regards!
    Last edited by Excel Fox; 05-18-2013 at 09:36 AM. Reason: Added URL Tag For Better Readability
  1. Replies: 4
    Last Post: 04-24-2013, 10:04 AM
  2. Find the highest then lookup result
    By Stalker in forum Excel Help
    Last Post: 04-02-2013, 02:04 PM
  3. Import html source of url list in each cell
    By Sergio Alfaro Lloret in forum Excel Help
    Last Post: 07-31-2012, 03:03 AM
  4. VBA Function to Search in Array
    Last Post: 04-10-2012, 11:34 AM
  5. VBA - Excel: Disable Internet / Google
    By technicalupload in forum Excel Help
    Last Post: 10-06-2011, 09:18 AM
