Results 1 to 10 of 11
Thread: Excel and XP Operating System Tests (Internet Router connection problems)
    Some notes in support of these Threads
    https://www.dsl-forum.de/threads/251...line-verbunden
    http://www.eileenslounge.com/viewtopic.php?f=21&t=37237
    https://telekomhilft.telekom.de/t5/T.../true#M1390641
    https://telekomhilft.telekom.de/t5/T.../true#M1394485
    The main problem is explained here: http://www.eileenslounge.com/viewtop...288546#p288546
    Here a bit of info about the “working” and not working XP machines
    “WorkingWPA”
    Non working WPA
    So it looks like Service pack 2 don’t work.
    WPA or WPA2
    It’s all to do with some secret coding / encryption. As time went on they got it more safer / more sophisticated,
    I expect when you send stuff across the air with the WLAN, then you want to try and prevent people tapping into you
    The older XP don’t know about the newer WPA2
    I did have a quick fiddle with various security settings on my computers, but that mostly just got me in a mess. But I did not really look at that in any great detail.
    My older router had written on the back WPA/WPA2 . The simple short term solution to my problem seemed to mainly to be changing something in the routers settings:
    WPA or WPA2
    WPA or WPA2
    The default original settings were
    This change was the main thing to cure the problem;
    I think that cured the problem, but there was still a bit to do. The error was still there. I am guessing that the earlier software simply is not expecting a 20 character string, possibly it’s expecting up to 16.
    Changing the number to 16 characters and almost immediately all was well, all XP machines are happy with the WLAN from the new FRITZ!Box router
    The XP machines are happy with that total fix. It’s as simple as this: with a 16 digit code and router set to WPA2(CCMP) then the offence taking XP wont get internet via WLAN. Change the router to WPA + WPA2 , hit the refresh , and internet springs into life.
    All other computers seem to be unaffected by switching back and forth in the router settings between WPA + WPA2 and WPA2(CCMP) .
    Switching the router from WPA + WPA2 to WPA2(CCMP) causes the internet to fail on the offending XP
    Niggly bit of playing around with number on Vista and Windows 7
    There was a few niggles after the change from a 20 to 16 digit password/ code
    XP was mostly no problem. Anything like
    refresh
    restart
    Deactivating and Reactivating the WLAN thing in Control panel Netzwerkverbindungen
    Or
    Anything similar usually resulted in the XP machine asking for the password/ code.
    Windows 7 and Vista gave me some problems initially. They seemed to be stuck with the old 20 digit password and did not seem to want to offer me the chance to update it , or simple re give it after a restart or refresh. I found a way to somehow get it to change or want to ask for the new code. Something similar also seemed available in XP
    The start point is to get at a list , one way or another , of available wireless connections currently “in the air” near you. Sometimes you may get offered that somewhere in the lower ribbon, towards the right, if you click on some symbol representing a wireless or aerial or antenna or similar. Another way is to navigate around Control panel / Systemsteurung
    It seems to be a bit hap hazard how / when / if you can get at such a list, so I will add a few screenshots of how I have found it
    Vista
    https://i.postimg.cc/vBGyStdd/get-to...properties.jpg
    https://i.postimg.cc/sf6zwW6t/get-to...properties.jpg
    https://i.postimg.cc/c4vSjJP6/get-to...properties.jpg
    Windows 7
    https://i.postimg.cc/26R0rCkQ/Win7-r...able-WLANs.jpg
    Once you get at a small menu from right clicking which has Properties in it, then click on the Properties and you will have a chance to write in the password/code. ( Sometimes if a number is already there, it may be an indication of it being stuck with a number).
    https://i.postimg.cc/Y9FXgJPr/get-to...nge-number.jpg
    https://i.postimg.cc/SRpgGg0W/get-to...nge-number.jpg
    Windows 10 was a bit different. As you often find, when trying to navigate around using the control panel, Properties and other old Windows explorer type ways, ( https://i.postimg.cc/7P0P99Jb/right-...then-extra.jpg https://i.postimg.cc/6qJWw2g9/right-...lable-list.jpg https://i.postimg.cc/qqsk7BH2/right-...properties.jpg ) you sometimes seem to get intercepted by the new blue background poxy new stuff
    But I did not need to find a way to get at a change in the code/password: Somehow it always knew when I had changed anything. ( So I always was offerd the chance to give a new password/code). Strange and unnerving. Possibly just Windows 10 spying on me all the time. ( I wonder if it saw me wanking about and drinking Beer last night? )
    kjhkjkjghkj
    sjfasjfalksjfalkjfasj
    jjgjkjjgjk
    test
    Post for later use
    lHdkahddha
    In support of this Thread:
    http://www.excelfox.com/forum/showth...ll=1#post11656
    Later...
    vnbvv
    Later...
    vnbvv
  1. Replies: 3
    Last Post: 11-17-2019, 11:08 PM
  3. Table Tests. And Thread Copy Tests No Reply needed
  4. VBA Trick of the Week: Range to Recordset Without Making Connection
    Last Post: 07-11-2013, 06:21 PM
  5. Get standard GMT time from the system using vba.
    Last Post: 09-13-2012, 05:21 AM
